ce ulei de motor folositi?, pentru motoarele de logan pe benzina
Adrian78 |
5 May 2007, 10:55
#151
Membru autentic Group: Members Posts: 816 Joined: 24 April 06 From: Bucuresti |
Logan Laureate
1.6
Kojak |
5 May 2007, 19:21
#152
Membru autentic Group: Members Posts: 1.786 Joined: 18 January 07 From: Bucuresti |
Azi am schimbat uleiul cu ocazia reviziei de 15000Km: "elf excellium ldx 5W40", ulei full sintetic.
daciafan |
5 May 2007, 19:27
#153
/ Group: Members Posts: 1.670 Joined: 20 January 05 |
acum (13500) am mobil 1 dar la 15 000 voi pune castrol softec 5w 40 (sper ca e mai bun ca primul)
Kojak |
5 May 2007, 19:48
#154
@daciafan:
e full sintetic? |
dadu221 |
5 May 2007, 22:16
#155
Membru autentic Group: Members Posts: 726 Joined: 11 March 04 From: Ploiesti |
e cineva care a folosit si elf si havoline sau valvoline ca sa poata face o comparatie ca as fi curios de un elf si n-as vrea sa schimb uleiul degeaba.
DSN rapsodie
YRX |
6 May 2007, 07:43
#156
Membru autentic Group: Members Posts: 4.739 Joined: 6 July 06 From: Bucuresti |
@Adrian78
Si uleiurile 5w50 si 10w60 au aprobari ale producatorilor. Am gasit fisele tehnice de la Castrol care spun urmatoarele: Castrol Syntec 5w50: Exceeds all car and light truck manufacturer's warranty requirements for the protection of gasoline, diesel and turbo charged engines where API SM, SL, SJ, SH, CF or CD is recommended. Exceeds European ACEA: A3, B3, B4; Ford WSS-M2C931-A and the engine protection requirements of GM 4718M, ILSAC GF-4 for API Certified Gas line Engine Oils. Castrol Edge 10w60: Delivers performance that has been designed especially for the BMW M-series. High degree of engine protection at elevated high and low temperatures. Fully synthetic technology. Specifications / Performance BMW approval for M series and Z8 models. API SJ/CF |
2005 Ambition 1.6 MPI
Ciumpalac |
6 May 2007, 16:59
#157
membru in devenire Group: Members Posts: 26 Joined: 31 October 06 |
Personal, m-am oprit asupra unui Aral Megatronic 5w50...l-am "ochit" in Selgros, bafta si voua la alegere...
This post has been edited by Ciumpalac: 6 May 2007, 17:01 |
1,6 Laureat
Corbu' |
6 May 2007, 22:13
#158
Membru autentic Group: Members Posts: 763 Joined: 6 August 05 From: Canada |
daciafan |
6 May 2007, 22:14
#159
Adrian78 |
7 May 2007, 07:58
#160
Eu am observat ca acest ulei Castrol Softec 5W40 se gaseste numai in "locatii selecte" pe cand Castrol GTD Magnatec 5W40 (echivalentul pentru motoare diesel) se gaseste peste tot. De ce oare?
Logan Laureate
1.6
Corbu' |
7 May 2007, 16:49
#161
Locatii selecte ? Pai il gasesti in Metro si parca era si prin Real. Cam 160 RON bidon de 4L.
Adrian78 |
8 May 2007, 08:33
#162
Metro si atat ! In Bucuresti nu avem Real. Cam putin ... In Carrefour, Cora, Auchan, Praktiker si alte magazine mai mari sau mai mici nu exista. Deci?
Logan Laureate
1.6
madhorsefuzzy |
8 May 2007, 09:12
#163
Membru Group: Members Posts: 4.193 Joined: 9 May 05 From: Bucuresti |
QUOTE(Corbu' @ 6 May 2007, 22:13) QUOTE(daciafan @ 6 May 2007, 22:14) O rugaminte: accesati pagina asta, mergeti in sectiunea "Range of products" din josul paginii, accesati link-ul Engine si cititi in pagina pop-up care se deschide ce scrie in dreptul Excellium 0w40 si in dreptul Excellium LDX 5w40 la Description. Apoi veniti pe topic si spuneti-ne si noua la care declara elf "100% synthetic oil " si la care "using ELF synthetics technology". |
Laguna Grandtour
2011 4Control 2.0dci
8 May 2007, 09:59
#164
daciafan |
8 May 2007, 10:26
#165
QUOTE(madhorsefuzzy @ 8 May 2007, 09:12) O rugaminte: accesati pagina asta, mergeti in sectiunea "Range of products" din josul paginii, accesati link-ul Engine si cititi in pagina pop-up care se deschide ce scrie in dreptul Excellium 0w40 si in dreptul Excellium LDX 5w40 la Description. Apoi veniti pe topic si spuneti-ne si noua la care declara elf "100% synthetic oil " si la care "using ELF synthetics technology". am o rugaminte...inainte de ne cere noua sa ne informam, informeaza-te tu. noi vorbeam despre castrol softec 5w 40 care este fara doar si poate sintetic. |
madhorsefuzzy |
8 May 2007, 12:11
#166
Scuze. M-am uitat aiurea. Bafta!
Laguna Grandtour
tuneam |
8 May 2007, 16:22
#167
Membru autentic Group: Members Posts: 852 Joined: 1 March 04 From: Bucuresti |
Salut
Azi am facut schimbul de ulei la Prestige. Am 7600 KM, mers mult in Buc, drumuri scurte. Am pus Elf 5w-40 LDX. Problema e ca cei de la service mi-au zis sa vin cu 4L de ulei. Am luat de la metro 1 bidon de 4L si m-am prezentat la Dacoserv. Au pus baietii 4L de ulei, si l-au scurs pe cel vechi in bidonul in care era cel nou. Din fabrica masina avea aprope 4 L. La plecare mesterul mi-a zis, ca ar fi bine sa mai pun 0.5L de ulei pentru ca in carte scrie ca intra 4.6L(a scrie, am verif), dar la nivelul de pe joja sunt la 0.5 cm de limita maxima si la vreo 2 cm de lim inf. Credeti ca chiar tb sa mai pun 0.5L ulei? Multumesc |
Renault/Ford
Clio IV
2014
- bucuresti
ThunderRa |
8 May 2007, 19:31
#168
posesor posedat Group: Members Posts: 412 Joined: 8 April 05 From: Piatra Neamt |
Nu trebuie sa mai pui daca ai verificat nivelul corect: ( motor rece, masina pe o suprafata plana )
Megane Sedan 2.2
2008 - Lux Privilege 1.6 16v
- NT-23-DAC Dacia MCV Laureat 1.6 16v recolta 2007
http://radunastasa.com |
Kojak |
8 May 2007, 19:39
#169
@tuneam:
fii mai explicit, nivelul uleiului masurat pe joja e SUB nivelul maxim sau PESTE nivelul maxim. Ia nivelul maxim ca reper, sau cel minim, dar nu pe amandoua...ca sa pricepem si noi cum stau treburile... |
crising |
8 May 2007, 21:17
#170
Membru autentic Group: Members Posts: 787 Joined: 16 December 06 From: Danube Delta Gates |
Parerea mea e ca nu ti-au lasat sa se scurga bine uleiul vechi.
In cartea tehnica scrie ca la prestige volumul de ulei (cu schimbarea filtrului) este 4,8L. Te sfatuiesc totusi sa verifici totusi niveul de ulei cu motor rece si pe o suprafata perfect plana. |
Mazda
6
2011 Combi 2.0
- TL31...
Kojak |
8 May 2007, 21:22
#171
Corect, dimineata, inainte sa pleci "in cursa" e de preferat.
Sau si cand e motorul cald dupa 15-20min. cu masina parcata (oprita), cum spuneau si colegii forumisti, pe o suprafata aproximativ plana (ptr. ca perfect plana, nu prea gasim) |
xtremepwa |
9 May 2007, 20:51
#172
Membru incepator Group: Members Posts: 5 Joined: 24 April 07 |
Gama de uleiuri ELF care este acum pe piata nu mai este ce era inainte, asa ca eu unu nu recomand uleiul elf, asta daca vrei sa duci motorul in cateva sute de mii de km.
SuperNova
2002/Clima
- CT-77-CDA
blackout |
9 May 2007, 21:17
#173
Membru autentic Group: Members Posts: 218 Joined: 15 October 05 |
Deci uleiul Elf e prost, DaciaOil e catastrofa, Aral, daca nu scrie pe el "Made in Germany" nu e bun, Mobil daca nu e Mobil 1 si nu e din sursa sigura iarasi nu e bun, Castrol parca mai merge, dar nici asta 100%.
Recomand ulei de la...bunica. P.S. Uleiul de la bunica nuu e bun pentru cei ce vor sa tina masina peste 200.000km!!! In ritmul meu si al multora de pe aici asta ar insemna vreo ...20 de ani |
- BN-##-###
Corbu' |
9 May 2007, 21:36
#174
blackout ai prins exact esenta topicului asta. Mai bine zis concluzia la care se va ajunge dupa inca multe pagini.
tuneam |
9 May 2007, 22:44
#175
Nivelul a fost verificat in service cu masina jos, pe supr. plana. Motorul cald. Ulei-ul vechi a fost lasat sa curga 15 min, pe ceas.
Nivelul uleiului nou e la 0.5 cm mai jos de lim. max. Cei de la service au aprobat uleiul adus de mine.Filtrul l-am luat de la ei. E acelasi filtru ca pe orice DSN/SZN/Logan pe benzina. Costa 18 RONI la Dacoserv. ATENTIE la acritura de l amagazin. NU am vazut o vanzatoare mai acra in viata mea. |
Renault/Ford
Clio IV
2014
- bucuresti
daciafan |
29 May 2007, 07:58
#176
$$ilvviu |
29 May 2007, 08:08
#177
Membru autentic Group: Members Posts: 5.882 Joined: 6 January 07 From: Roman/NT |
Tocmai am cumparat Castrol 5W30 din magazinul de piese auto de la coltul blocului. Bidonul de 4 L 148 lei.
Initiale 2002
KilleR82 |
29 May 2007, 10:34
#178
Membru incepator Group: Members Posts: 42 Joined: 2 November 06 From: Cluj-Napoca |
La prima revizie mi s-a oferit Mobil 1 ca alternativa la Dacia Oil.
Am ales Mobil 1, 0W40. A fost 400 mii litrul la Dacia Feleac Cluj. N-am vrut sa mai discut cu ei sa imi aduc eu uleiul. Oricum am iesit cu revizia mai ieftin decat la multe alte masini. Uleiul arata bine acum, dupa 3,000 km. Ramane de vazut. Oricum, nu cred ca se compara cu Dacia Oil. |
Megane mk2 ph2
2008 1.6 16v K4M Euro4 Privilege (2008-) + GPL Dacia Duster 4x4 mk1 ph2 2015 1.6 16v K4M Euro5 Laureate (2015-)
29 May 2007, 10:38
#179
- Group: Members Posts: 21.859 Joined: 19 April 05 From: Romania |
Oricum la 3000km nu trebuie sa se schimbe culoarea prea mult.
KilleR82 |
29 May 2007, 11:44
#180
IRONICK, ai dreptate, si cel "original" arata bine la 3000 km , dar la 7000 km cand m-am hotarat sa il schimb, deja era "bronzat"
Bine, doar pe la 9000 l-am schimbat, din diverse motive (in special lipsa de "timp") O sa urmaresc uleiul vara asta, sa vad cum se prezinta (masina mea e din octombrie 2006 si nu prea a vazut calduri mari, cum se prevad in aceasta vara) |
Megane mk2 ph2
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 11th May 2024 - 05:46 |
