Bad quality unleaded fuel, what to expect...
zorpetus |
5 May 2006, 08:42
Membru Group: Members Posts: 120 Joined: 17 April 06 |
None
None
- None
13nov |
5 May 2006, 09:40
Membru autentic Group: Members Posts: 260 Joined: 7 June 04 From: Bucuresti |
As you probably know, the same engine from Logan was first introduced by Dacia on the Supernova model, and from my experience with Supernova the fuel quality is important. Bad quality fuel used on common basis will affect your fuel-injectors and the catalityc convertor.
If you will use bad unleaded fuel once or twice I don't think that will have a major effect on how the engine will work during its life. But again it depends on how bad the fuel is. On the romanian side of the forum, a user, Liviu, had his engine jammed due to very poor quality fuel, so don't try your luck. This post has been edited by 13nov: 5 May 2006, 09:40 |
OPEL
ASTRA GTC 1.9 CDTI
2008 Clio III 1.5 dci Privilege
5 May 2006, 09:50
The engine is pretty tolerant to bad fuel.
Is not workink as its best, but i tolerant, because is simple. |
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 28th March 2024 - 12:47 |
