Amplasare detector radar, Clasificare eficienta - vizibilitate
fristei |
16 May 2006, 21:06
Membru incepator Group: Members Posts: 3 Joined: 16 May 06 |
Astra
sandman_ |
17 May 2006, 11:11
software engineer Group: Members Posts: 2.416 Joined: 20 June 05 From: Viena, Austria |
care este tetiera centrala stanga?
vroiai sa spui tetiera centrala spate? daca da, aceea e optiunea mea |
Megane 2(.1) C-C
Dinamique, 2.0 16v 136cp, 2005
- GJ-01-SSP Renault Laguna 3 2.0dCi, 150CP, 2008
and the best is still to come... |
zyppo |
17 May 2006, 11:28
Membru autentic Group: Members Posts: 207 Joined: 23 February 05 From: Bucuresti |
In curind il vei pune pe bord, fiindca se va da liber din toamna la detectoare.
Iar intr-un an, doi nu il vei mai pune deloc fiindca va fi total ineficient impotriva noilor sisteme de detectare video. |
Megan Sedan
2004 - 1.6 16v MEGANE II Sedan 1,6 16v - 2005.
Confort Privilege - Negru, Clima, ESP, Xenon. |
GoGu |
23 Apr 2007, 18:59
Prea de la tara Group: Moderatori Posts: 1.970 Joined: 14 August 03 From: Iasi |
De pe site-ul Beltronics, in legatura cu pozitia optima a detectorului:
QUOTE Positioning Detectors First rule of thumb: For RADAR, the higher the better. For LASER, the lower the better. We recommend placing the detector as low as possible. Laser is more difficult to detect than radar. With that said, as far as positioning the detector, you want to give the detector a clear field of view: front and rear. Avoid placing the detector behind the tinting at the top of most windows, or hidden behind parking stickers, wiper blades, or anything similar that will obstruct the detector's window or lens. We no longer include the visor mount with the detectors because most cars have tinting that will reduce the laser detection range. We also advise placing the detector where it will not obstruct your view. Concluzie: cum nu avem in Ro laser, atunci montati detectorul cat mai sus. Chestiile alea cu parbrizul colorat sus nu au nici o relevanta pt. detectia radar. This post has been edited by GoGu: 23 Apr 2007, 19:00 |
Scenic 1.5dCi
recolta 2012
l@u |
24 Apr 2007, 08:13
Membru autentic Group: Members Posts: 6.057 Joined: 31 July 06 |
Cred ca nici nu mai este interesat de topicul asta ca acus face un an asa ca ar fi mai bine sa fie sters.
Land Rover
Freelander
Td4, HSE
danchitu86 |
9 May 2007, 23:19
Membru cu BRB Group: Members Posts: 199 Joined: 24 September 05 From: Bucharest |
Eu as vrea sa aflu daca-l plasez pe un Logan in partea stanga pe bord, ce implicatii are? Problema ar fi ca daca il lipesc cu ventuzele de parbriz nu sta paralel pe drum si usor oblic. Ar fi o problema?
Logan 1.4 MPI
Albastru Marin
2005 Laureate People's problem is not that they are mortal, but that they are suddenly mortal...
l@u |
10 May 2007, 08:26
Pai cam are.... el se pune in centru si cat mai paralel cu drumul adica ca sa intelegi numarul masinii este principalul vizat de radar iar fascicolul este directionat catre numar iar daca detectorul tau bate in stele detectia este minimalizata ca sa spun asa.
Land Rover
Freelander
Td4, HSE
holograma |
10 May 2007, 12:22
Membru autentic Group: Members Posts: 437 Joined: 20 December 06 |
pune-l pe mijloc, usor spre dreapta, astfel incat sa "vada" printre stergatoare. este destul spatiu. coboara putin ochiul la nivelul bordului si vei gasi pozitia ideala.
bafta! This post has been edited by holograma: 10 May 2007, 12:22 |
2005 Laureate
GoGu |
10 May 2007, 12:24
La Laser se tinteste de obicei numarul sau farurile, radarul normal nu prea are cerinte dintr-astea.
Conditia principala ce trebuie indeplinita e ca planul "ferestrei" prin care detectorul "priveste" drumul sa fie perpendicular pe planul soselei, lucru care se regleaza prin indoirea tablitei-suport a detectorului (aia cu ventuze) in cazul in care nu exista un sistem de reglare (tip balama). Daca aceasta conditie e indeplinita, nu stiu daca are importanta daca detectorul e rotit in planul celalalt (era o discutie legata de polarizarea undelor diferitelor radare, ca ar fi benefica montarea verticala sau oblica a detectorului, insa cum nu cunosc polarizarea radarelor de pe la noi ma feresc sa comentez). |
Scenic 1.5dCi
recolta 2012
holograma |
10 May 2007, 12:35
montarea verticala? cred ca voiai sa spui orizontala. pai daca-l montez in pozitie verticala ce-mi mai detecteaza? comete?...
oricum, prin toate instructiunile pe care le-am citit este specificata (si desenata) instalarea paralela cu soseaua. drive safe! |
2005 Laureate
GoGu |
10 May 2007, 12:38
Verical, dar cu respectarea primei conditii pe care am enuntat-o (cu fatza la drum), adica rotit in jurul axei longitudinale.
Dar repet, nu stiu cum sunt polarizate radarele de la noi si nu stiu ce sa zic, daca ajuta sau nu (in particular sau in general, de fapt...). This post has been edited by GoGu: 10 May 2007, 12:39 |
Scenic 1.5dCi
recolta 2012
l@u |
10 May 2007, 14:02
Land Rover
Freelander
Td4, HSE
holograma |
11 May 2007, 12:49
ca sa aiba vedere libera printre stergatoare
2005 Laureate
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 19th April 2024 - 18:39 |
