temperature indicator over heat
tondarmania |
13 Jun 2016, 06:30
Membru incepator Group: Members Posts: 4 Joined: 13 June 16 |
irankhodro
l90
2011
13 Jun 2016, 10:30
the problem might be at the table (minus ) from dashboard / chassis engine
read end translate with google this this topic |
tondarmania |
13 Jun 2016, 12:25
Thanks Alot for your advice.
i prepared a NO 14 power cable for strengthen the negative polarity to chasis, yesterday.but not under test !!!. as soon as done inform you the result. hopefully get rid of this problem |
irankhodro
l90
2011
tondarmania |
15 Jun 2016, 11:05
strengthen the negative polarity by the power cable to chassis did NOT work
All i knew and asked from specialists done ,but the problem is still available. The solution is selling the car and get rid of troubles. This post has been edited by tondarmania: 15 Jun 2016, 11:06 |
irankhodro
l90
2011
15 Jun 2016, 11:16
you tried to see if the fan speed goes ?
when you turn on the air conditioning should go |
rusugxg |
15 Jun 2016, 14:59
Membru incepator Group: Members Posts: 92 Joined: 28 November 06 From: Iasi |
Try to change the "specialist". I’m sure that you already have pay for nothing. Check yourself what the colleague @bygy007 suggest above!
By the way, how did “4-checking water pump health” was done??? Also check the front engine radiator. It can be partially stifled. |
Dacia, Ford
Logan, Focus
2006-Ambition 1.6.MPI, 2020
tondarmania |
18 Jun 2016, 09:22
Thanks to you :
1- as soon as problem happened checked fan speed (both slow and fast ) .so ,make sure about fan health. 2- the specialist is the best as i asked other specialists !!! step by step checked but unfortunately nothing happened. about checking water pump : since access to it is a little bit difficult ,he checked the water path hot via pushing tube which caused to sense hot air goes out that proved the water circulation is ok. checking the radiator while problem happened also done.put the hand on radiator and was hot,which showed coolant circulation . cleaning (insects like butterfly ,paper and typically any rubbish ) is also checked and was normal (not dirty). if you mean something else about radiator ,please inform me. just one thing !!!! : when i told to the specialist that his last solution was not successful,told me found a solution on other cars and that`s checking the battery and alternator (dynamo) voltage which must be 13.5-14.5 or some thing like this and recommend me to check these by him .what`s your idea? |
irankhodro
l90
2011
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 26th April 2024 - 10:38 |
