Logan 1 repeated misfire/vibration/stalling, Technical issue
Mark.gebel92 |
30 Aug 2018, 09:39
Membru incepator Group: Members Posts: 5 Joined: 30 August 18 |
Logan 1, 1.4mpi
30 Aug 2018, 10:32
fan Dacia Group: Members Posts: 19.920 Joined: 12 November 05 From: Bucuresti |
swicth between nr 4 fuel injector and nr 1 and see if fault follows the injector. Be carefull of orings when pulling injector out of the fuel rail. If fault switches to nr 1 cilinder, replace faulty injector. If not, check for mechanical issues (tight valve clearence, low compression) on nr 4
do you have LPG on it also? If so, some ecu parameters might us ea reset before anithing else. good luck |
Mark.gebel92 |
30 Aug 2018, 12:42
Hello,
Thank you very much for your reply. I appreciate it. I will try to see if the injector might be the problem. I considered doing this procedure before, but having no way of relieving pressure (unfortunately it is not clear to me which relay controls the fuel pump) from the fuel lines i somewhat gave this up. About LPG - the car has no LPG I will try to see if i can find a way to carry out this procedure and carry out your suggestion. Thank you This post has been edited by Mark.gebel92: 30 Aug 2018, 12:45 |
Logan 1, 1.4mpi
sorin1983 |
30 Aug 2018, 22:34
Membru autentic Group: Members Posts: 5.588 Joined: 3 July 06 From: Bucuresti-Rahova |
maybe it's the catalyst converter...
Megane1-
Mark.gebel92 |
31 Aug 2018, 11:02
Good Morning,
Thank you for your answer. I understand that the repeated misfiring might damage the catalytic converter, but how can a faulty cat affect the overall performance in this way. is it plausible? Also the rear end O2 sensor has been monitored quit closely by me. The voltage reading according to my information is good and it doesnt seem to me that (high amounts of) raw fuel is getting in there or anything that might damage the catalytic converters performance in any way. I might have to check this again as it has been a couple of months since i did this inspection. Personally, I think this is an injection problem overall. I think that the misfire is a lean misfire caused by a clogged or partially clogged fuel injector(s). When the misfire occurs and i read the freeze frame data from the OBS tool the fuel trims are showing lean mixture (negative) in all cases. When the engine is cold before the O2 sensor kick in i believe the ECU is programmed to apply a biased rich fuel mixture until it is in open loop. Since the injector might be clogged then it might be that not enough fuel is getting into the injectors, and therefore cyclinder, to keep the power in the car when load is relieved (stalling issue.) The shaking at idle/stopped could also be cause by a clogged injector relieved from load being shy and not spraying enough fuel into the cyclinder causing this shaking condition and causing the O2 sensor to go crazy while trying to adjust for this condition. It would be nice if someone could confirm my logic I have booked myself in for a inejctor check at a local mechanic and a thorough fuel system cleaning. I think that it is the best place to start as proposed by Einstein This post has been edited by Mark.gebel92: 31 Aug 2018, 11:03 |
Logan 1, 1.4mpi
MyKe89 |
31 Aug 2018, 11:08
Membru RFG Group: Members Posts: 3.013 Joined: 16 December 07 From: Bucuresti |
You have figured it out, kudos!, the clogged injector is also my guess.
'23 Honda
CR-V
e:HEV ‘23 Honda NC750XA
Mark.gebel92 |
31 Aug 2018, 12:16
Hello,
Thank you for your answer. I appreciate it. I will post something after the diagnose from the shop to update on whether the issue has been solved or not. Regards, |
Logan 1, 1.4mpi
Mark.gebel92 |
23 Sep 2019, 21:13
Good Evening,
Quick feedback on the issue below. Turned out that this was not an issue with the injectors in the first place. We brought the car to a mechanic who had experience with first generation renault engines and he immediately saw the issue that so many meganes and clios had before: VALVE MIS-ALIGNMENT!! The previous owners of the car never had had a proper service done to the car and the exhaust valves were completely out of standard. This was more pronounced when the engine was cold and repeated misfire + engine stalling occurred until the engine heated up to operating temperature and the metal components of the cylinders expanded just enough to make the problem disappear. The man popped open valve cover, calibrated the valves and that was it. Problem solved. If you are experiencing similar problems as the one we had the above is definitely something to keep in mind |
Logan 1, 1.4mpi
24 Sep 2019, 08:42
if the injector permutation turned out same result, that would have confirmed a mechanical problem so probably valves.
glad you solved it. |
Barrie |
29 Sep 2019, 06:47
Membru incepator Group: Members Posts: 42 Joined: 15 April 08 |
Try using a petrol with the least ethanol. Ethanol attracts humidity and so causes low temperature misfiring. It certainly helps with older vehicles.
Here in France, the 98 octane is best. Bon Chance, Barrie |
Logan MCV Diesel
- Not known yet
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 5th May 2024 - 00:10 |
