Exporting a Logan MCV to United Kingdom, Changing the headlights to dip to the left
Colinr |
27 May 2010, 02:05
Membru incepator Group: Members Posts: 1 Joined: 27 May 10 |
Logan MCV
2007 Laureate Diesel
Fratzica |
27 May 2010, 02:33
Zen Group: Moderatori Posts: 2.912 Joined: 6 April 04 |
I don`t think Dacia manufactures left-hand drive models so I don`t see why it would supply such headlamp units.
Kia
Sportage
T-GDI 2021 "The happier we are, the less we see." - some japanese guy
variable_dynamics |
27 May 2010, 12:13
Membru autentic Group: Members Posts: 976 Joined: 24 May 07 From: Bucuresti |
Dacia-Renault DOES manufacture left-hand drive models in India(the joint-venture is called Mahindra-Renault and the car is Mahindra Renault Logan).
I presume Dacia could supply with special headlights. Try requesting more information via e-mail: vocea.clientului@daciagroup.com Best regards. |
EX Dacia
Nova GTi
GabrielD |
20 Jun 2010, 15:04
Membru incepator Group: Members Posts: 54 Joined: 31 May 09 From: Pitesti |
Hello!
I have just decided to register my Dacia Logan in UK. First I need to fit an extra tail fog lamp on the rear right side, fix the speedometer so that will show miles/hour and fit those headlights dipping to left. And some paperwork and payments aswell. The problem so far would be headlights. I have heard that some headlights of this kind are produced in Romania at Elba Timisoara factory. They are ment to be exported to India or South Africa, not sure, maybe they will fit Mahindra Logan. If anyone could help regarding this lead I would be very grateful. Thanks a lot! |
2006 LaureatePlus(ABS) 1.4 MPI
free_fiber |
22 Jun 2010, 13:40
Membru autentic Group: Members Posts: 1.555 Joined: 25 October 04 From: Bucuresti |
QUOTE(GabrielD @ 20 Jun 2010, 16:04) fix the speedometer so that will show miles/hour I think this is an easy task, you will have to rewrite a memory from inside the dashboard, so the soft will turn from 6002 into 6003. The trick works on other softs as well. |
Logan Laureate 1.5dci 85CP
- B xx XXX
GabrielD |
22 Jun 2010, 21:02
QUOTE(free_fiber @ 22 Jun 2010, 13:40) I think this is an easy task, you will have to rewrite a memory from inside the dashboard, so the soft will turn from 6002 into 6003. The trick works on other softs as well. Thank you! I would never thought about that! I was going to apply a sticker in mph on the existing speedometer. |
Maskatu |
24 Jun 2010, 14:06
QUOTE(free_fiber @ 22 Jun 2010, 14:40) I think this is an easy task, you will have to rewrite a memory from inside the dashboard, so the soft will turn from 6002 into 6003. The trick works on other softs as well. I think he is refering to the writings from the speedometer.... more exactly the 20,40,60,80,etc. marks.... he has to print a version that has miles and not km. When he drives the car and for example the speed limit is 30 miles/h, he will have to know that... and in order for the car to be registered, the car needs miles not km. I think the mahindra logan has headlamps for use in uk.... it also has right stearing. |
24 Jun 2010, 14:31
fan Dacia Group: Members Posts: 19.912 Joined: 12 November 05 From: Bucuresti |
There are part numbers for the headlights and tail lights available in the left hand drive specifications, any renault dealer can find them in selecting steering wheel on the right end technical country specifications TLAFSU (South africa) in Dialogys.
The problem lies with fact that even with the correct part numbers, the parts are not in stock in europe. I don't know if Renault can supply those parts over here. This post has been edited by einstein1984: 24 Jun 2010, 14:34 |
M.C. |
24 Jun 2010, 16:36
Membru autentic Group: Members Posts: 2.152 Joined: 24 January 04 From: Ploiesti ,din cind in cind. |
QUOTE(Maskatu @ 24 Jun 2010, 16:06) I think he is refering to the writings from the speedometer.... more exactly the 20,40,60,80,etc. marks.... he has to print a version that has miles and not km. When he drives the car and for example the speed limit is 30 miles/h, he will have to know that... and in order for the car to be registered, the car needs miles not km. This is the easiest way to solve the problem. It will be better if you can print out a sticker with both indications,i mean mph and km/h,for the speedometer. I have an Mercury Milan,american car,and on the speedometer i have both indications(mph and km/h ) Have a look on the attached photo,maybe it will inspire you. Regards. 2008_mercury_milan_4_door_sedan_3_0_instrument_cluster_100285900_m.jpg ( Size: 119.81k ) Number of downloads: 613 This post has been edited by M.C.: 24 Jun 2010, 16:42 |
Renault Megane
II Sedan Influence
GabrielD |
24 Jun 2010, 20:21
Thank you all very much for all your replies. I will try and follow your suggestions.
The main problem is still replacing the headlamps with Mahindra Logan ones. Have a thought on that, maybe you have some ideas. |
M.C. |
25 Jun 2010, 07:15
I don't know what to say.
I have an ideea,maybe it will work. If not,please do not be angry on me! Try to rotate a little to the left the bulbs onto the headlight support. In this way,the low beam fillament dipping direction it will change to the left. But for this job,you need to buy two new bulbs and to do some small modifications on that three pins that are fitted on the bulb flange,in order to have the freedom to change the bulb position on the headlight support. Regards. |
Renault Megane
II Sedan Influence
GabrielD |
6 Jul 2010, 14:12
http://www.elba.ro/index.php?option=com_fi...&id=5&lang=en#5
Follow this link regarding RHD Logan headlamps made in Romania. And Google translate: Hello, after our fellow consultarii at the Department of design we can say that mill at ELBA is on the left headlamp for circulation (for Logan actualface-elevator that is accomplished in South Africa). For variant India, headlamps and are completed echipeaza Loganul by Chevrolet, Phase1 Loganul are for. Now, for India is not circulating on the left uses the headlights of THE ELBE. |
copros |
21 Nov 2010, 18:25
Membru incepator Group: Members Posts: 7 Joined: 7 June 10 |
what special headlight are you looking for?try to find it on our website please. www.hid-copros.com
BMW
volvo
- 18765 www.hid-copros.com Profeestional on auto lighting such as hid kits,canbus ballast,led bulbs,canbus led bulbs,bixenon lens,daytime running light.
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 26th April 2024 - 15:25 |
