Airbag problem, passanger light faintly turn on and off
pepsi_bozic |
16 Feb 2005, 15:34
Membru incepator Group: Members Posts: 2 Joined: 16 February 05 |
Hentiu |
16 Feb 2005, 15:45
Membru incepator Group: Members Posts: 59 Joined: 2 July 04 From: Timisoara |
Hi,
Don't worry too much... We all have the same problem... There is not very bad, that means, the airbag is working, but seems to be some problem to the LED electrical circuit... It is posiible, Dacia will gve us a solution, sometime in the near future, and we will let you know about. Drive safely ! |
Logan Ambition
- TM-96-HEN
pepsi_bozic |
16 Feb 2005, 16:00
Thanks Hentiu This post has been edited by pepsi_bozic: 16 Feb 2005, 16:02 |
MoneyTalks |
20 Feb 2005, 01:59
- Group: Members Posts: 2.712 Joined: 18 April 03 From: Ireland |
QUOTE(Hentiu @ 16 Feb 2005, 14:45) the airbag is working, As long as you don't have an accident, you just assume that the airbag is working... |
Lexus
ES300H
dras |
28 Mar 2005, 20:17
Driver Group: Members Posts: 163 Joined: 21 November 04 From: Bucuresti |
I just visited the dealer for a check on my Logan.
Nothing wrong with it, but I wanted them to test it on the computer and tell me how things are going. I told them about the blinking LED from the passenger's air bag and not only they told me it's OK, but they tested in front of the the air bags (the car has about 5 computers which are controlling various functions like braking, airbags&seatbelts, locking system, and so on). The test showed that the device is working properly. Then htey have explained that the Logan display is "borrowed" with some modification from Renault CLio which had the same issue. It appears that the light is circulated through a plastic tube which by default has a small crack which in complete darkness gives the impresions that the passenger's airbag is blinking. The problem was solvd in CLio after the facelift. So you really dont anything to worry abount as long as the LED is not well lit. GL |
Honda
Accord Executive
2007 / 2.0 A/T 155CP
- B-74-***
29 Mar 2005, 09:41
The dealer was right the problem is present on clio II also, but regarding the light coming from outside, is not true. The led is really blinking. Is an issue with the rezistors in the airbag computer (or with the resistors in dashboard, one of them).
The computers on logan are: 1. Engine computer 2. UCH - Computer for "habitacle" 3. ABS computer 4. Airbag computer (logan does not have pretensioned seat-belts) |
dras |
29 Mar 2005, 15:40
QUOTE(klaus @ 29 Mar 2005, 09:41) The dealer was right the problem is present on clio II also, but regarding the light coming from outside, is not true. The led is really blinking. Is an issue with the rezistors in the airbag computer (or with the resistors in dashboard, one of them). The computers on logan are: 1. Engine computer 2. UCH - Computer for "habitacle" 3. ABS computer 4. Airbag computer (logan does not have pretensioned seat-belts) True. Now that you mentioned it (except for the part with light coming from outside which was what the guy from DaciaTec told me) I remember. |
Honda
Accord Executive
- B-74-***
Boris |
1 Apr 2005, 10:35
Croatian member Group: Members Posts: 497 Joined: 20 October 04 From: Zagreb, Croatia |
Just read something about it on a Croatian Renault forum. Aparently, as mentioned, the Clio 2 Phase I, and Clio II phase II also have the same problem. One guy there says that is't a problem with poor wire connector and that it can be fixed by changing teh connector. Apparently the wires in question are under the seat. I don't know if there are any wires under the Logan seat, but maybe it's the same problem. BTW, I don't have that problem, nothing blinking. |
Logan Laureate 1.6
2005 + LPG Landi Renzo sequent Reliability of machines is inversely proportional to the number and importance of people watching it
mccoy |
1 Apr 2005, 15:33
Membru autentic Group: Members Posts: 273 Joined: 2 January 05 From: small town in Vojvodina |
Laureate 1.6
- ...98-7. -----------------------------
Divide et impera ... and unite in EU ! ----------------------------- |
dras |
1 Apr 2005, 18:44
QUOTE(mccoy @ 1 Apr 2005, 15:33) Don't worry. I'm sure you have it. I have only noticed it after 1 and 1/2 months of driving the car. There must be complete darkness around you and if you turn on the headlights you won't see it because it's so fade that it's unoticeable near other lights. Or, maybe they have changed the assembly line for your car |
Honda
Accord Executive
- B-74-***
mccoy |
1 Apr 2005, 23:58
QUOTE(dras @ 1 Apr 2005, 17:44) After having been in garage,doing some hard examinations, I am obliged to confess that I was wrong. Yes,there is tiny,bluish blinking of airbag lamp. I couldn`t notice it from normal driving distance,but when I came closer,nearly putting my head ( not so small ) through steering wheel I experienced revelation. Oh,what a “eye of the hawk” you have… Tomorrow,I`m going to visit oculist . P.S. Let The Old Man rest in peace… |
Laureate 1.6
dras |
4 Apr 2005, 07:05
Don't worry too much. Your eyes are fine. Maybe there's something wrong with the guys who tested the machines before sending them to us .
Honda
Accord Executive
- B-74-***
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 7th May 2024 - 20:33 |
