Cutie Viteze LOGAN - agata in a 2 -a, Problema Cutie viteze LOGAN
alxex |
21 Jun 2008, 01:22
Membru incepator Group: Members Posts: 7 Joined: 9 January 08 |
30 Dec. 2004
- CT 89 ALE
ArtVandelay |
21 Jun 2008, 01:30
Anytown, USA.. Group: Members Posts: 2.662 Joined: 5 January 08 From: Craiova |
focus
2001 He wondered why the boomerang kept getting bigger. Then, it hit him.
I got 99 cookiez cause a bitch ate one. |
alxex |
21 Jun 2008, 11:52
deci ????
30 Dec. 2004
- CT 89 ALE
AR-18-MOS |
21 Jun 2008, 12:44
Ai citit topicul din link?
BMW
730Ld
'07 High Executive
alxex |
21 Jun 2008, 16:36
da si nu am gasit ceva sa ma lamureasca .... la treapta 1 nu face probleme doar la a2-a ....
30 Dec. 2004
- CT 89 ALE
AR-18-MOS |
21 Jun 2008, 21:11
Obisnuiesti sa pleci in forta si sa dai "scartz" in a 2-a?
BMW
730Ld
'07 High Executive
roland |
22 Jun 2008, 14:01
Membru autentic Group: Members Posts: 2.704 Joined: 18 November 04 |
alxex |
22 Jun 2008, 14:56
roland: ma refer cand e motorul oprit ...
AR-18-MOS ... da am obiceiul sa plec tare si sa o scarta`i in a2-a ..... |
30 Dec. 2004
- CT 89 ALE
22 Jun 2008, 16:42
fan Dacia Group: Members Posts: 19.949 Joined: 12 November 05 From: Bucuresti |
Si atunci de ce te mai miri?
AR-18-MOS |
22 Jun 2008, 19:08
BMW
730Ld
'07 High Executive
BZN |
23 Jun 2008, 12:50
Itan convins Group: Members Posts: 3.590 Joined: 29 January 08 From: Rucar / Bucuresti |
QUOTE(AR-18-MOS @ 22 Jun 2008, 20:08) Stai putin, daca conduci nitel mai sportiv , asta dauneaza in asa masura cutiei de viteze? Sa clarificam, asta la un mers alert, daca insa "carai" cutia - alta treaba, atunci inteleg. Sa nu fiu inteles gresit ,si fara sa ma laud, eu conduc des in forta dar precis, asa am facut cu toate masinile pe care le-am avut ,fara probleme. |
Tico 0,796 6v, 1998
/Logan 1,598 16v, 2009
- AGXXMAV / AGXXVAB
ProMotor |
24 Jun 2008, 04:25
Membru autentic Group: Members Posts: 210 Joined: 30 November 07 |
Las-o mai moale ca nu e masina "de forta" si poate te va tine mai mult si nu va mai agata. Cei care conduc sportiv isi asuma si reparatiile mai dese si consumurile mai mari.
Logan ABS Plus
AR-18-MOS |
24 Jun 2008, 09:55
QUOTE(BZN @ 23 Jun 2008, 12:50) Stai putin, daca conduci nitel mai sportiv , asta dauneaza in asa masura cutiei de viteze? Sa clarificam, asta la un mers alert, daca insa "carai" cutia - alta treaba, atunci inteleg. Sa nu fiu inteles gresit ,si fara sa ma laud, eu conduc des in forta dar precis, asa am facut cu toate masinile pe care le-am avut ,fara probleme. "Nitel" mai sportiv nudauneaza asa grav cutiei, dar deja, cand in repetate randuri la schimbarea treptei de viteza din 1->2 si cauciucurile sa piarda aderenta, deja cutia e foarte solicitata. |
BMW
730Ld
'07 High Executive
alxex |
24 Jun 2008, 14:18
da, conduc sportiv si mai agresiv.... dar nu bag in viteza in asa fel incat sa caraie sau ceva de genu ... am foarte mare grija la schibmarile de viteza ...
30 Dec. 2004
- CT 89 ALE
cosminwon |
24 Jun 2008, 18:54
Membru Group: Members Posts: 149 Joined: 6 December 06 |
Alxex!!!Problema este ca nu tu esti de vina!!!Mai esti in garantie?Eu lucrez la reprezentanta Dacia si cu ceva timp inapoi am avut si eu un Logan (cumparat de nou) care avea aceeasi problema ca si al tau!Solutia a fost sa umblu in cutie!!Tin sa mentionez ca mie mi-a facut de cand l-am scos pe poarta service-ului.In ultimul timp sunt mari probleme cu cutiile de viteze,planetare,simeringuri la priza,etc!!!Ai 2 variante:sa-l vinzi sau sa repari cutia!!La treapta a2a eu am schimbat:manson;sincron;pinion a2a,iar numai piesele s-au ridicat la vreo 380 euro,asta fara manopera!!!Daca mai ai vreo nelamurire,iti las id-ul meu de mess cosminwon
masina de cacat
de n-as fi mai avut-o
uyry
iicy99 |
27 Jun 2008, 18:02
Membru incepator Group: Members Posts: 5 Joined: 20 May 08 |
Salut!
Am si eu un logan 1,5 dci si am avut si eu probleme de genul: simteam o agatatura la bagarea in treptele 1 si 3. Am intrebat in stanga si in dreapta dar nu am aflat nici un raspuns, dar raspunsul a venit singur. Dupa cam 2000 km s-a rupt un cablu de la schimbator. Cu schimbarea acelui cablu am rezolvat problema, acum intra fora probleme in toate treptele de viteza si pe deasupra am mai rezolvat o problema a schimbatorului. Dupa introducerea manetei in treapta a 4-a, daca puneam mana pe schimbator avea o toleranta de vreo 3-4 cm catre inapoi (frana de mana), cred ca din cauza cablului slabit. acum nu mai am probleme de genul asta. |
2007 ABS plus
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 11th May 2024 - 04:59 |
