Un topic pentru off topic
gabize |
11 Oct 2019, 06:10
#7021
DECONECTAT Group: Members Posts: 6.017 Joined: 21 July 08 From: ©City of Mini Roundabouts |
⚓ Am decât
o... barcă...
+ H247 "Unde poți lega cu sârmă, e păcat să pui șurub!"
axabrt |
11 Oct 2019, 06:12
#7022
Membru autentic Group: Members Posts: 3.067 Joined: 15 February 05 From: Ploiesti |
Focus mk3.5
11 Oct 2019, 08:03
#7023
fan Dacia Group: Members Posts: 19.943 Joined: 12 November 05 From: Bucuresti |
radian |
11 Oct 2019, 08:33
#7024
gandeste pozitiv: nu spera si nu ai teama... Group: Members Posts: 1.273 Joined: 17 January 05 From: petrosani |
Esti tu sigur ca vaporii aia sunt mai grei decat aerul si se depun pe grila de aspirare aer aeroterma? Daca sunt mai usori ca aerul si vaporii aia mici si rai zuburda fericiti spre ceruri?
dacia logan
ambition
- HD 06 LDM
ady77 |
11 Oct 2019, 08:55
#7025
راحتزیل یو Group: Members Posts: 1.721 Joined: 15 December 05 From: near Bacau |
Oricum Axa are o sticla de coniac in masina, preventiv
________________
________________
ecnedifnocfollufsisoM |
DannyY |
11 Oct 2019, 09:35
#7026
Marele plictisit Group: Members Posts: 1.695 Joined: 5 May 09 |
Cine nu suporta coniacul poate folosi Jameson?
Opel/Honda/Opel
Astra G/Civic 4D/Corsa E
2004/2015/2019
ady77 |
11 Oct 2019, 10:56
#7027
Da, dar nu singur
________________
________________
bion |
11 Oct 2019, 18:51
#7028
SLZ Scala
pistritu |
11 Oct 2019, 18:52
#7029
Membru autentic Group: Members Posts: 520 Joined: 8 May 14 |
-- Gil26 este bolnav psihic
bion |
11 Oct 2019, 19:05
#7030
Dau o bere virtuala sau pentru consateni reala daca stie cineva raspunsul la intrebarea: La motoarele 1,2 tsi baujahr 2016 cand si daca se schimba cureaua de distributie?La trei service-uri inclusiv doua dedicate zic ca nu e normat.La Porsche ziceau sa nu o schimb ca ce e pe piata sigur o sa crape dupa un timp.
Caruta are seria wvwzzz16zgm036882. Astept provincia si rog seriozitate. "Der Zahnriemen bei den Golf 7 TSI Motoren 1.2 und 1.4 ltr hat kein festes Wechselintervall. Er wird erstmalig bei der Inspektion nach 240.000 km überprüft, dann weiter alle 30.000 km. Nur im Falle von Beschädigungen/Verschleiß wird der Zahnriemen gewechselt. Bei den Golf 7 CR Dieselmotoren wird der Zahnriemen zusammen mit der Spannrolle nach jeweils 210.000 km ersetzt." Alti savanti germani Im Gegensatz zu den TSI Motoren im Golf 6 (vorwiegend 1.4 TSI) haben die Golf 7 Motoren an Stelle einer Steuerkette einen Zahnriemen. Der Grund ist einfach: Im Golf 6 gab es einfach zu häufig Probleme mit der Steuerkette, die ja eigentlich wartungsfrei sein sollte. Volkswagen wird euren Zahnriemen ab den 90000er Inspektionen prüfen und danach auch bei den folgenden Inspektionen immer eine Prüfung durchführen. Der Wechsel des Zahnriemens wird dann spätestens bei 180000 Kilometern (das kennt ihr vielleicht schon vom TDI Dieselmotor) erfolgen. Utilzati goagltransleit ca mi-a fost lene sa traduc. Multumesc This post has been edited by bion: 11 Oct 2019, 19:17 |
SLZ Scala
axabrt |
11 Oct 2019, 19:46
#7031
New bioane am căutat o jumate de oră , despre cureaua de la motoru lu matale, EA211, dar n am găsit nimic.
Parca ar fi așa ceva strict secret. Am găsit pe un forum Skoda că se verifca la 60000 și se schimba la 120000 sau 10 ani dar nimic sigur. Am mai găsit asta, dar iarăși nu e nimic sigur Screenshot_20191011_205613.png ( Size: 174.69k ) Number of downloads: 364 Pe de altă parte puteai și tu să ți iei Ford. Găseai imediat toate informațiile Ford Europe - Ecoboost engines 1.0L / 1.5L -The timing belt with oil bath -Change interval: 240,000 km / ten years. This post has been edited by axabrt: 11 Oct 2019, 19:57 |
Focus mk3.5
psychoo |
11 Oct 2019, 20:05
#7032
Membru Group: Members Posts: 3.419 Joined: 23 August 07 From: Timisoara |
Heh, acolo ne indreptam. Masini de unica folosinta.
In viitor cand expira garantia o sa vina direct platforma si o ia din parcare |
Focus
DannyY |
11 Oct 2019, 21:33
#7033
Cand se rupe, e clar ca trebuie schimbata.
Opel/Honda/Opel
2004/2015/2019
pistritu |
11 Oct 2019, 21:44
#7034
Uite ce scrie cineva pe vwforum
"Motorul de 1.2 TSI 105 are 16 Valve pe masina asta. Cu capota ridicata, zgomotul variantei anterioare (gen masina de cusut) s-a diminuat cu 75%. Se aude aproape ca un aspirat clasic pe benzina, semn ca schimbarea lantului in curea cu insertii metalice este de bun augur. Distributia se schimba acum la 220.000 km cu verificare la 180.000 km. Absolut decent, parerea mea." Sursa, postul" ritter1976 Posted February 27, 2013" https://vwforum.ro/topic/96583-golf-7-parer...presii/page/46/ This post has been edited by pistritu: 11 Oct 2019, 21:44 |
psychoo |
11 Oct 2019, 21:58
#7035
Nu e informatie oficiala, deci nu se poate garanta veridicitatea.
Faptul ca producatorul nu mentioneaza nicaieri un interval imi pare cel putin dubios. As incerca sa dau un mail la fauve dar nu in romania |
Focus
DragosP |
11 Oct 2019, 22:15
#7036
Nu se strică. E germană, ce naiba!
Ceva de plastic
Cu noi este Dumnezeu! |
pistritu |
11 Oct 2019, 22:19
#7037
pistritu |
12 Oct 2019, 22:20
#7038
Info exacte ptr motorul 1,2tsi
Sursa aici https://vwforum.ro/topic/28134-schimbare-di...e/107/#comments Attached thumbnail(s) benzina.thumb.jpg.4758b6f48a3f229819158c2d31e2d1ec.jpg ( Size: 34.74k ) Number of downloads: 313 benzina2.thumb.jpg.2a11c04ad8c5d3e399da67cb8513b162.jpg ( Size: 30.65k ) Number of downloads: 314 |
14 Oct 2019, 08:35
#7039
Avem un coleg care lucra la porsche, aveau interval de schimb la curea de accesorii 120 000 km pt 1.9 tdi . La rveizia de 60 000 o inspecta el si te anunta ca trebuie inlocuita. Daca refuzai si se rupea pana la 120 000, nema garantie.
ady77 |
14 Oct 2019, 09:56
#7040
Adevarul ca parerea lui DOrel bate hartiile.
________________
________________
sorin1983 |
14 Oct 2019, 10:27
#7041
Membru autentic Group: Members Posts: 5.589 Joined: 3 July 06 From: Bucuresti-Rahova |
si atunci la ce bun sa mai dai un interval cand nu se stie daca il atingi? asa si la distributie poate fi, iti desfac capacul si iti zic ca trebuie inlocuita la 120000 fata de 240000.
Megane1-
14 Oct 2019, 11:46
#7042
pai daca e unu ca psychoo care la 200 000 are amortizoare originale si e si de parere ca sunt ok, il doare undeva de parerile alora din service.
S PSA are curele in baie d eulei care tin 10 ani sau 240 000 km |
psychoo |
14 Oct 2019, 20:58
#7043
Dorele, au fost masurate in service, degeaba bagi bațul prin gard
Focus
busu 12 |
14 Oct 2019, 21:47
#7044
Member Group: Members Posts: 567 Joined: 22 October 14 |
Testu de amortizoare in service dacia reno este vax, vezi ca se plangea lumea in niste topicuri pe forumul reno
1
4x4 |
14 Oct 2019, 21:59
#7045
Übermensch Group: Members Posts: 3.394 Joined: 24 March 07 |
Pun pariu ca nu au verificat nici presiunea din pneuri , trist dar adevarat in mare parte testul de amortizoare classic pe platane oscilante in service e util doar ca sa localizezi pe ce parte e defectul. Un amortizor se testeaza demontat, dar doreii nu dau bani nici pe sdvuri...
W
S
S Attere Dominatum!
bion |
15 Oct 2019, 19:14
#7046
QUOTE(pistritu @ 12 Oct 2019, 23:20) Info exacte ptr motorul 1,2tsi Sursa aici https://vwforum.ro/topic/28134-schimbare-di...e/107/#comments Multam. Din lista lipseste egzapt CYVD din dotare.Probabil ca o jalba la vw o sa ma bage in ceata complet. Testat telescoape. La ciclop 75/80 la Procar 81/81 ( fata). Asa ca am bifat reparatie palarii telescop si bielete antiruliu.Telscoape la anu impreuna cu discurile de frana. |
SLZ Scala
16 Oct 2019, 07:28
#7047
apropo de CBuri care mint:
Am luat un logan de la munca, buc-mioveni si retur 250 km cu 150 (minim 130) pe autostrada.... si nu a scazut indicatorul de carburant nici o linie. merg la benzinarie, pun motorina si intra 7,5litri.... Sa fiu si eu obtuz sa zic ca CBul cu 8% minte (neresetat la plecarea la drum)? Ala dinainte a facut plinul pana a dat pe jos, drumul ala ia 14litri d eobicei. |
radian |
1 Nov 2019, 07:46
#7048
Azi e ziua cand targul se umple de cersetori. Undeva pe la ora 8 AM ajunge in gara personalul Craiova _ Petrosani, azi, plin ochi cu tigani cersetori din Oltenia.
Azi e ziua mortilor, ceremonie preluata de romani de la maghiari. De fapt ziua mortilor, Luminatia e pe 2 noiembrie si la catolici, reformati azi e ziua tuturor sfintilor, dar din motive care-mi scapa de foarte multi ani a ramas 1 noiembrie ca fiind ziua mortilor. Si a doua "completare" semnificativa adusa de ortodocsi la ceremonia Luminatiei este datul de pomana. Nu poti sa mergi in cimitir linistit sa depui o floare la mormantul celor dragi care nu mai sunt ca la fiecare pas te trage cate unul de maneca sa-i dai ceva ... |
dacia logan
ambition
- HD 06 LDM
bgdrenault |
1 Nov 2019, 10:06
#7049
bgd Group: Members Posts: 3.319 Joined: 4 February 07 From: Piatra Neamt |
Azi sau maine?
https://www.google.com/url?sa=t&rct=j&q=&es...zplc_IuO7gah-tx This post has been edited by bgdrenault: 1 Nov 2019, 10:08 |
Megane
Sedan 1,33 140 CP
2019 Intens
- XXX
DragosP |
1 Nov 2019, 10:14
#7050
El vorbește despre altceva.
Ceva de plastic
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 9th May 2024 - 21:04 |
