Hydraulic clutch for Logan
ezee |
19 Jun 2008, 19:34
Ezee Group: Members Posts: 53 Joined: 4 December 07 From: India |
Mahindra Renault
Logan DLS 1.5 Diesel
martin245 |
19 Jun 2008, 21:42
EX PAT Group: Members Posts: 913 Joined: 1 April 06 From: Karlsbad Germany (again) |
All our Logans have cable clutches and I find no problem with them at all
I have driven on one drive 1400km one way with no problems you need to strengthen the muscles in your legs Stu |
logan 14 mpi Simply RED
- GB 1 Bessy Regs
heinz57g |
19 Jun 2008, 22:19
IN PAT Group: Members Posts: 200 Joined: 6 May 07 |
ezee, pls tell me this was just a joke!
greetings - heinz - |
LOGANs, several
2004 - 2008 There is nothing wrong with change, if it is in the right direction. Thats why the British drive on the left.
g100sic |
20 Jun 2008, 11:15
Membru autentic Group: Members Posts: 313 Joined: 4 January 07 From: Serbia |
Try the clutch in Lada Samara, then complain about Logan
Fiesta 1.4 (96 HP)
2010 / Trend (Flex Pack 11) Never argue with a fool -- people might not notice the difference! (Murphy's First Law of Debate)
Asi |
20 Jun 2008, 13:52
Camaro SS Group: Members Posts: 930 Joined: 24 July 05 From: Bucuresti |
what's the purpose of a hydraulic operated clutch? because only the command part is hydraulic, (it is still a dry friction type of clutch).
A good use would be a "wet" multidisk cluth, but that's an overkill to a logan. Or a hydrotransformer but it's useless without an automatic gearbox (panetary type). Any way, the cable operated clutch it's still a very reliable sistem. (and by the way, a regular faulty of 3-series bmw -old ones- was the leak in the master cilinder of the hydraulic operated clutch. So afterall it isn't "bulletproof" as some may think.. sometimes it just makes things more complicated, and that means more things can go wrong) So .. get used to it! |
Mitsubishi/Mercedes
Carisma/B-class
2003 1.9 DI-D/2007 200CDI
ezee |
20 Jun 2008, 17:40
As per a rep from company told me they have hydraulic clutch in EU countries, and removed that here in India for cost cutting purpose only.
Now its not me, there were others as well who were complaining of hard clutch at service center .... I somehow manage with this system by giving relax to my legs max possible but what about ladies drivers? |
Mahindra Renault
20 Jun 2008, 18:54
the cable actioned clutch on logan is not hard on cars in europe, i don't know in india. but it has a very long displacement of the pedal, the purpose of that being the exactly not to be hard clutch.
Is a kind of uncomfortable that long moves of clutch pedal, but the pedal is not hard. Actually on hydraulic clutch it seems to me the pedal is harder, but i should be wrong. But you should check the clutch cable, because the presence of a fault cable is common in Romania |
martin245 |
20 Jun 2008, 23:42
OK you will be annoyed with me Eeeze but could it be that indians have shorter legs
Sorry i could not resist that Stu |
- GB 1 Bessy Regs
ezee |
21 Jun 2008, 19:48
I am 5.10"
Mahindra Renault
voicamic |
16 Oct 2008, 18:28
Membru Group: Members Posts: 178 Joined: 28 December 04 From: Bucuresti |
Hi, Eeze! Did you finally solve the hard working clutch? By any chance did you find the cable having a fold ruptured and rubbing against the cable sleeve?
Dacia Logan MCV
Laureate 1.5 dCI 68 CP
- B-**-*** Fugi D'acia!
ezee |
30 Mar 2009, 16:49
I could not find any fault in clutch cable but have developed a regular knee pain (only in left leg). No solutions from company as well.
Mahindra Renault
nagarajkumbar |
26 Nov 2010, 13:17
Membru incepator Group: Members Posts: 1 Joined: 26 November 10 |
logan 1.5dls
zeljkor |
30 May 2011, 01:10
Membru incepator Group: Members Posts: 1 Joined: 12 May 11 |
Whether it can be found in Romania "aftermarket" hydro bearings?
Laureat
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 26th April 2024 - 21:09 |
