Alternator de golf2 pe Berlina
KTC |
18 Aug 2008, 23:10
Membru autentic Group: Members Posts: 341 Joined: 3 May 06 From: BUC -IF |
Attached thumbnail(s) DSC01582.JPG ( Size: 441.61k ) Number of downloads: 1721 DSC01581.JPG ( Size: 516.16k ) Number of downloads: 1927 DSC01580.JPG ( Size: 528.44k ) Number of downloads: 1795 DSC01579.JPG ( Size: 479.2k ) Number of downloads: 1754 DSC01577.JPG ( Size: 495.01k ) Number of downloads: 1823 DSC01576.JPG ( Size: 480.24k ) Number of downloads: 881 DSC01575.JPG ( Size: 514.49k ) Number of downloads: 753 DSC01574.JPG ( Size: 536.93k ) Number of downloads: 729 DSC01572.JPG ( Size: 449.8k ) Number of downloads: 755 DSC01571.JPG ( Size: 477.05k ) Number of downloads: 887 DSC01557.JPG ( Size: 564.51k ) Number of downloads: 943 DSC01578.JPG ( Size: 209.9k ) Number of downloads: 858 |
`85 (54cp)
- IF 75 KTC BMW 325i `93 (192cp) - B 95 KTC
18 Aug 2008, 23:19
cam mica tensiunea ar trebui sa ai cel putin 14V ai incercat sa vezi tensiunea cind era turata?
LAUREATE 1,6 GPL
19 Aug 2008, 06:27
prea mare diferenta de al ralanti la turat, ar trebui sa fie maxim 0,2 V, si tensiunea in general nu are voie sa scada sub 14 si sa depaseasca 14,4. La tensiunea aia la ralanti degeaba la montat zic eu. Sau poate avea consumatori mari porniti?!
emircea |
21 Aug 2008, 12:03
membru cu Te-FiSI Group: Members Posts: 756 Joined: 14 June 04 From: Timisoara |
Dacia 1300, 1981;
1981 / 1977 / 2009
ciprianeduard |
31 Aug 2008, 19:51
Membru agitat Group: Members Posts: 743 Joined: 16 June 05 From: PLOIESTI |
La mine am alternator valeo 80 A (de supernova) si la relanti (cam 900 ture ) cu farurile aprinse am 14,02 , o sa postez si o poza . Nu am nici o variatie in intensitatea luminoasa a farurilor relanti-turatie si am becuri originale de logan ( renault scrie pe cutie ) de 55W / 65W
31 Aug 2008, 19:53: Becurile oricinale de dacia clasica au 45/55 iar cele de logan se pot monta impreuna cu o flansa adaptoare care la piese auto costa 1 ron bucata This post has been edited by ciprianeduard: 31 Aug 2008, 19:53 |
MCV 1.5 DCI, SOLENZA 1.4 MPI
2008, 2004
- ...... _____________________________________________________________________
talentosu' |
16 Mar 2009, 23:43
Membru incepator Group: Members Posts: 4 Joined: 1 February 08 |
aqm vad eu ce a postat tovarashul meu )... pai acolo aveam bateria descarcata. in prezent am un condens de 1F si cand porneste alternatorul imi indica 14v constant, cu toti consumatorii deschisi imi coboara la 13.5. ar mai fi muzica... atunci cand dau in blana suge grav cu tot cu condensator... bateria e si ea de 65Ah. iar alternatorul nush ce are de porneste mai greu... cred ca din cauza contactelor... trebuie sa turez un pic motorul pana la 2800-3000 de ture ca sa porneasca si atunci se aprind farurile si toate luminile mai puternic. stiu ca nu e bine asta oricum! oricum e jmeker alternatoru de golf... practic nu am facut nicio modificare in afara de fulia aia si de saiba la surubul acela lung incercuit in poza de mai sus
2000 injectie
- IF 87 TMY
B-03-YHD |
19 Mar 2009, 12:19
Membru incepator Group: Members Posts: 89 Joined: 13 March 09 From: Bucuresti / Pitesti |
Incarca bine. Alternatorul in principiu nu porneste. Daca pui voltmetru pe el si invarti fulia cu mana vei observa o mica variatie de tensiune (deci incarca si daca invarti cu mana, insa cam egal cu 0). La tine alta e buba cu farurile. Poate acumulatorul... ii scade tensiunea prea mult la pornire? Oricum nu e alternatorul. Ala incarca sau nu.
Puterea farurilor fluctueaza odata cu turatia? Daca da, si nu mult, e ok. Nu iti face probleme. This post has been edited by B-03-YHD: 19 Mar 2009, 12:21 |
1310 L
1993 Break
- B-03-YHD Skoda Fabia 2003 Break - B-25-TTB
Cine-i harnic si munceste, are tot ce vrea. Cine-i lenes, trandaveste, are mai ceva! |
parpanel |
19 Mar 2009, 13:28
Calator Group: Members Posts: 805 Joined: 11 March 05 |
QUOTE(talentosu' @ 16 Mar 2009, 23:43) aqm vad eu ce a postat tovarashul meu )... pai acolo aveam bateria descarcata. in prezent am un condens de 1F si cand porneste alternatorul imi indica 14v constant, cu toti consumatorii deschisi imi coboara la 13.5. ar mai fi muzica... atunci cand dau in blana suge grav cu tot cu condensator... bateria e si ea de 65Ah. iar alternatorul nush ce are de porneste mai greu... cred ca din cauza contactelor... trebuie sa turez un pic motorul pana la 2800-3000 de ture ca sa porneasca si atunci se aprind farurile si toate luminile mai puternic. stiu ca nu e bine asta oricum! oricum e jmeker alternatoru de golf... practic nu am facut nicio modificare in afara de fulia aia si de saiba la surubul acela lung incercuit in poza de mai sus E din cauza diodei de sens si lipsa curentului de excitatie. Schimb-o cu un bec ordinar. |
2006 Ambition
DannY_SmekeruL |
26 Mar 2009, 21:07
Membru autentic Group: Members Posts: 454 Joined: 30 August 07 From: Bucuresti-Slobozia |
am si eu un alternator de golf care as vrea sa il pun pe dacie dar nu stiu cum sa leg firele.din alternator mai iese un fir care nu stiu unde se duce.
Attached thumbnail(s) aa.JPG ( Size: 319.9k ) Number of downloads: 677 |
SOON Dacia 1310
with F7P Kompressor Edition
'84 VW Passat B6 2.0 TDI
Daniellos3 |
14 Nov 2011, 22:29
Membru incepator Group: Members Posts: 2 Joined: 14 November 11 |
Salut baieti! Am si eu un Break pe injectie din 2004 si as vrea sa-i pun un alternator de capacitate mai mare caci asta din fabrica am impresia ca nu prea incarca cum trebuie, adica iarna, cu muzica (un cd-player Pioneer de 4 * 25 W RMS cu niste Magnat de 15*23 cm pe spate), lumini, ventilatie, dezaburire la relanti, ia vizibil din lumina farurilor, mai exact, palpaie; si-n plus, scade simtitor turatia motorului... Am citit ce-ati postat voi despre topic-ul asta si as vrea sa-mi dati un sfat; adica ce alternator sa pun (de preferabil unul care sa nu necesite modificari majore si complicate), unde gasesc, cat costa... Multumesc anticipat!
2004 Break
Kiraly |
14 Nov 2011, 23:28
Membru autentic Group: Members Posts: 921 Joined: 21 May 10 |
raspunsul la intrebarea ta este titlul topicului...alternatorul de Golf2 se potriveste fara modificari complicate..ia unul bun linistit cu cat mai multi "cai" si forumul te ajuta sa-l montezi si sa-l legi.bafta
1310 Li
- BH 90 PUP sufli in jigler pui o sarma si gata!!!
Daniellos3 |
19 Nov 2011, 00:49
Am inteles. Multumesc!
2004 Break
ghitza |
19 Nov 2011, 14:57
eu am pus de 75A de un R21 parca si ii arhisuficient
Dacia/BMW 316i an 99
1310 li
2003 Berlina
- Ar-07-GIB/BG
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 30th May 2024 - 16:21 |
