montare detector radar unde si cum?, acum este legal...
GoGu |
20 Feb 2007, 08:24
#61
Prea de la tara Group: Moderatori Posts: 1.970 Joined: 14 August 03 From: Iasi |
Scenic 1.5dCi
recolta 2012
l@u |
21 Feb 2007, 19:42
#62
Membru autentic Group: Members Posts: 6.057 Joined: 31 July 06 |
QUOTE(kAndrei @ 16 Feb 2007, 07:57) Scuze dar am fost foarte ocupat.....Ptr + am indoit capatul acela de circuit in care am infipt un papuc iar ptr.- am cositorit un alt papuc . Mai atasez o poza din lateral ca sa-ti dai seama mai bine unde se cositoreste papucul de -. Pe+ am pus o siguranta de 2A.Daca nu intelegi am sa caut sa fac poze mai clare . This post has been edited by l@u: 21 Feb 2007, 19:45 Attached thumbnail(s) Plafoniera.jpg ( Size: 117.98k ) Number of downloads: 1152 Papuc__.jpg ( Size: 86.72k ) Number of downloads: 1182 |
Land Rover
Freelander
Td4, HSE
DomnulK |
22 Feb 2007, 01:10
#63
ex kAndrei Group: Members Posts: 1.403 Joined: 7 September 03 From: Bucuresti |
ar fi utile niste poze mai clare...nu inteleg nimic din astea, oricum iti multumesc!
oricum eu as vrea sa ma leg direct de fire, nu de plafoniera...mai utila mi-ar fi o schema electrica...sau un cod de culori pentru firele de la plafoniera.... Multumesc anticipat! This post has been edited by kAndrei: 22 Feb 2007, 03:43 |
Laureate 1.6 MPI
2004 Asfalt Uscat!
l@u |
22 Feb 2007, 09:16
#64
Hai ca incerc sa-ti dau un cod al culorilor de la plafoniera dar sa stii ca e f. greu sa te legi in mufa aceea.
EDIT: Revin.... mufa: fir rosu + fir negru - fir alb comanda temporizare UCH Desfa plafoniera si cu ea si cu poza in fata ai sa-ti dai seama de legaturi This post has been edited by l@u: 22 Feb 2007, 09:45 Attached thumbnail(s) XXX.jpg ( Size: 99.17k ) Number of downloads: 1152 |
Land Rover
Freelander
Td4, HSE
Fygaro |
16 Mar 2007, 13:45
#65
Membru autentic Group: Members Posts: 214 Joined: 11 July 05 |
Poza mai clara domnul meu
This post has been edited by Fygaro: 16 Mar 2007, 13:48 |
Fiat
Punto
2003 1,2 16V 80Bhp
- RMS
l@u |
16 Mar 2007, 15:32
#66
Nu pot sa o fac cu telefonul mai clara spune ce nu intelegi si iti explic
Land Rover
Freelander
Td4, HSE
DomnulK |
17 Mar 2007, 01:06
#67
plafoniera ta e cea cu doua becuri...sau cea cu un singur bec? ca am desfacut plafoniera...
Laureate 1.6 MPI
2004 Asfalt Uscat!
l@u |
17 Mar 2007, 11:58
#68
Acea cu doua becuri
PS mai incerc inca o poza! This post has been edited by l@u: 17 Mar 2007, 11:59 |
Land Rover
Freelander
Td4, HSE
DomnulK |
17 Mar 2007, 13:22
#69
lau
de unde esti? am vazut, din GL... This post has been edited by kAndrei: 17 Mar 2007, 14:20 |
Laureate 1.6 MPI
2004 Asfalt Uscat!
l@u |
17 Mar 2007, 13:47
#70
Pai nu scrie acolo From:......???
Nu pot sa fac poze mai clare cu telefonul am incercat si cu zoom dar degeaba |
Land Rover
Freelander
Td4, HSE
calinutz |
20 Mar 2007, 23:34
#71
Membru incepator Group: Members Posts: 19 Joined: 1 June 06 From: Oradea |
Cum pot verifica un detector de radar daca mai functioneaza sau nu?
Am un whistler 1732 si cind era nou striga pe linga fiecare benzinarie sau magazin cu usi glisante automate. Acuma am serioase dubii asupra functionarii lui pt. ca nu l-am mai auzit sa reactioneze niciodata de vreo 2 luni, nici macar cind era radaru la sosea . Cei drept ca nici nu ma oprit nimeni . Aparatul sta prins pe parbriz la 10 cm deasupra bordului. Toata iarna am mers cu dezaburirea pornita si poate ca aerul cald care iesea deasupra bordului sub el ia facut felul, cred. |
Dacia,Logan,Clio
1300,Laureate,Simbol
1980,2004,2006
- BH04_ _ _ BH08_ _ _ motorul merge bine dar are probleme cu piesa dintre volan si pedale
l@u |
21 Mar 2007, 09:58
#72
Deschide toate benzile ,da-l pe highway si du-te pe la benzinarii ca trebuie sa dea vre un semn ceva sau mai vezi la cei ce vand detectoare ca unii mai au tot felul de chestii de incercat detectoarele radar.Bafta!
Land Rover
Freelander
Td4, HSE
tedy |
10 May 2007, 17:08
#73
Membru Indoctrinat Loganist Group: Members Posts: 580 Joined: 7 July 05 From: Bucuresti |
QUOTE(paulp @ 22 Jan 2007, 12:09) Eu, incepind cu data de 01.12-2006 l-am scos de deasupra oglinzii, si l-am postat drept in mijlocul parbrizului. Cine m-a vazut in trafic poate confirma ca merg asa cu el, de-al dracu La inceput s-a uitat Garcea cam crucis la mine, inclusiv cei de la radare, dar cum merg si cu o copie dupa Codul Rutier dupa mine si cu tupeu cit cuprinde, nu am avut nici un fel de probleme. Si radarele le iau de pe la 2-3 km De cand l-ai coborat ai sesizat cumva vreo diferenta?Sau binganeste la fel ca inainte? multumesc |
VW
bettle
1.9 tdi
- xxx
C@talin |
6 Jun 2007, 12:18
#74
Gata si eu cu alimentarea de la plafoniera,multumita schemei lui l@u,oricumprima oara gresisem pusesem pe minusul de la uch si cand se inchidea palfoniera se inchidea si detectoru
A daca va zic din ce am facut carcasa de la siguranta ptr ca la nici un amgazin nu am gasit,doar la unu dar era ptr sigurante mici,am confectionat una dintr-un capac de pix deci sa nu radeti prea tare .Oricum merge tipla |
Range Rover
V8 5.0
Vogue SE
Laurentziu83 |
6 Jun 2007, 12:25
#75
Membru autentic Group: Members Posts: 7.588 Joined: 17 May 05 From: Tziganistan |
Eu inca n-am pus siguranta la al meu (pe clio si pe dacie e alimentat prin cablu telefonic, doar la VW folosesc cablul original cu siguranta pe stecher), dar cred ca poti lua una de la vreo alimentare de casetofon auto, au toate.
This post has been edited by Laurentziu83: 6 Jun 2007, 12:27 |
C@talin |
6 Jun 2007, 12:44
#76
E siguranta originala pe cablu + cum e in poza lui l@u in alt topic.numai ca am confectionat carcasa ei dintr-un capac de pix
Range Rover
V8 5.0
Vogue SE
GoGu |
6 Jun 2007, 12:55
#77
Pai cumpara un soclu si o alta siguranta (rapida, de 2 A, poti sa mai iei una, de rezerva), te costa impreuna 1-2 ron...
Scenic 1.5dCi
recolta 2012
C@talin |
6 Jun 2007, 12:59
#78
Am cauta un soclu prin toata braila,mai mult am consumat benzina degeaba,si am gasit doar soclu ptr siguranta mica ,soclu ptr dasta mare nu avea,am intrebat porma da aveti siguranta dasta model mic da de 2 A,cica nu exista .oricum eu nu prea am auzit la nimeni sa se arda siguranta pana acuma si stiu oameni cu detector de 3 ani care nau nimic la el
Range Rover
V8 5.0
Vogue SE
Laurentziu83 |
6 Jun 2007, 13:02
#79
Intreaba prin cunostinte daca n-au vreun casetofon auto mai vechi (si domotec la 15 lei e bun), ca sigur au siguranta cu soclu pe alimentare.
Aveam eu una, da costa mai mult deranjul. N-ai gasit nici un magazin gen "Dioda"? This post has been edited by Laurentziu83: 6 Jun 2007, 13:05 |
C@talin |
6 Jun 2007, 13:17
#80
LA dioda am gasit doar dalea mici ,si pe la astia cu casurile stiau de ce vorbesc da nu aveau
Oricum uite poze 2 carcasa de la siguranta unde e si siguranta 6 Jun 2007, 13:30: Sorry de calitatea pozelor acum am vazut ca,camera era data pe manual focus 6 Jun 2007, 14:45: Are ceva daca pui siguranta de 2.5 A in loc de 2A ? Ca am facut o mica greseala si sa ars siguranta lui si nu am gasit decat de 2,5 A,aia a lui sa ars in urma atingeri din greseala a jack de suportu detectorului si a facut o scanteie cred ca am atuins plususl dar totusi de ce a facut asa ?Ca doar suportu ala nu-i legat la curent , sta in aer This post has been edited by C@talin: 6 Jun 2007, 14:45 Attached thumbnail(s) DSCF0649.JPG ( Size: 129.93k ) Number of downloads: 1222 DSCF0651.JPG ( Size: 119.37k ) Number of downloads: 1108 DSCF0652.JPG ( Size: 142.87k ) Number of downloads: 661 |
Range Rover
V8 5.0
Vogue SE
Laurentziu83 |
7 Jun 2007, 09:03
#81
Hmm, incearca sa muti detectorul mai spre zona hasurata. Unde l-ai pus tu il vei lovi cu parasolarul cand vei merge cu soarele in fata. Din pacate, ventuzele se lipesc doar cu superglue pe zona hasurata.
7 Jun 2007, 09:35
#82
Sau se prinde suportul detectorului de capitonajul plafonului
l@u |
7 Jun 2007, 13:43
#83
QUOTE(Laurentziu83 @ 7 Jun 2007, 10:03) Hmm, incearca sa muti detectorul mai spre zona hasurata. Unde l-ai pus tu il vei lovi cu parasolarul cand vei merge cu soarele in fata. Detectorul se regleaza sus/jos pe parbriz pana sta parasolarul in pozitia optima. Cobra 9730 este mult mai mare si nu am avut probleme cu parasolarul. This post has been edited by l@u: 7 Jun 2007, 13:50 |
Land Rover
Freelander
Td4, HSE
C@talin |
7 Jun 2007, 16:01
#84
Eu n-am folosit parasolaru ala mai deloc, pun ochelari de soare cand bate tare
Range Rover
V8 5.0
Vogue SE
Laurentziu83 |
7 Jun 2007, 20:42
#85
Ferice de tine, eu ca sa-mi pun ochelari de soare trebuie sa-i dau jos pe cei de vedere...
This post has been edited by Laurentziu83: 7 Jun 2007, 20:42 |
bashtalu |
24 Jun 2007, 01:26
#86
Membru autentic Group: Members Posts: 2.051 Joined: 9 September 06 From: Bucuresti |
am si eu o problema
am pus ventuzele in spatiul hasurat si le-am lipit cu super glue ca nu stateau deloc cred ca de la soare s-au dezlipit, am pus iar super glue si dupa un timp iar s-a dezlipit. pe parbriz s-a format o chestie alba, un star de lipici pe care nu-l mai pot lua, la fel si pe ventuze nu stiu cu ce sa le curat ca sa pun "moment", poate asta e mai bun sfaturi ceva? ms |
Audi
A4
borciparte |
24 Jun 2007, 07:48
#87
da Group: Banned Posts: 171 Joined: 7 June 07 |
QUOTE(C@talin @ 6 Jun 2007, 13:59) Vino pana la mine si iti dau eu suport de siguranta, cu capac, se inchide, se deschide, mare, scula pe bascula , doar ca trebuie sa faci drumul pana la Galati. Daca te hotarasti da-mi PM ca sa iti zic unde sa vii, e usor de gasit, daca coroborezi si cu o sesiune de cumparaturi la Metro e perfect This post has been edited by borciparte: 24 Jun 2007, 07:48 |
Dacia 1300
1980
- x 10 BOR Romania, tara tuturor imposibilitatilor!
Clona de-a lui cristirenault |
C@talin |
24 Jun 2007, 12:50
#88
Ms,da am facut eu unu home made ,merge perfect de atunci
Range Rover
V8 5.0
Vogue SE
borciparte |
24 Jun 2007, 14:49
#89
pai se poate face cu doi papuci mama si s-a rezolvat problema, eu am de la sisteme de alarma soclu pentru siguranta, mai multe modele chiar, daca are careva din zona nevoie il servesc
Dacia 1300
1980
B-84-HWH |
15 Aug 2007, 15:15
#90
Membru si atat Group: Members Posts: 83 Joined: 11 July 06 From: Bucuresti |
Dilema: Am parbriz atermic, care are o zona delimitata pe centru unde folia este decupata, totusi daca as amplasa detectorul acolo ar avea stergatorul in fata lui.
Intrebarea pe scurt ar fi: Ce ii afecteaza mai tare performantele, stergatorul sau "atermicitatea"? Bunul simt imi spune clar ca stergatorul, dar am zis sa intreb si niste experimentati in domeniu. Tot parerile voastre le-am folosit si la achizitionare cand m-am decis la srt 35r. Va multumesc "pe aceasta cale". Am luat deja in considerare pozitia din spatele retrovizorului dar ma incomodeaza firul si nu il pot ascunde caci detectorul e pentru mai multe masini. This post has been edited by B-84-HWH: 15 Aug 2007, 15:16 |
Clio Bicorp
2004 Extreme 1,5 dci 82CP
- B-84-HWH
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 27th April 2024 - 05:42 |
