Problema A/C Logan
Problema A/C Logan
N0SpeedLimit |
12 May 2017, 09:07
Membru incepator Group: Members Posts: 6 Joined: 8 May 17 |
2006 Diesel
iulic' |
12 May 2017, 09:44
Membru Group: Members Posts: 168 Joined: 28 January 07 |
Pare ca ai prea mult freon in instalație, asa cred
Laureate 1.5 dCI , 2006
- IF 90 ULI
N0SpeedLimit |
12 May 2017, 11:44
Am verificat in doua service-uri. A inceput sa faca asa prin iulie 2016, am fost sa bag freon crezand ca nu mai este destul, s-a dovedit ca era ok freonul, am reumplut instalatia si in maxim 2-3 zile iar a intrerupt. am mers si acum 3 zile sa verific iar instalatia ... este exact ca la carte ... parca aveam lipsa 2 grame.
2006 Diesel
sorin1983 |
12 May 2017, 11:45
Membru autentic Group: Members Posts: 5.587 Joined: 3 July 06 From: Bucuresti-Rahova |
ambreiajul compresorului e posibil sa faca figuri
Megane1-
12 May 2017, 15:12
senzorul de presiune posibil defect
Attached thumbnail(s) senzor_presiune_aer_conditionat_dacia_logan_ii_b6ed74243acb0fc3ad_0_0_0_0_0.jpg ( Size: 27.03k ) Number of downloads: 320 |
LAUREATE 1,6 GPL
Adrian Frigo |
12 May 2017, 22:17
Membru cu o tigaie de dacie Group: Members Posts: 2.031 Joined: 4 February 15 From: Undeva,pe dreapta |
QUOTE(bygy007 @ 12 May 2017, 16:12) senzorul de presiune posibil defect Asta este rezolvarea! |
Dacia 1300/
1310/1410 GTL/CL/Lj/Renault
Daciot convins! |
sobolan |
12 May 2017, 22:45
QUOTE(sorin1983 @ 12 May 2017, 12:45) majoritatea cazurilor la logan au avut ca efect inlocuirea compresorului , asta nu e o regula...... QUOTE(N0SpeedLimit @ 12 May 2017, 10:07) ....si am verificat urmatoarele: cantitate freon/ulei , presostat a/c(initial curatata mufa dupa care inlocuit) , panou comanda a/c(inlocuit cu altul). ..... This post has been edited by sobolan: 12 May 2017, 22:46 |
Logan-1.5dci-2017--
Golf mk5 - syncro - 2007--
N0SpeedLimit |
16 May 2017, 09:21
am pus testerul in weekend (un tester delphi) si asta arata...
Attached thumbnail(s) IMG_0106.JPG ( Size: 900.75k ) Number of downloads: 309 |
2006 Diesel
Adrian Frigo |
16 May 2017, 20:51
QUOTE(Adrian Frigo @ 12 May 2017, 23:17) QUOTE(bygy007 @ 12 May 2017, 16:12) senzorul de presiune posibil defect Asta este rezolvarea! |
Dacia 1300/
Daciot convins! |
16 May 2017, 21:29
LAUREATE 1,6 GPL
N0SpeedLimit |
17 May 2017, 08:26
O sa incerc azi sa schimb senzorul de presiune. Totusi am o presimtire ca nu senzorul este vinovat ... ci cablajul... sa vedem. Am vrut sa urmaresc presiunea dar cum sa fac asta daca in momentul in care a venit mecanicul sa puna furtunele pe masina ... a/c-ul nu a vrut sa plece nici mort.(si masina era nepornita de o zi).
2006 Diesel
kert |
17 May 2017, 08:31
Group: Moderatori Group: Members Posts: 360 Joined: 12 September 12 From: Bucuresti |
La mine asta a fost (dci/2006, a crăpat tot in 2016), acu' merge "brici":
http://www.daciaclub.ro/index.php?showtopi...dpost&p=4481693 |
Logan/Sandero Stepway
2006 dci/2017 09Tce-EasyR
- . Daca prin vot am putea schimba ceva, nimeni nu ne-ar mai lasa sa votam - Mark Twain
N0SpeedLimit |
17 May 2017, 11:23
Motorul meu merge rotund si frumos si cand merge ac-ul si cand nu merge. Am vrut sa ma uit la lipituri insa am observat ca am nevoie de o surubelnita mai speciala ca sa pot desface carcasa uch.
2006 Diesel
kert |
17 May 2017, 11:34
Pai nu e musai sa faca la fel. Comanda releului pentru compresor vine din UCE injectie, posibil sa ai probleme numai la pinul respectiv. La mine erau o gramada cu lipituri reci/fisurate.
Cind nu porneste compresorul, deschide capota si misca de cele 3 mufe ce intra in UCE injectie sa vezi daca e o problema de contact la mufe/pini, ciocaneste un pic in carcasa calc. de injectie si vezi daca o ia compresorul din loc... |
N0SpeedLimit |
17 May 2017, 13:03
Kert, am o rugaminte la tine si anume sa imi spui si mie daca in momentul in care pornesti A/C-ul, pe loc, masina pe liber si accelerezi putin...fie si 100 rpm, la revenire la relanti ... compresorul decupleaza si cupleaza iar sau nu decupleaza indiferent cat si de cate ori accelerezi... pt ca la mine decupleaza si nu prea pare normal... Multumesc
2006 Diesel
kert |
17 May 2017, 13:26
La mine se intimpla haotic. Cuplarea sau decuplarea nu erau corelate cu nimic si a fost vorba de contact imperfect al pinului (de pe placa UCE inj.) de comanda a releului pentru compresor.
Eu nu spun ca e acelasi defect pe care l-am avut eu ci doar sa verifici si ce am zis poate te ajuta. |
daniel777 |
1 Jul 2017, 00:48
Membru incepator Group: Members Posts: 3 Joined: 25 June 17 From: București |
am aceeași problemă, verific săptămâna viitoare și eu ce pot pe la mașină, senzor de presiune etc și dau de veste
This post has been edited by daniel777: 1 Jul 2017, 00:48 |
- ATG
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 23rd April 2024 - 08:34 |
