Water accumulating in LOGAN, Water accumulating in LOGAN
Macmahon |
26 Jun 2008, 11:56
Membru incepator Group: Members Posts: 3 Joined: 26 June 08 |
Mahindra Logan
1.4 GLX
march 2008
martin245 |
26 Jun 2008, 17:45
EX PAT Group: Members Posts: 913 Joined: 1 April 06 From: Karlsbad Germany (again) |
Take the car to the dealer !!! It is faulty .
Stu |
logan 14 mpi Simply RED
- GB 1 Bessy Regs
mario1980 |
27 Jun 2008, 09:05
Membru autentic Group: Members Posts: 437 Joined: 8 April 05 From: Iasi |
1. The fuel consumtion reaches normal level usualy after 3000-5000km, for any new car I think (except for the electric ones ).
2. It could be the plastic cover of the back doors, that is not selaed properly to the door metal body, in the down side area. You can check if this is the case, by watering the back door window, with lots of water, It will drop inside the door, and from there it will splash until it gets inside the car. Hope you understood... Regards... |
dci Preference 2006
- SV ?? ??? Adesea, aproape fiecare om tolereaza prostia celui de linga el, atit timp cit nu ii uzurpa propria prostie.
Keka |
28 Jun 2008, 12:27
Logan driver :P Group: Members Posts: 113 Joined: 30 May 07 From: Novi Sad, Serbia |
if you have AC, water drainage pipe could be obstructed with dirt.....this morning i found wet carpet at passanger's feet, and when i got under the car and cleaned drainage, some mud and water ran out.
2004 1.6 MPI Laureat pack LPG by Dora
- Kadett 1.6D 1983
Macmahon |
30 Jun 2008, 05:51
I got my car serviced on saturday.
According to the service centre the problem is due to A/C vent pipe. It was half outside and half inside which was accumulating water near driver seat. I was further told that because of gallery provided for wiring the water travelled to rear seats also. They have repaired this A/C pipe, and extended it with additional pipe so that it never again jumps in the cabin. They have to dismental and re assemble the dashboard since the pipe is under it. Got my car back on sunday evening. Hope the problem is solved. The service was excellent. They were eager to listened to your problem, discussed the probeble cause with you. I don't understand why people are not happy with the service centre. "G3 Motors in Nerul, Navi Mumbai" is very professional. About the milage they told that getting 8.5 to 9 km / lt is good. Eventually when they change the oil during second servicing the avarage will be 10.5 to 11 km / lt. Makes sense....... |
Mahindra Logan
1.4 GLX
march 2008
VIKRAM |
12 Oct 2012, 06:20
Membru incepator Group: Members Posts: 1 Joined: 12 October 12 |
QUOTE(Macmahon @ 30 Jun 2008, 05:51) I got my car serviced on saturday. According to the service centre the problem is due to A/C vent pipe. It was half outside and half inside which was accumulating water near driver seat. I was further told that because of gallery provided for wiring the water travelled to rear seats also. They have repaired this A/C pipe, and extended it with additional pipe so that it never again jumps in the cabin. They have to dismental and re assemble the dashboard since the pipe is under it. Got my car back on sunday evening. Hope the problem is solved. The service was excellent. They were eager to listened to your problem, discussed the probeble cause with you. I don't understand why people are not happy with the service centre. "G3 Motors in Nerul, Navi Mumbai" is very professional. About the milage they told that getting 8.5 to 9 km / lt is good. Eventually when they change the oil during second servicing the avarage will be 10.5 to 11 km / lt. Makes sense....... Please can you post image of the ac drain pipe. I cant locate it under my car. tankx in advance |
renault
LuluMOB |
12 Oct 2012, 07:55
Membru cu pedale. Group: Members Posts: 1.136 Joined: 28 October 05 From: Iași |
In the third video, at 2:45. Under the car, the hole is aligned with the front doors hinges... more or less.
http://www.scribd.com/doc/22506181/Dacia-L...nual-de-Service This post has been edited by LuluMOB: 12 Oct 2012, 08:23 |
ABS+ AC 1.4MPI 06/2007
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 10th May 2024 - 01:39 |
