Blinkers - Side light signals problem, Dash board light signals both working same time
salamat |
30 Mar 2012, 13:45
Membru incepator Group: Members Posts: 3 Joined: 30 March 12 |
Renult
Tondar90/Dacia Logan
2011
hhgttg69 |
30 Mar 2012, 14:48
Membru incepator Group: Members Posts: 18 Joined: 14 March 11 From: Ballarat , Australia |
try the flasher can first , or maybe try another indicator switch?
other than that no idea |
Mitsubishi
lancer
- 166GP
salamat |
1 Apr 2012, 17:31
Thank you so much for your kind reply........
I'm not sure I tryed to check but there is no map or information to check which is for the flasher or the blinker........ I hope if you can explain me more |
Renult
2011
1 Apr 2012, 18:00
there is only 1 led for signal light in dashboard, not 2, so it cannot blink different for right or left.
so is no problem, it's a "feature" Even there is one exit from UCH (unite controle habitacle) for signal light on dashbord, not two as there are on other cars. |
salamat |
2 Apr 2012, 09:12
Dear klaus
Thnx alot for your reply What a GOOOOOD feature !!!!!! is adding another LED will cost them so much ??? very strang thing |
Renult
2011
ionik_e4 |
28 May 2012, 15:36
Membru autentic Group: Members Posts: 370 Joined: 17 February 11 From: Constanta |
Our iranian friend,Dacia Logan,like Klaus said,have one led in the dashboard, a common signal,and what do you want is,probably,a dashboard signal like Dacia Solenza have..look at the pictures bellow:
This post has been edited by ionik_e4: 28 May 2012, 15:37 Attached thumbnail(s) 10000277yy.jpg ( Size: 72.94k ) Number of downloads: 223 651987938076603137148667_5782623_700_700.jpg ( Size: 59.14k ) Number of downloads: 247 dacia_solenza.jpg ( Size: 61.14k ) Number of downloads: 234 |
Daewoo
Matiz
- CT 11 KTC
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 26th April 2024 - 15:34 |
