Sticla far logan, se poate scoate?
cosminzcv |
23 Sep 2010, 20:41
Membru incepator Group: Members Posts: 2 Joined: 17 February 09 |
1.5dci.abs+
- b 77 zcv
god |
23 Sep 2010, 23:26
wizard Group: Members Posts: 328 Joined: 15 November 04 From: Bucuresti |
Uite aici detalii: http://www.daciaclub.ro/Faruri-ca-noi-t138480.html
Duster 1.5 dci 4X4
Iunie 2010 / Prestige It's time to burn™
23 Sep 2010, 23:46
acolo e vorba de dsn, care are sticla de sticla la far, nu plastic.
Andyno |
24 Sep 2010, 00:33
Membru autentic Group: Members Posts: 1.435 Joined: 9 June 09 From: Bucuresti. |
la fel este si la logan....cauta pe daciaclub.ro
This post has been edited by klaus: 24 Sep 2010, 14:14 |
Dacia 1310, an 99'.
Toyota Hilux D4D 170 CP 2007.
Dacia 1310, an 20' injectata.
24 Sep 2010, 11:27
La fel este ce? oare cum se face policarbonatul ala din farul de Logan daca-l prajesti pe aragaz?
This post has been edited by klaus: 24 Sep 2010, 14:15 |
24 Sep 2010, 11:52
Jack Daniel's |
24 Sep 2010, 15:28
MEMBRU DE LA INCEPUT! Group: Members Posts: 2.010 Joined: 26 October 03 |
Bogyciu |
24 Sep 2010, 18:19
Membru autentic Group: Members Posts: 1.017 Joined: 11 July 07 From: Constanta |
Exista pe youtube destule filmuletze in care se explica exact cum sa dai "sticla" unui far jos. Daca nu ai incredere si nu vrei sa faci paguba pe masina ta, mergi la un atelier de tinichigerie, reparatii caroserii si cauta un far cu urechi rupte sau alte defecte pe care ei de obicei le arunca si incerci.
Jack Daniel's |
24 Sep 2010, 22:37
Oare vrea sa ii puna leduri ca la Audi?
Serje |
25 Sep 2010, 10:53
Membru autentic Group: Members Posts: 2.129 Joined: 11 December 04 From: Cluj-Napoca |
Dsign parca si-o desfacut farurile, daca bine tin minte. Cauta aici: http://www.daciaclub.ro/B-48-C-U-P-Logan-1...PI-t134882.html
MTD
Optima
53 SPB HW
CriSTI68 |
25 Sep 2010, 17:31
Membru Valvos Group: Members Posts: 5.001 Joined: 8 January 07 From: Bucuresti |
am desfacut eu.... trebuie incalzite bine cu un pistol cu aer cald, dar cu grija sa nu topesti geamul de la far ( ) masticul ala este foarte al dracu pe care l-au folosit astia de la fabrica, cauta sa te joci pe un far stricat inainte ca sa vezi cum sta treaba, eu am tiganit un far mai terminat si m-am potolit cu desfacutul geamului
rayn3 |
27 Sep 2010, 11:09
Membru Group: Members Posts: 123 Joined: 3 May 07 |
Fara sa rupi ceva la ele(carcasa sau dispersor) n-ai sa reusesti.....In primul rand geamul(cum ii zici tu), in domeniu i se spune dispersor, la Logan este din plastic(mai exact policarbonat alb-transparent rezistent la UV ). In al doilea rand, la montarea dispersorului de carcasa(faza finala), pe carcasa exista un canal, in care se insereaza un adeziv(care adera foarte intre materialul carcasei(PP) si materialul dispersorului (PC)), asa ca nu prea se poate. Evident ca veti vedea ca sunt si niste clipsuri intre cele doua. Acelea sunt puse pentru o prefixare, asta pana cand se va intari acel adeziv. Se foloseste aceasta metoda(cam najpa) din doua considerente:
1. Etansarea farului(la praf/apa) 2. La defectarea unei componente din far, producatorul are interesul sa vanda tot farul si nicidecum componente din cadrul lui(asta-i mersul, firmele trebuie sa castige. Oricum este foarte dificil sa furnizeze piese de schimb la un far spre exemplu). Stiu ca un prieten de-al meu, a rupt multe din astea, tot incercand sa le demonteze, niciunul nescapand crapat sau spart/rupt. Monteaza kit-uri xenon. Am lucrat in cadrul firmei care produce farurile pentru Dacia, nu pentru divizia Automotive, dar le-am studiat si am vazut procesele, asadar stiu cum se fac. La stopurile spate, este si mai dificil de scos dispersorul(geamul rosu), intrucat cele doua piese se monteaza prin sudare prin ultrasunete(deci adio demontare ulterioara). In cazul de fata, varianta propusa mai sus(cea cu incalzirea la aragaz sau aer cald) pica din start, intrucat vei deforma/arde plasticele... In concluzie, daca te gandesti sa faci o astfel de operatie, gandeste-te de doua ori, eventual sa ai bani de un far nou(complet).... |
2007/1.6 MPI
Flavinho |
31 Oct 2010, 14:21
Membru autentic Group: Members Posts: 349 Joined: 21 September 09 |
De desfacut se poate sigur pentru ca sunt destui cu lupe bixenon deja, insa ma indoiesc ca e f simplu.Asa cum recomanda cineva mai sus cel mai bine ar fi sa iei un far chiar daca e spart si sa te antrenezi cu ala ca e pacat sa le strici pe cele de pe masina.
Megane sport tourer
2010 1.5 110 cai privilege
- AR-75-DMP
alex_ph27 |
27 Dec 2014, 23:51
Membru incepator Group: Members Posts: 15 Joined: 24 December 14 |
pana la urma ai reusit? )
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 26th April 2024 - 05:53 |
