Referitor la boxe, diametru, etc.
BraescuTeo |
25 Jul 2005, 14:32
Membru incepator Group: Members Posts: 8 Joined: 25 July 05 |
Super-Nova
- B 33 JRE
dadu221 |
25 Jul 2005, 18:59
Membru autentic Group: Members Posts: 726 Joined: 11 March 04 From: Ploiesti |
15 w dar nu se stie cat de reali is . Diametrul alora de pe usi e de 14. pe spate n-am idee
DSN rapsodie
BraescuTeo |
26 Jul 2005, 16:56
mersi mult |
Super-Nova
- B 33 JRE
thunder |
26 Jul 2005, 20:50
Membru autentic Group: Members Posts: 540 Joined: 22 April 04 From: Pitesti |
Casul are ca amplificator integratul TA8276H facut de TOSHIBA si se pare ca are 35W pe canal, probabil 15-17W reali.
Pt. cine stie mai multa electronica atasez si datasheet-ul integratului: PS: pt. cei interesati, integratul are si intrare AUX This post has been edited by thunder: 26 Jul 2005, 20:55 Attached thumbnail(s) Picture_0041.jpg ( Size: 86.54k ) Number of downloads: 652 Attached File(s) TA8276H_datasheet___amplif_casetofon_original_DNS.pdf ( 249.66k ) Number of downloads: 210 |
Astra H
- B-50-WSE Doua lucruri sunt infinite: universul si prostia umana. Despre univers nu sunt inca sigur. Albert Einstein
m2b |
21 Aug 2005, 16:00
Membru incepator Group: Members Posts: 8 Joined: 17 August 05 |
QUOTE(dadu221 @ 25 Jul 2005, 19:59) Diametrul alora de pe usi e de 14. pe spate n-am idee Nu sunt cumva de 10cm? Vreau sa le schimb pe cele de pe fata la o srn, dar vreau sa investesc foarte mult in ele. Ceva ieftin si decent gasesc? Doar pentru fata, momentan. |
d
sn
- cucu
marianrec |
21 Aug 2005, 20:10
membru drept Group: Members Posts: 330 Joined: 30 March 04 From: Galati |
Recomand boxe cu diametrul cat mai mare, respectiv 16.5 cm.
This post has been edited by marianrec: 21 Aug 2005, 20:31 |
1990, 1994
- GL03WWT & GL07NAT bau
marianrec |
21 Aug 2005, 20:11
Exista boxe cu diametrul de: 10cm, 13cm, 16.5cm. Toate aceste boxe se pot monta la SRN. Totusi daca vrei upgrade.. recomand boxe cu diametrul cat mai mare, respectiv 16.5 cm.
This post has been edited by marianrec: 21 Aug 2005, 20:13 |
1990, 1994
BraescuTeo |
26 Sep 2005, 20:33
QUOTE(marianrec @ 21 Aug 2005, 20:11) Exista boxe cu diametrul de: 10cm, 13cm, 16.5cm. Toate aceste boxe se pot monta la SRN. Totusi daca vrei upgrade.. recomand boxe cu diametrul cat mai mare, respectiv 16.5 cm. am 2 boxe cu diametru de 16.5 cm.. 25W reali unde pot sa le montez ? in spate sau in fata? si trebuie facute ceva modificari ? |
Super-Nova
- B 33 JRE
thunder |
26 Sep 2005, 20:46
Multi au reusit sa bage difuzoare de 16.5 cm in usi, in locul celor originale, dar la mine nu au intrat (Sony Xplode), erau cu vreo 2-3 mm mai mari in diametru. Tipu de la Sony care mi le-a vandut a zis ca intra garantat, ca multi si-au pus. Dupa 2 luni cand am apucat sa le montez ... surpriza ... nu mergeu.
Incearca totusi sa faci o proba sa vezi daca intra, dar mai mult ca sigur trebuie scoasa din usa bucata aia de plastic care proteja difuzoarele vechi (un plastic negru, pus sa nu curga apa direct pe difuzoare, si de care sunt prinse difuzoarele originale), altfel nu intra difuzorul, are magnetul mai mare. Ar mai fi o problema cu capacul, daca poti sa-l pui pe cel original al masinii, daca nu, pe cel care vine cu difuzoarele, dar care sigur are mai mult de 16.5 cm in diametru (la mine aveau 18 capacele) ... si va lovii manivela de la geamuri in el. |
Astra H
marianrec |
26 Sep 2005, 22:09
Eu montez destul de des asa ceva si nu au fost probleme de genul: sunt mai mari cu 2 mm. Dimesnsiunile sunt standard. Daca vrei boxe de 16.5 trebuie sa te chinui mai mult dar rezultatul va fi pe masura efortului depus. Si intradevar la astea de 16,5 trebuie pusa plasa difuzorului, ni mai merge capacul ala original...
1990, 1994
thunder |
26 Sep 2005, 22:44
Cum prinzi difuzoarele de 16.5 pe usa ? Inca le mai am prin casa si ma gandesc sa le schimb. Eventual le pun si masca lor ... acum am geamuri electrice si deci am scapat de problema cu manivela.
Astra H
BraescuTeo |
13 Dec 2005, 19:56
1. Deci, am pus 2 boxe de 25W RMS in spatele masinii si am dus cablu pana in fata si pe cablu am pus un intrerupator care intrerupe unu din cabluri din cele 2 de la un difuzor (ca sa le pot inchide cand nu am nevoie de ele) si le-am probat, mergeau, le-am inchis si mergeau doar cele din portiere si a mers asa vreo o sapt pana cand nu mi se mai deschide casetofonul, poate fi de la ce am facut eu ? (o mers o sapt si ceva de cand am facut acest lucru)..
2. Acum nu mai pot deschide casetofonu.. am scos si cablurile de la boxele adaugate dar degeaba.. ce poate fi? ce sa fac? Multumesc.. |
Super-Nova
- B 33 JRE
13 Dec 2005, 23:11
Siguranta s-a verificat?
BlonduGL |
14 Dec 2005, 13:34
Membru incepator Group: Members Posts: 27 Joined: 18 May 05 |
QUOTE dar mai mult ca sigur trebuie scoasa din usa bucata aia de plastic care proteja difuzoarele vechi (un plastic negru, pus sa nu curga apa direct pe difuzoare, si de care sunt prinse difuzoarele originale) Are ceva daca e scos si nu l-am mai pus la loc? Ca mi-am schimbat de curand boxele pe fata, si la montaj mi-au scos plasticul ala negru. Boxele pe fata sunt de 13, asta ca raspuns pentru iniatiatorul threadului. |
SuperNova
- GL-xx-NRG
BraescuTeo |
14 Dec 2005, 20:07
mersi klaus
siguranta era arsa am inlocuit-o cu cea de rezerva, am pus codul si merge |
Super-Nova
- B 33 JRE
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 4th May 2024 - 04:28 |
