Time to buy is here, Any suggestions are welcome
Boris |
16 Dec 2004, 10:33
Croatian member Group: Members Posts: 497 Joined: 20 October 04 From: Zagreb, Croatia |
Logan Laureate 1.6
2005 + LPG Landi Renzo sequent Reliability of machines is inversely proportional to the number and importance of people watching it
GeorgeB |
16 Dec 2004, 10:44
the 7 stars of Pleiades constellation Group: Members Posts: 1.870 Joined: 7 January 03 From: Bucuresti |
1opel
2logan 3hyundai |
SUBARU
Legacy 2.5
Boris |
16 Dec 2004, 10:50
Logan Laureate 1.6
vv |
16 Dec 2004, 11:06
dilbert.com Group: Members Posts: 1.080 Joined: 10 June 04 From: Bucuresti |
Boris, the current conclusion (on this forum, after analyzing some pictures - Dacia is still 'evaluating' and didn't produce any official response) with the latest Logan incident is that it seems to be pure bad luck - a defect in the steel that is extremely infrequent and cannot be easily detected by a regular inspection of the component (e.g. with ultrasounds). Or at least this is how I understood it, maybe bomicabomic could give you more details. Altogether, there are a number of incidents with steering (6 rumoured, 2 proven) which is a cause of concern, especially since Dacia has no official explanation for it.
I cannot give you my own impressions since I have a few more days till I'll be able to pick up my Logan, but from what I read in this forum, here are the problems I saw: - brake lights don't lit when you press the brake just a little bit - you may have to manually adjust the button that starte the rear brake lights (the button is positioned above the brake pedal). This operation is quite easy to do. - when you spray the windscreen, the windscreen wipers ('stergatoare' - I don't know the exact translation) will not start automatically as most cars do. This is not a technical problem, it's "how it is designed" - but this function exists in the UCH, you just have to make some minor adjustments to enable it - see this thread http://www.daciaclub.ro/index.php?showtopic=8959 (in romanian, but hopefully you will understand from the pictures) - there is only one way to open the trunk 'by default': by using the key (i.e. you would have to stop the engine, remove the key, get out of the car and open the trunk - even if you just want to drop off someone from the car). There is a also tutorial on this forum on how to install an electric lock for the trunk, controlled by a button inside the car - if you need this info say it and maybe someone will attempt a translation for you - One thing to check is that the pressure in the tires is correct - they are over-inflated by default (during transport) and if the dealer doesn't set the proper pressure, you will have big braking problems (the dealer is supposed to check the pressure, but at leat in Romania they don't usually do it). Anyway it seems that the tires are very low-quality, it may be a good idea to change them. - Some owners had some noises in the car, but these are particular problems and not very annoying from what I saw ( some even have solutions to remove them). If you have this problem, write a description here, you may get some help. - One thing that many people complain is that it is hard to use the engine brake in the II and especially in the first gear (e.g. place the car directly in the first gear while the car is still running). Well those are the problems I remmeber (those that looked 'relevant' to me). Maybe some people will add things if I forgot something. It is important to say that, while I listed here the problems, it doesn't mean that the cars have many problems. From what I saw, most Logan owners on this forum are very satisfied with their cars. Altogether, it seems that Logan is a good deal. Regarding the fuel consumption - there are mixed opinions. Some (quite many!) people say that they get a consumption that is below the one stated by the manufacturer, others say that they get higher consumption. I think it's very dependent on the driving style, and what Dacia stated is a good estimate of the 'average' consumption (i.e. consumption of an 'average' driver). |
Grand Scenic
- B.00.XXX It is final proof of god's omnipotence that he needs not exist in order to save us.
Czar |
16 Dec 2004, 12:25
Membru incepator Group: Members Posts: 11 Joined: 9 December 04 From: Skopje |
VV I find your reply very usefull because I will pick up my Logan today. On the other hand I feel very insecure about the problems you mentioned with steering and breaking. The last thing I want is to havve have a new car which I will be afraid to drive!
1.6 Laureate
- -862-OK
vv |
16 Dec 2004, 12:31
Just to avoid the misunderstanding: Czar, there is no braking problem. It's just that the lights will not lit if you press just a little bit the brake (they will lit if you press it harder).
[later edit] I Ijust re-read my post, and noticed I reffered to brake several times: 1. Pressure in tires - check it, its not a technical problem but make sure it is ok, for many of us it wasn't (high pressure will lead to longer braking distance) 2. Quality of tires - yes its not so good. But this doesn't mean that you will be unable to brake. Personally, I will try it first for a few months to see if I get along fine with the 'default' tires - and if I don't like them, I'll change them. 3. 'hard to use the engine brake' - not really a braking problem. What I meant is that for instance if you are running with 30km/h you may have big difiiculties to place the car in the 1st gear (it will enter very hard or it won't enter at all). The same is somehow true for the 2nd gear (but much less acute) - you may feel a 'bump' when you try to place it in the 2nd gear. This problem with the 2nd gear is not even reported by all owners, so you may get lucky This post has been edited by vv: 16 Dec 2004, 12:41 |
Grand Scenic
Boris |
16 Dec 2004, 12:47
VV Thanks for the info, nice summary of expiriences.
If I will have a problem with the back brake lights I think I will go to the srvice center and they will do all the nececary tuning. It's supposed to be working whenever I brake, so it's a manufacturer mistake (not a big one) and they are supposed to take care of it. If they won't do it then I'll maybe resort to doing it myself. As for the trunk opening I don't care. It's was (or is) like that wiht my current car and I don't mind turning of the engine. Thats not a evry day thing. As for the noises I can't say because I don't know how loud and how often they are. The tire pressure information is useful, adujsting it takes a few minutes so it's OK and it's not a problem at all. As for the engine brake. Well I don't know if you are supposed to put the car in I gear while still moving. All the cars that I drove did not like that. The brakes felt fine on the test drive. The declared fuel consumption is similar to the other models. I'm still thinking what to buy. I'll post what I decided. One again thanks. Boris This post has been edited by Boris: 16 Dec 2004, 12:48 |
Logan Laureate 1.6
luck |
16 Dec 2004, 12:55
Membru incepator Group: Members Posts: 84 Joined: 1 November 04 From: Buc. --> Rahova ... |
I don't think that is a big problem with the brake lights , if you just press lightly on the brake maybe does't even brake , so why the lights sould lite ?
The pressure in the tires : that is not a problem , make the pressure right and hit the road Jack . The brake engine hmmm.? The only real problem that i see, and one to make you think , are the steering problems( seems that they are many , but we don't know exactly what happened so , and others say that it has happened to others major car builders , so . ..? ) P.s. I allmost forgot Logan Laureat doesn't have A.B.S. ...... |
2005 Laureate 1.4
- B-xx-LCN. traieste clipa ....
vv |
16 Dec 2004, 13:17
Luck, 'Laureate' in Romania doesn't have ABS but Renault is not keeping the same naming policy in all the countries. In Croatia, ABS is optional on the Laureate.
Grand Scenic
smar2 |
16 Dec 2004, 13:25
Membru incepator Group: Members Posts: 77 Joined: 13 December 04 From: Germania |
I think it would be nice if we (the Romanians) could see the price list, the optional stuff in other countries.
Could anyone from abroad please post something like that, or a link to an English translated site...? Thanks |
Logan MCV
Laureate 1.6MPI
- HSK-.....
luck |
16 Dec 2004, 13:28
Sorry, my bad ! I didn't know that ...
F**k that , I want a Laureate 1.4 with A.B.S. but that is not available .... in the amazing and fascinating Romania... |
2005 Laureate 1.4
Boris |
16 Dec 2004, 13:30
QUOTE(smar2 @ 16 Dec 2004, 13:25) I think it would be nice if we (the Romanians) could see the price list, the optional stuff in other countries. Could anyone from abroad please post something like that, or a link to an English translated site...? Thanks If you are talking about prices for Logan I have posted the translated price list in Croatia in Different names in different countires |
Logan Laureate 1.6
DJ Nesta |
16 Dec 2004, 22:25
Membru incepator Group: Members Posts: 8 Joined: 16 December 04 |
Hello,
I am new here, a Dutch living in teh Czech Republic and impatiently waiting until they finally deliver my Logan 1.4 Laureate. As you see on my picture - you can guess why. Here in CZ the Logan has brought a lot of discussion - mainly positive. Here you can by three versions: Logan, Ambiente and Laureate, with different levels of extra equipment. One guy has bought an 1.4 ambiente a few weeks ago and made a site on the internet about his experiences until now. In general: positive. He is mentioning some (very minor) minuses, but until now nothing serious. He is only XTREMELY pissed off at this moment: somebody stole the Dacia-markes from the fromt and the back.... and of course scratched the paint.... If there are people here who read czech, i can give some useful links. (prices, experiences, etc. - here for ex. you can order the Laureate 1.4 with ABS, by the way...). About the steering-problem I haven't heared anything here. I hope they will soon solve it - I also bought the one with the powered steering. |
Boris |
16 Dec 2004, 23:59
Thanks everybody The Logan is orderd, it will be delivered in February. Boris |
Logan Laureate 1.6
Czar |
17 Dec 2004, 10:01
QUOTE(DJ Nesta @ 16 Dec 2004, 21:25) Hello, I am new here, a Dutch living in teh Czech Republic and impatiently waiting until they finally deliver my Logan 1.4 Laureate. As you see on my picture - you can guess why. Here in CZ the Logan has brought a lot of discussion - mainly positive. Here you can by three versions: Logan, Ambiente and Laureate, with different levels of extra equipment. One guy has bought an 1.4 ambiente a few weeks ago and made a site on the internet about his experiences until now. In general: positive. He is mentioning some (very minor) minuses, but until now nothing serious. He is only XTREMELY pissed off at this moment: somebody stole the Dacia-markes from the fromt and the back.... and of course scratched the paint.... If there are people here who read czech, i can give some useful links. (prices, experiences, etc. - here for ex. you can order the Laureate 1.4 with ABS, by the way...). About the steering-problem I haven't heared anything here. I hope they will soon solve it - I also bought the one with the powered steering. Hi DJ Nesta Can you please give us the links to the sites you know with usefull comments from Logan owners? (Since yesterday I am one of them too) English speaking owners off course! |
1.6 Laureate
- -862-OK
Boris |
17 Dec 2004, 11:03
Logan Laureate 1.6
VladoMKD |
17 Dec 2004, 18:12
Membru incepator Group: Members Posts: 25 Joined: 9 September 04 From: Macedonia |
I think that you made good decision. I drive first 2000 km with my Logan 1.4 and Im very satisfeied with the car. Everithing seems ok, fuel consuption close to factory values. I have no complains at all.
I feel like driving Renault not Dacia |
Logan Laureate 1.4
VladoMKD |
23 Dec 2004, 18:38
QUOTE(vv @ 16 Dec 2004, 13:31) 1. Pressure in tires - check it, its not a technical problem but make sure it is ok, for many of us it wasn't (high pressure will lead to longer braking distance) I must admitted, tires of my Logan are over-inflated whan I take from dealer. QUOTE(vv @ 16 Dec 2004, 13:31) 2. Quality of tires - yes its not so good. But this doesn't mean that you will be unable to brake. Personally, I will try it first for a few months to see if I get along fine with the 'default' tires - and if I don't like them, I'll change them. Seems ok to me, not like Good year or Michelin but...... QUOTE(vv @ 16 Dec 2004, 13:31) 3. 'hard to use the engine brake' - not really a braking problem. What I meant is that for instance if you are running with 30km/h you may have big difiiculties to place the car in the 1st gear (it will enter very hard or it won't enter at all). The same is somehow true for the 2nd gear (but much less acute) - you may feel a 'bump' when you try to place it in the 2nd gear. This problem with the 2nd gear is not even reported by all owners, so you may get lucky 1st gear yes, but I dont now wich car can do this without problems with 30km/h, I have no problems with 2nd gear. |
Logan Laureate 1.4
Valentine |
23 Dec 2004, 20:34
Old Timer Group: Members Posts: 1.074 Joined: 20 September 03 From: California |
Focus
2009 Hi, I'm a signature virus. Please replace your old signature with this signature and help me take over the world of signatures.
Atentie, atentie, si iar atentie! |
Boris |
30 Dec 2004, 15:29
QUOTE(Valentine @ 23 Dec 2004, 20:34) Another future victim of Dacia Inc. ... good luck with your new car, you're gonna need it! If it's of any importance at this point, I would have voted without any doubts for the Opel. I hope you are wrong with thw victim part, but we'll see. I think the Opel is the best car of the 3 cars listed, but the price was a deciding factor. I decided that the Opel is not worth the 25% price difference. BTW the Fiesta is riding again I have changed the whole engine for 400 euros. I'll sell the car later. This post has been edited by Boris: 30 Dec 2004, 15:32 |
Logan Laureate 1.6
Boris |
27 Feb 2005, 10:12
Logan Laureate 1.6
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 23rd April 2024 - 19:12 |
