Dacia Logan Gearbox, JH1, JH3...
Peja |
3 May 2008, 20:17
Membru incepator Group: Members Posts: 81 Joined: 26 January 08 From: SERBIA |
Logan 1.4MPI Preference + AC
Apr 2008 http://loganimprovements.blogspot.com
PaulT |
4 May 2008, 19:36
Membru autentic Group: Members Posts: 3.294 Joined: 23 June 06 From: Bucuresti |
There is no automatic gearbox for Logan.Only manual,so you will have to change the gears manually.But it handles with great ease...
Dacia/Mitsubishi
2006 Laureate/1973/2008
- B-00-xxx
Peja |
4 May 2008, 23:51
I didn't ment AUTOMATIC, but AUTOMATED in meaning that by pressing the clutch and puting joystic in wanted position, electro-hidraulic mechanism adjust gearshift.
If it is a same gearbox like in Megane II or Laguna II (like DACIA says) JH1 should be working in this way. That's why changing gear is so easy and "soft". Am I correct? Peja This post has been edited by Peja: 4 May 2008, 23:59 |
PaulT |
5 May 2008, 19:55
No,you're not right.It's a classic,manual transmission.And as far as I know,the Megane 2 is equipped either with a classic,manual gearbox,with 5 or 6 gears,either with an automatic gearbox with 4 gears.You might be talking about an cable gear selector,wich is not automated.But it's smoother compared to the classic gear lever .You will find this on Logan Prestige.
Dacia/Mitsubishi
- B-00-xxx
Peja |
6 May 2008, 11:39
Yes Paul, you got wright. I've reading russian book for Logan with color photes, and yes it is classical manual gear.
eXtenSion |
19 Jul 2008, 15:55
Membru autentic Group: Members Posts: 1.259 Joined: 10 January 05 |
It is not automated, the connection between the stick and the gearbox is done either with rods or cables (some MCV versions). The clutch is mechanical or hidraulic-on some diesel versions, I think.
This post has been edited by eXtenSion: 19 Jul 2008, 16:00 |
Mercedes
C
'22 Mazda 3 '19 Logan '07 1310 '01
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 25th April 2024 - 19:13 |
