Detalii dupa seria VIN, Informatii dupa numar identificare Dacia
espacern |
1 Jun 2014, 12:15
ART-ist Group: Moderatori Posts: 17.600 Joined: 14 August 09 From: Mihalaya |
- . RENAULT are mistere pe care OMUL nu va reusi niciodata sa le afle!
espacern |
2 Jun 2014, 15:46
Exemplu de informatii pentru VIN:UU1KSDAFH41043732.
@+ Attached File(s) VIN.txt ( 3.88k ) Number of downloads: 1717 |
espacern |
7 Aug 2014, 11:40
shteffanivlad |
7 Aug 2014, 11:53
Membru cu ESP/ASR Group: Members Posts: 691 Joined: 2 July 07 From: Bucuresti |
Multumesc mult de tot, rapid ca de obicei.
This post has been edited by shteffanivlad: 7 Aug 2014, 11:54 |
Megane II.2 Sedan Privilege 1.5dCi
Ianuarie 2008 / LMSE
- B-81-LXV iGO Primo cu Ioana
Statie CB TTi cu antena pe plafon |
BennyORWO |
11 Feb 2015, 00:35
Membru autentic Group: Members Posts: 403 Joined: 10 June 11 From: Alexandria-TR |
Buna seara.
Am si eu nevoie de putin ajutor. Pot afla data exacta de fabricatie a daciei mele?anul este 1994,dar posibil din aceste serii sa fie stantate ziua si luna? Attached thumbnail(s) IMG_20150209_195448.jpg ( Size: 2.72mb ) Number of downloads: 1096 |
Daewoo
Nubira 3
- TR-09-BEN Dacia 1410 Break CN2 1994 B-65-LYL
11 Feb 2015, 10:17
Academician doctor inginer, savant de renume mondial Group: Moderatori Posts: 7.444 Joined: 11 November 03 From: Bucuresti |
nu
poti gasi in schimb luna si anul diverselor repere (alternator, bobina inductie, cutie sigurante, pompa benzina) si asa iti faci o idee cam cand a fost produsa masina. |
espacern |
11 Feb 2015, 16:43
Informatii complete doar pentru Dacia By Renault cu serie VIN.....ca modelul din #2.
djcristi |
1 May 2015, 19:58
Membru autentic Group: Members Posts: 3.944 Joined: 5 October 09 From: Bucuresti / Pitesti |
QUOTE(Ov @ 11 Feb 2015, 11:17) nu poti gasi in schimb luna si anul diverselor repere (alternator, bobina inductie, cutie sigurante, pompa benzina) si asa iti faci o idee cam cand a fost produsa masina. in general pt Renault-uri: pe diagnoza la data de programare a ECU-ului. This post has been edited by djcristi: 1 May 2015, 19:59 |
Megane 2.2
03/2008 Estate 1.5dci euro4 76kW FAP business
- DJC Dacia Logan euro4 1.5dci 50kW(68ps) ambition (fab oct-2007)
VanCroft |
13 Jun 2015, 16:58
Membru incepator Group: Members Posts: 1 Joined: 13 June 15 |
Buna , ma ajuti si pe mine cu informatii despre: UU1LSDEKF38038439
Preference
2007/diesel
aysmen89 |
14 Jun 2015, 14:25
Membru autentic Group: Members Posts: 241 Joined: 26 April 08 |
Pt o solenza se poate afla ceva?
UU1R5A71533361815 Multumesc |
Solenza Scala
djcristi |
20 Jun 2015, 00:41
Megane 2.2
espacern |
20 Jul 2015, 16:47
QUOTE(aysmen89 @ 14 Jun 2015, 14:25) Pt o solenza se poate afla ceva? Se poate....sigur! Attached File(s) Solenza.txt ( 2.25k ) Number of downloads: 249 |
blu3z |
22 Dec 2015, 09:33
Membru incepator Group: Members Posts: 12 Joined: 17 February 15 |
Salutare,
As dori detalii despre un sandero cu vin-ul UU1BSDBNH41637315 daca se poate. Merci! This post has been edited by blu3z: 22 Dec 2015, 09:34 |
1987
- BH-PRP-73
espacern |
22 Dec 2015, 09:41
Am trimis PM.
shteffanivlad |
22 Jan 2016, 10:31
Ma poti ajuta cu detaliile pentru UU1OSDA4549202948 ?
Multumesc anticipat. |
espacern |
4 Feb 2016, 19:54
Am trimis PM.
uniger2003 |
9 Feb 2016, 11:19
Membru incepator Group: Members Posts: 30 Joined: 5 August 10 From: Braila |
Salut! Nu am destule posturi ca sa dau pm, asa ca iti scriu aici. Am nevoie, daca poti, de un cablu de ambreiaj cod 7700431360. Multumesc anticipat!
Logan 1.4MPI + GPL (fabrica)
espacern |
9 Feb 2016, 17:31
Ai gresit adrisantul.....si topicul!
gastorro |
8 Feb 2017, 12:57
Membru Group: Members Posts: 184 Joined: 27 September 15 |
mutat in alta parte
This post has been edited by gastorro: 9 Feb 2017, 11:43 |
Megane2 facelift 1.4 16v K4J740
2006.12
- CYO-274
djcristi |
8 Feb 2017, 18:44
topicul actual este aici
Megane 2.2
espacern |
9 Feb 2017, 13:54
Aici pe acest topic se ofera informatii despre Dacia.....si atat!
gastorro |
9 Feb 2017, 15:02
Multumesc espacern
Nu mai stiu ce sa cred despre motorul asta ! ( UU1BSDBHH41395858 ) Pe haionul ei scrie Hi-Flex si eco2 iar asta inseamna ca merge si cu E85 (Etanol cu 15% benzina), Dar in pliantul asta scrie ca motorul ar fi K4M 696 cu 8 valve (desi in capul aceluiasi tabel scrie Motorversion 1,6 16V HI-FLEX) 1.6MPI_Hi_Flex_eco2.jpg ( Size: 251.18k ) Number of downloads: 671 Eu o alimentez acum numai cu bezina de 95 (si pare ca-i ok). Intrebare: Ce anume este diferit la motorul asta fata de unul care merge doar pe benzina? This post has been edited by gastorro: 9 Feb 2017, 19:44 |
2006.12
- CYO-274
espacern |
10 Feb 2017, 21:37
QUOTE(gastorro @ 9 Feb 2017, 15:02) Intrebare: Ce anume este diferit la motorul asta fata de unul care merge doar pe benzina? Datorita setarilor din calculatorul de injectie se poate alimenta cu E 85....fara probleme ulterioare. |
uniger2003 |
13 Feb 2017, 10:23
Salut! Va rog, daca se poate info despre vin: VF1BG0M0528136403. Am logan, dar m-am hotarat sa trec la laguna si as vrea un istoric de service, sau kilometrii la ultima intrare intr-un service autorizat + nivel echipare/optiuni. Nu ma pricep la laguna si nu stiu la cine altcineva sa apelez. E vorba de masina asta: https://www.autovit.ro/anunt/renault-laguna...html#8bf243473f
Va multumesc in avans! 13 Feb 2017, 20:58: Multumesc frumos," espacern"! Nu am suficiente posturi sa dau pm, dar e vreo sansa sa afli nr. de kilometri la ultima intrare intr-un service autorizat? Vanzatorul zice ca masina are 138000 acum si vreau sa stiu cu cat i-a dat inapoi. Multumesc inca o data! O seara buna! This post has been edited by uniger2003: 13 Feb 2017, 20:58 |
rav |
21 Jul 2017, 02:34
Membru incepator Group: Members Posts: 9 Joined: 22 October 16 |
Mă poți ajuta și pe mine cu detaliile despre Lodgy-ul cu seria de șasiu UU1JSDBC650535887?
Lodgy
2014 Laureate 1,5 dCi 107 CP
tudormihai87 |
3 Oct 2017, 20:02
Membru incepator Group: Members Posts: 2 Joined: 23 September 17 |
Buna seara,
Ma intereseaza si pe mine detaliile pentru urmatoarea serie UU1LSDAEH40184361 Tocmai ce am cumparat masina si incerc sa aflu cat mai multe despre ea ( dotari/ caracteristici). Multumesc. |
espacern |
4 Oct 2017, 08:08
Am trimis PM.
tudormihai87 |
4 Oct 2017, 12:51
Din pacate nu am suficient acces si nu pot intra in PM.
miki |
25 Jan 2018, 14:02
#Hırsızlargibigeceniniçine Group: Members Posts: 1.002 Joined: 30 July 02 From: Bucuresti |
Ziua buna
Pentru asta UU1HSDJ9G57448122 se pot da informatii? Merci mult |
Sedan 1.6 16V / Megane IV 1.33 TCE
2004 / 2019
- XX-B-XXX #Hırsızlargibigeceniniçine
Funken Kurbelwelle Uzun Araç! Değer Așılırsa |
25 Jan 2018, 14:13
fan Dacia Group: Members Posts: 19.908 Joined: 12 November 05 From: Bucuresti |
in septembrie avea 7400 km, K9K serie blackshadow, comenzi pe volan, medianav harta europa de est
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 25th April 2024 - 17:28 |
