> Logan strange problem
ivo1404
post 17 Jul 2013, 00:28
Hello, I have Dacia Logan 1.6MPI when car reaches normal working temperature(4 bars) or measured with torque(Android) about 94C the moment I turn on the headlights the temperature it goes up to 6 bars, but on torque the temperature remains same 94C and when I turn off the headlights the temperature returns to 4 bars.
I have two Logan's so I've tried the instrument panel, the water temperature sensor nothing changes. Any suggestions?
Dacia Logan 2005
post 17 Jul 2013, 12:23
The dashboard panel is not very well grounded, is a poor (cheap) conception of electrical system in Logan and there is an electrical potential difference between engine ground and dashboard ground.
Shortly, is not a real problem.
ivo1404
post 17 Jul 2013, 21:27
OK so I will check ground connections and hopefully the problem will be solved.
Thanks
Dacia Logan 2005
MyKe89
post 17 Jul 2013, 22:38
Membru RFG
Retightening all of your ground connections or just replacing the thin wires with thicker ones should solve your problem.
'23 Honda CR-V e:HEV
‘23 Honda NC750XA
Lo-Fi Version  Harta site  Parteneri  Jocuri online  Curs Valutar  HRH Haine din lana merinos Time is now: 16th April 2024 - 11:42
