[VAND] Sistem audio Genius 5.1, Avariat, eventual pe bucati ca si piese de schimb
Lord Hades |
26 Dec 2009, 18:26
Memento Mori Group: Members Posts: 1.640 Joined: 28 July 07 From: Brasov |
OOOO
A3
$$ilvviu |
26 Dec 2009, 20:17
Membru autentic Group: Members Posts: 5.882 Joined: 6 January 07 From: Roman/NT |
Despre ce sistem e vorba?
Ai niste poze? |
Initiale 2002
Lord Hades |
26 Dec 2009, 21:31
Boxe GENIUS SW-HF 5.1 5000
Putere 150W Specificatii Tip 5.1 Banda de frecventa 40Hz ~ 20KHz Putere RMS 150W Telecomanda Da Raport semnal/zgomot 85 dB Impedanta Satelit: 4 ohmi Subwoofer: 4 ohmi Dimensiune sateliti Front:140 x 217 x 165 mm Rear: 120 x 197 x 140 mm Dimensiune subwoofer 220 x 412 x 344 mm Dimensiune satelit central 332 x 142 x 155 mm Putere satelit 15W Putere subwoofer 75W Altele 6x RCA Audio Input Jacks for 5.1 Channel DVD player 3x pairs of RCA jacks for two-channel DVD players 26 Dec 2009, 22:34: Daca e nevoie, pot adauga poze reale cu boxele mele, dar abia maine. This post has been edited by Lord Hades: 26 Dec 2009, 21:34 Attached thumbnail(s) genius.jpg ( Size: 28.47k ) Number of downloads: 3273 |
OOOO
A3
lucifer |
26 Dec 2009, 23:45
Membru autentic Group: Members Posts: 711 Joined: 9 April 05 From: Bucharest Dr. Taberei |
Vreau eu subwoofer-ul daca esti din Bucuresti ! Si telecomanda daca o mai ai !
1410
1997
- B xx GEC
bolidu |
27 Dec 2009, 11:13
Pai daca n-am ?! Group: Members Posts: 2.068 Joined: 1 July 06 From: Medgidalas |
M-ar interesa doar difuzorul din subwoofer si toata placa cu circuite. Le dai asa? La ce pret ?
Solenza Confort
Opel Astra Coupe
- CT-XX-CMF Daca te lasi de fumat, de baut si de femei, nu traiesti mai mult, doar ti se pare ca timpul trece prea incet.
Lord Hades |
27 Dec 2009, 12:41
lucifer sunt din brasov. Daca te intereseaza totusi, il pot expedia prin posta, taxele fiind mai mici decat la curierat rapid. Iti pot trimite si transformatorul, daca crezi ca il mai poti utiliza. Deocamdata nu am transformatorul la mine, el fiind la cineva pt rebobinare. Treaba e ca sunt dus cu vorba cu rebobinarea si maine anulez afacerea. In 2 zile ar trebui sa recuperez transformatorul, si pot pregati un colet pt tine. Daca preferi curierat rapid nu am nicio problema, doar ca tariful e mai mare decat la posta romana, si dupa cum am mentionat, preturile afisate sunt fara transport.
Sunt dispus sa discutam sa gasim cea mai buna varianta Am uitat sa adaug, am si telecomanda 27 Dec 2009, 13:44: QUOTE(bolidu @ 27 Dec 2009, 12:13) Pai daca il descompletez atunci nu o sa mai am ce face cu restul componentelor. Daca nu te intereseaza tot subwooferul, eu pot scoate din el ce doresti, si iti trimit componentele, dar la pretul de 40 lei + taxe de expediere. Aici ai fi in avantaj, pt ca nu te taxeaza suplimentar pt greutate. Ce zici? This post has been edited by Lord Hades: 27 Dec 2009, 12:44 |
OOOO
A3
bolidu |
27 Dec 2009, 16:03
Cand era bun, se auzeau toti satelitii ? Basu` se auzea bine ? Daca lasi subwoferul cu totu la 30 il iau. De preferat ar fi sa iei si transpormatorul din el ca atarna degeaba. Daca il trimiti si prin posta pana la Medgidia batem palma. Evident ca eu platesc taxele de transport.
Solenza Confort
Opel Astra Coupe
Lord Hades |
27 Dec 2009, 18:01
@bolidu, ce zici de 35 lei? Si scot orice nu iti trebuie din el.
De auzit se auzea perfect, satelitii nu au avut niciodata nicio problema. Basul la fel, daca se foloseste o sursa audio buna se aude frumos. O singura chestiune, acum 1 an s-a ars integratul de putere pt subwoofer, si l-am schimbat eu (evident cu unul identic), ba am adus si imbunatatiri (inlocuit cabluri parlite sa nu faca vreun scurtcircuit, pasta conductoare termic intre integrat si racitor ...) si de atunci a mers impecabil. Daca vrei iti trimit poze cu interiorul subwooferului sa nu zici ca ti-am dat plasa cand il desfaci. Transformatorul a intrat in scurt, bobinajul care alimenteaza subwooferul a facut treaba asta. Cand s-a ars integratul, a facut un mic bum si presupun ca a suprasolicitat transformatorul, lacul izolant s-a subtiat, sau probabil spirele au inceput sa se frece una de alta si in cele din urma inevitabilul s-a produs. Daca reuseam sa gasesc transformator il reparam, dar nu gasesc transformator si caut de mai bine de 1 luna. Asa ca mai bine il dau pe bucati sa fac un bine altora decat sa il arunc. totusi am nevoie de bani sa imi iau altceva, si 100 lei e cat vreau sa scot din vechiul sistem. De trimis la Medgidia il trimit cu placere ca nu e greu. Te astept cu o oferta finala |
OOOO
A3
bolidu |
27 Dec 2009, 18:39
Da man e ok. Iti las pe pm adresa si id de mess sa vb mai lejer.
This post has been edited by bolidu: 27 Dec 2009, 18:39 |
Solenza Confort
Opel Astra Coupe
Lord Hades |
28 Dec 2009, 23:27
OOOO
A3
Lord Hades |
30 Dec 2009, 13:10
Se poate inchide multumesc
pentru cablu si telecomanda voi deschide alt topic, acesta nemaireflectand realitatea. This post has been edited by Lord Hades: 30 Dec 2009, 13:11 |
OOOO
A3
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 23rd April 2024 - 23:10 |
