Alarma Cu Probleme
Alarma Cu Probleme
megane sedan |
24 Jun 2005, 07:21
Membru incepator Group: Members Posts: 3 Joined: 17 June 05 |
renault
megane
2005 sedan
Lex Luthor |
24 Jun 2005, 07:31
Membru autentic Group: Members Posts: 1.112 Joined: 25 April 05 |
Incearca sa mergi la firma Gemenii (care a instalat alarma) si sa-ti reduca sensibilitatea senzorilor (banuiesc ca ai senzori de volum habitaclu). Adresa si numerele de telefon le ai pe sticker-ul de pe geam.
meganescu |
24 Jun 2005, 10:11
Membru autentic Group: Members Posts: 286 Joined: 20 August 04 |
Mare porcarie alarma de la Gemini ...
Boby |
1 Jul 2005, 14:02
Membru incepator Group: Members Posts: 29 Joined: 21 April 05 |
Mi-a urlat si mie intr o seara de n ori pina am realizat ca era plafoniera din spate aprinsa... cum am stins-o, cum am putut avea si eu un somn linistit...
Megane Sedane
1.6 16V 2005 Renault Megane II Sedan Influence
1.6 16V Gri Eclipse May 2005 ----------------------------------------- Dacia Nova GT 1.6 Gri Nov 1999 |
rombu |
1 Jul 2005, 17:03
FOR SALE Group: Members Posts: 586 Joined: 20 August 04 From: Bucuresti |
sau mai exista varianta (pt fericitii posesor de HB) ca mica jmekerie eelctrica de la haion sa nu fi agatzat adica ala nu s-a inkis...tu zici ca e inkis ca asa se vede..da daca tragi de el se rodica fara probleme...si contactu ala e cumva...de simte ca e descuiat nu neaparat departat
Megane 2
2004 Confort Dynamique Megane II BICORP 1.6 16V Confort Dinamique
Gris Hologramme- 2004 Bucuresti |
Tudor |
2 Jul 2005, 16:43
Moderator Group: Members Posts: 1.824 Joined: 10 May 05 From: Bucuresti |
Alarma Gemeni e ok, e compatibila cu diesel (eu am), atentie la consumatori si senzori inchidere usi (incl portbagaj, subscriu la cele spuse de Rombu): daca urla e vreun bec aprins sau vreo usa nu e inchisa bine.
Clio III
2006 1,5 dCi 80cp Dynamique 3usi Honda CR-V 2006 2,2 CDTi 140cp Executive
danutzu |
25 Jul 2005, 16:27
Membru incepator Group: Members Posts: 10 Joined: 25 July 05 |
Am si yo o problema cu alarma Gemini : alarma asta are senzori doar pentru habitaclu? Adica daca vine unu si da ca nebunu in masina alarma nu face nimic si doar daca intra nebunu in masina incepe sa urle? Asa e?
Megane II Sedan
1,6 16v
cornel_t |
25 Jul 2005, 16:32
Membru autentic Group: Members Posts: 1.174 Joined: 12 November 04 From: Bucuresti |
Asa e. Tu ai doar senzori volumetrici, pt respectivu nebun itzi trebuie senzor de soc.
-------------------- Honda Accord 2.2 i-CTDi EX
25 Jul 2005, 16:37
*** Big Daddy *** Group: Members Posts: 755 Joined: 5 February 05 From: ...pe aici, pe dincolo, pe peste tot... |
Vezi ca se poate monta ulterior. Eu am montat:
-senzor soc 25Euro -sirena 25Euro -modul ridicare geamuri 50Euro. |
Clio Bicorp
2005-dCi/80cp Clio Bicorp Dynamique 1,5dCi/80CP, Bleu Odissee, Full Options (15.06.05)
VW Polo 1,4 TDI PD/105CP, Attractive, chiptuning by TCM Turbo (24.10.05) |
danutzu |
25 Jul 2005, 17:20
Multumesc! Am sunat si la Meridian de unde am luat masinuca si asa e : am doar senzori volumetrici .
Megane II Sedan
1,6 16v
alexnet |
10 Aug 2005, 13:10
Membru Group: Members Posts: 183 Joined: 23 June 05 |
Salutare tuturor,
De 2 saptamani sunt fericitul posesor al unui Megan II Sedan (upgrade de la Solentza) si am alarma Gemini primita cadou de la AutoCobalcescu. Un singur lucru ma enerveaza la culme si anume ca se autoarmeaza cam la 30 sec dupa ce opresc motorul si urla de era sa fac stop cardiac de cateva ori. Stie cineva cum pot anula functia de autoarmare, pt ca nu am gasit nimic in fituica pe care am primit-o de la dealer? Multumesc, |
-------------------- Megane II Sedan 1.5 dCi 80 CP, Gris platine
Confort Expression + clima automata, jante aliaj Iulie 2005 |
cornel_t |
10 Aug 2005, 13:19
Da o cautare pe google dupa tipul alarmei si sigur gasesti cum sa dezactivezi aceasta functie.
reno-Sergiu |
22 Dec 2005, 01:46
Membru incepator Group: Members Posts: 21 Joined: 19 May 05 From: Bucuresti |
Salut!
E a doua oara cand am ceva probleme cu Alarma mea Gemeni! Bineinteles prima data se declansa singura dupa armare (bec lasat aprins pe plafoniera). Asta a trecut, rezolvat, lasat tot timpul plafoniera pe pozitia mijloc. In noaptea asta (la 1 noaptea o apuca) s-a declansat deja de 3 ori singura... deja ma astept la ghivece sau sticle pe masina Recitesc forumul, ma duc jos sa verific (nu am mai incercat faza cu "de cate ori palpaie ledu" ptr diagnostic - ca deja o dezarmam/armam de la balcon. Evident la masina usile inchise, nu a umblat nimeni, tot ce am gasit ca explicatie era geamul dreapta spate neinchis perfect, poate o fi intrat un fulg/doi de nea si i-au simtit senzorii? Inchis toate geamurile, reinchis usile, inchise plafonierele (just in case).. sper sa pot sa dorm.. A mai intalnit cineva probleme chiar din senin? Sau fara o frecventa clara? |
Megane
2005 Influence Megane Bicorp Influence 1.4 16V 98CP- Mai 2005
Bleu Encre |
another_brick_in_the_wall |
22 Dec 2005, 11:01
Membru incepator Group: Members Posts: 82 Joined: 30 August 05 |
Salut,
probleme cu "alarma" am avut si eu la meganelu' meu... dar nu alarma era de vina... Am montat alarma Viper cu pager si problema a fost ca pornea din senin... dupa ce am evitat oarece ghivece, legume de tot felul, dupa ce am iesit in pijamale in toiu' noptii (iarna trecuta) pt ca pagerul imi indica ca s-a deschis o usa, am decis ca trebe sa merg la service-ul care mi-a montat alarma sa vad de unde se intimpla asa ceva... Anyway, cel care mi-a montat alarma nu era acolo dar am intilnit un baiat care stia de problema asta, si mi-a explicat ce a gresit colegul lui... Explicatia o s-o gasiti in cele ce urmeaza...: "calculatorul" de Megane II face o verificare la fiecare (parca) 60 minute si testeaza daca toate usile sint inchise, geamurile si luminile.... Impulsul pe care il trimite calculatorul catre fiecare usa sa testeze starea incuietorilor (eu banuiesc ca doar mai comanda inchiderea pe fiecare usa) declanseaza alarma si tot scandalul... Acel om de la service mi-a montat alarma asa cum trebuie si de atunci nu mai am nici o problema... |
Megane II
2005/Dynamique Megane II Bicorp
1,5dCi - Dynamique |
claus |
22 Dec 2005, 13:49
private spice Group: Members Posts: 1.695 Joined: 27 November 03 From: Bucuresti |
sergiu.. am patit si eu cu bec lasat aprins la plafoniera.. si geam uitat deschis in rest.. nici un deranj.. super multumit de ea
renault
megane II
2003 confort dynamique
reno-Sergiu |
22 Dec 2005, 23:54
Mers la service la Gemini direct! (intai prin telefon m-au intrebat cum am plafoniera:) )
Rezolvat, sau asa mi s-a comunicat. Senzorii volumetrici prea sensibili reglati, au perceput contractia volumului de aer existent in masina (a venit frigul). Cum a verificat asta: cu geamul deschis, alarma pornita a bagat mana inauntru, s-a declansat de la cateva degete inauntru. Modificat senzitivitatea acum se declanseaza la o mana inauntru . Initial nu prea imi venea sa cred dar tipul meserias. Apropo ce m-a invatat: cum sa inchizi usile din telecomanda fara sa armezi alarma! Inchizi, se aprinde ledul rosu (sta aprins inainte de armare). Descui iar din telecomanda si inchizi imediat. becul ramane stins, alarma nu se mai armeaza, usile sunt inchise. Sper sa nu mai fie probleme, dar chiar daca mai sunt, macar stiu cum sa incui masina fara alarma ! |
Megane
Bleu Encre |
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 27th April 2024 - 04:08 |
