Stuck CD!, AHHH! My son has 'doubled up'!
chippydave |
13 May 2015, 21:28
Membru incepator Group: Members Posts: 1 Joined: 13 May 15 |
Logan MCV
2015
marksman |
17 May 2015, 17:36
Post mortem nihil est Group: Members Posts: 7.464 Joined: 1 November 04 From: sat |
It's weird how the 2nd disc was accepted in the 1st place. I've tried to do this myself on a unit which refused to eject the disc so it was compromised anyway but there is some mechanical protection as the the disc would go in only about 1/3rd.
My advice to you is to remove the unit from the dashboard and dismantle it as the 2nd disc might have found its way above the CD mechanism and into the way out of the 1st disc which is inside. As you try to eject the disc inside, it will be blocked by the 2nd disc and reinserted. Make sure you have the unit's security code handy as you will need to pull the plugs out to get the unit removed and dismantled. This will VOID your warranty. |
Opel / Mazda
Crossland X / CX-30
2019 / 2020 Charlie Foxtrot
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 27th April 2024 - 03:25 |
