Castrol TBE petrol additive?, Is it safe for Logan ?
zorpetus |
15 Aug 2006, 12:51
Membru Group: Members Posts: 120 Joined: 17 April 06 |
None
None
- None
BAC |
15 Aug 2006, 13:31
Membru autentic Group: Members Posts: 450 Joined: 1 September 04 From: Reghin |
Maybe is safe but certainly is waste of money. Is not necessary to use in the new engine.
ex. Opel
ex.Vectra C
2007 OPC line
- MS
kodrix |
15 Aug 2006, 14:54
Membru tanar Group: Members Posts: 220 Joined: 20 July 05 |
If your car doesn't have a problem you don't need to use that solution. So, my advice is not to use it!
- Skoda Fabia 1.2TSI 2010
Logan 1.4MPI Laureate 2005 de la 0 km la peste 180.000 km Logan 1.4MPI 2009 E0 Logan 1.4MPI 2009 Ambiance |
zorpetus |
15 Aug 2006, 15:14
QUOTE(BAC @ 15 Aug 2006, 13:31) I know that it is not necessarry to use it in new engine, but since quality of fuel around here (Balkans) is under big question mark... maybe this could be good preventive maintenance for the fuel injectors etc. |
None
None
- None
driverx |
15 Aug 2006, 15:47
From time to time, drive the car at higher RPMs to keep the injectors opened for a longer period of time to allow some type of cleaning the injectors. This will eliminate small sediments which may block the injectors to work properly.
P.S. Be careful, do not destroy the engine |
Mitsubishi
Lancer
zorpetus |
15 Aug 2006, 16:55
QUOTE(driverx @ 15 Aug 2006, 15:47) From time to time, drive the car at higher RPMs to keep the injectors opened for a longer period of time to allow some type of cleaning the injectors. This will eliminate small sediments which may block the injectors to work properly. P.S. Be careful, do not destroy the engine Yeap, I know, so called "Italian tuning" :-) Speaking about the RPM - what is recommended as optimum RPM for 1.4 engine? Optimum - meaning best ratio between power and fuel consumption. And I guess that this engine should not be driven for a long period over 4000 rpm? |
None
None
- None
mccoy |
15 Aug 2006, 21:47
Membru autentic Group: Members Posts: 273 Joined: 2 January 05 From: small town in Vojvodina |
Perhaps Castrol gasoline additive is suitable only for engines with Castrol oil in…
I agree that is waste of money. |
Laureate 1.6
- ...98-7. -----------------------------
Divide et impera ... and unite in EU ! ----------------------------- |
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 4th May 2024 - 23:51 |
