turatie mica la relanti, 500 rot/min
hurmuzs |
23 Feb 2010, 18:55
Membru incepator Group: Members Posts: 3 Joined: 6 January 10 |
Logan 1.4 Mpi
boobybooby23 |
23 Feb 2010, 19:56
Membru autentic Group: Members Posts: 713 Joined: 3 January 09 |
1,e motoru cald
2.eu unu nu as da mare importanta la turometru asa ca stai calm |
LS0A
2005,stock
- nt 05 zac
dan supernova |
23 Feb 2010, 21:22
Membru autentic Group: Members Posts: 754 Joined: 20 April 09 From: Bucuresti |
1 .curata senzoru de turatie
2 .curata si mototrasul pas cu pas (mpp) si ar trebui sa it imearga brici dupa ce le curete |
Dacia /Renault
Supernova clima & Clio
Supernova (2002) & Clio (2005)
- B-902-DAN
bobo77 |
23 Feb 2010, 22:01
........................... Group: Members Posts: 7.213 Joined: 27 January 06 From: Mangalia |
Sigur stii sa citesti corect turometrul? nu vreau sa te jignesc dar am mai vazut cazuri...
Laureate 1,6 mpi
2008 ph 2
Ionut Stoica |
24 Feb 2010, 20:20
Membru incepator Group: Members Posts: 9 Joined: 14 February 10 |
La mine asa sta mereu, din fabrica este asa dar s pare ca turatiile nu pornesc exact de la 0 asa ca mai adaugi la turatia indicata inca vreo 100-150 de rotatii deci sta pe undeve pe la 650 rot/min. ceea ce e bine dupa parerea mea... plus ca sigur nu sta exact la 500 deci intre 650 si 700 este normal....
1.4 mpi ambition 2006 verde camleon
- bz 10 ***
robbie_ro |
24 Feb 2010, 21:33
----------------------- Group: Members Posts: 459 Joined: 25 June 07 |
1. Porneste de la 500 rot/min.
2. Acolo unde se crede ca-s 500 rot/min sunt de fapt 750 rot/min 3. S-a mai discutat si ras-discutat, cautati pe forum. This post has been edited by robbie_ro: 24 Feb 2010, 21:34 |
2007, Laureate Plus
adrianos787 |
9 Mar 2010, 15:11
Membru incepator Group: Members Posts: 53 Joined: 25 January 09 From: ARAD |
buna.eu am probleme cu trpidatiile la relanti, acul de la turometru ascileaza si masina tremura putin.adica intre 700-900 .am schimbat bujiile,am curatat mpp si tot degeaba .ce e de facut???
renault
19 chamade
1990 1721cc multipunct
- AR 24 RDN
9 Mar 2010, 15:18
reglat culbutorii ai incercat?
roland |
9 Mar 2010, 15:54
Membru autentic Group: Members Posts: 2.704 Joined: 18 November 04 |
apropo de culbutori, o intrebare...
cum iti dai seama ca trebuie reglati? adica, daca sunt prea stransi stiu ca trepideaza motorul la relanti, am patit-o pe Dacia 1310 injectata. daca sunt prea largi (daca pot sa ma exprim asa), ar trebui sa tacane, nu? la Logan, se aude un usor tacanit care provine de la injectoare, se aude la o anumita turatie inainte de a fi acoperit de sunetul motorului turat, chestie normala (cred si sper). cum stii cand tacane de la culbutori prost reglati? |
roland |
1 Apr 2010, 11:53
Anyone?
1 Apr 2010, 12:05
fan Dacia Group: Members Posts: 19.908 Joined: 12 November 05 From: Bucuresti |
Cand pui lera intre culbutor si suapapa e jocul prea mare. Si ralantul instabil... sau lipsa de puetre.
roland |
1 Apr 2010, 14:22
multumesc. intrebam in ideea de a nu desface capacul. deci relanti instabil.
danut.ditoiu |
24 May 2014, 17:39
Membru incepator Group: Members Posts: 7 Joined: 17 May 14 |
ok.ms de raspunsuri
2005 1.4
cd06 |
11 Oct 2014, 08:11
Membru incepator Group: Members Posts: 25 Joined: 11 October 14 |
Dar trepideaza?
none
none
2014
2xGI |
21 Oct 2018, 13:35
Membru autentic Group: Members Posts: 993 Joined: 24 October 08 From: Bucuresti |
E corect acest relanti? Logan 1.4 2005
Mie îmi pare cam mic. Același motor de 1.4 la alt logan 2008 are relantiul la prima linie de sub 1000. Care din relantiuri e cel corect ? Attached thumbnail(s) 20181021_141746.jpg ( Size: 2.13mb ) Number of downloads: 331 |
ex. Dacia
1978
- momentan Treanta 2 niciodata sa nu spui niciodata
MuciX |
21 Oct 2018, 14:19
Daca te uiti atent, prima linie groasa e echivalentul a 500 rpm, deci ce iti indica tie e 750 rpm.
2xGI |
21 Oct 2018, 17:52
Corect, dar mie totusi mi se pare cam mic ( sau asta e relantiul corect ? ). La cealalta masina parca merge mai rotund motorul cu relantiul mai sus ( prima linie de sub 1000 ).
Se poate face cumva sa se mareasca relantiul ? This post has been edited by 2xGI: 21 Oct 2018, 17:54 |
ex. Dacia
1978
tatabobu |
22 Oct 2018, 08:32
membru Group: Members Posts: 4.528 Joined: 14 September 04 From: Bucuresti |
Da' esti sigur ca ambele turometre sunt calibrate identic? De corect nu intreb
2xGI |
23 Oct 2018, 09:36
Da, corect, calibrarea . Mama ei de calibrare de unde sa știu dacă sunt la fel de calibrarte
Cert este ca motorul ăla cu relantiul mai sus se aude mai frumos, și merge mai rotund. |
ex. Dacia
1978
flavyus1987 |
29 Dec 2019, 10:17
Membru incepator Group: Members Posts: 43 Joined: 31 May 15 |
Am intalnit problema aceasta in special la motoarele de 1.4 cu gaz.dar se manifesta și cand merg pe benzina.Se observa o mica trepidatie sau ca și cum ar da rateuri mici pe evacuare.Motorul trepideaza usor,schimbatorul de viteze la fel.
O mica îmbunătățire a adus reglajul distanței rachetelor. În bord acul stând la 600rpm cand de fapt pe teste media era 750rpm, tirania oscilând 745~761rpm. Într-un final am mărit turatia din tester cu 50rpm adică la 800rpm, pe tester oscilând între 791~805rpm.oscilatia aceasta este un lucru normal la toate masinile. Rezultatul a fost foarte satisfăcător.plecarea de pe loc s-a îmbunătățit atat pe gaz cat si pe benzina.iar motorul nu mai trepida. În ambele setări motoarele verificate nu dădeau rateuri, dar era enervantă trepidatia la turatia de 750rpm. Consumul instant la relanti , pe tester, cu setarea la 800rpm apa la 83grC și 4grC afara, era aproximat la 0.93L/h.cu setarea de 750rpm nu am verificat consumul la relanti. Sper sa va ajute informatiile de mai sus. |
1989
- CT-05-SZL
kommodore_ss |
4 Jan 2020, 10:53
Membru Group: Members Posts: 108 Joined: 26 July 17 |
QUOTE(einstein1984 @ 1 Apr 2010, 12:05) Cand pui lera intre culbutor si suapapa e jocul prea mare. Si ralantul instabil... sau lipsa de puetre. Eu am 1.5 dci si aud țăcănitul ăla când motorul e rece , metalic doar la o anumită turație in sarcina moderata. Relanti cam instabil. Nu prea mă pricep tehnic. Daca as vrea un reglaj ce trebuie sa zic la service? |
RazvanF |
9 Jan 2020, 06:44
Tech Group: Members Posts: 2.284 Joined: 25 March 14 |
Logan MCV Stepway X52
9 Jan 2020, 09:25
la K9K zgomotul e mai degraba d ela injectoare
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 25th April 2024 - 13:42 |
