stereo instalation, wiring diagram
gav |
24 Jun 2008, 11:09
Membru incepator Group: Members Posts: 13 Joined: 24 June 08 |
Logan MCV
Laureate 1.6 16V 2008
mario1980 |
24 Jun 2008, 13:40
Membru autentic Group: Members Posts: 437 Joined: 8 April 05 From: Iasi |
Speakers: 13 cm, all 4 of them, the blue wire, do not know... Isn't it pluged to the ISO connector?
dci Preference 2006
- SV ?? ??? Adesea, aproape fiecare om tolereaza prostia celui de linga el, atit timp cit nu ii uzurpa propria prostie.
gav |
24 Jun 2008, 17:05
Yes, all the wires are in the connector, but I thought what ever stereo i buy probably wouldn't have the same connector. Seeing as you're calling it iso I guess it's standard. Haven't installed a stereo into car in quite a few years. Have a lot of experience making portable sound systems with car amplifiers though.
I might just have a pair of 13cm speakers stored away that I never used before. Thanks. |
Logan MCV
martin245 |
24 Jun 2008, 18:45
EX PAT Group: Members Posts: 913 Joined: 1 April 06 From: Karlsbad Germany (again) |
Could the blue wire be for an electric antenna ?
Stu |
logan 14 mpi Simply RED
- GB 1 Bessy Regs
mario1980 |
25 Jun 2008, 15:26
QUOTE(gav @ 24 Jun 2008, 17:05) Yes, all the wires are in the connector, but I thought what ever stereo i buy probably wouldn't have the same connector. Seeing as you're calling it iso I guess it's standard. What ever stereo you will buy, it would not have the same connector for sure. But, it is most likely to have the complementary connector... At least in Europe, I belive almost every stereo uses this type, or has an adapter included. Enjoy your new car. |
dci Preference 2006
gav |
25 Jun 2008, 16:41
Ok great, I look for a new stereo in Austria tomorrow. Pretty sure it will be cheaper than in Croatia. Import and sales tax here is very high.
Stu, I think you might be right about electric antenna. Didn't think people still used them. |
Logan MCV
martin245 |
25 Jun 2008, 17:42
They dont but it is still there just in case
stu |
- GB 1 Bessy Regs
gav |
30 Jun 2008, 09:11
Bought a stereo and it seems the blue wire is something a little more modern. It's the remote mute wire used in conjunction with some hands free phone systems.
My speakers in the basement turned out to be 17cm, but I think I can fit them by removing the plastic speaker surround that's mounted in the door already. Will let you guys know how it goes. |
Logan MCV
TheSaiLor |
30 Jun 2008, 09:27
Membru autentic Group: Members Posts: 367 Joined: 6 April 04 From: Constanta |
Gav, the blue wire from the ISO conector i'm think is for the dimmer. The blue wire for mute I belive you read about it in the manual of your new stereo.
Audi A4 1.9 TDI
Clio 1.5 dCi
- CT - 0123
gav |
30 Jun 2008, 15:45
yeah, stereo wiring does not equal wiring in car. The blue wire is in fact as stu said, aerial remote.
Fitted the stereo, no problems. 17cm speakers went in just fine after I removed the plastic speaker surround from the door. All holes aligned well. Only problem was that the speaker covers no longer had anything to clip on to. I just used a few drops of glue to put them back on. |
Logan MCV
urban |
15 Sep 2011, 20:35
Membru incepator Group: Members Posts: 2 Joined: 15 September 11 |
Hi!
I just bought a Sandero and there was not a stereo included. The wiring in the hole where the stereo fits is in place. But! I don`t find the speaker wires that should be in the front or backdoors. I suppose they are somewhere in the sides in the front compartment since there are prewired connections from the place of the stereo... Anyone knows the location??? Plz help out !! Kindly /Urban |
Llogan MCV and Sandero
2011
mario1980 |
16 Sep 2011, 14:17
I'm afraid you'll have to install the wires for the speakers by yourself. Though I may be wrong.
dci Preference 2006
mario1980 |
22 Sep 2011, 09:25
The same issue was discussed on the romanian language section, and it seems that the wiring for the speakers was found in the end, but I didn't quite understood the location.
Sorry for the previous statement. |
dci Preference 2006
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 26th April 2024 - 00:06 |
