Crash-test Logan, Chiar asa...
3 Jan 2005, 13:00
Attached File(s) AB_Motors___ESSAI_LOGAN_crash_test_1.avi.zip ( 792.74k ) Number of downloads: 2663 |
Manuel |
3 Jan 2005, 13:24
Membru autentic Group: Members Posts: 4.116 Joined: 27 November 02 From: VASLUI |
Apropo, am prins un crampei dintr-o editie Auto Motor Und Sport preluata de pe DW. In final, anuntau ca urmatoarea emisiune va contine un test comparativ Golf V - Dacia Logan. Daca stiti cand urmeaza sa fie difuzata, spuneti si aici...
Ca fapt divers, am prins un test comparativ BMW seria 5 break (90.000 euro) si Lada break (10.000 euro). Toate bune pana cand Lada n-a mai vrut sa porneasca. A fost distractiv... |
Astra J Sports Tourer Active
2013 / 2.0 CDTI / 165CP
- VS15CMA "Base e un bou betiv." (corbex)
luck |
3 Jan 2005, 14:20
Membru incepator Group: Members Posts: 84 Joined: 1 November 04 From: Buc. --> Rahova ... |
Poate nu pricep eu asa ca luminati-ma si pe mine cum se deschide ca winzipu nu-l deschide ...?
Zice asa : QUOTE Cannot open file : it does not appear to be a valid archive. If you downloaded this file, try downloading the file again. Am facut si tot degeaba , d c ? .... |
2005 Laureate 1.4
- B-xx-LCN. traieste clipa ....
Wolfman |
3 Jan 2005, 14:24
The Fastest Group: Members Posts: 483 Joined: 9 July 04 From: Murciélagos |
Pai n-a zis klaus ca trebuie sa-i stergi extensia zip (fisierul este de fapt .avi)?
MOKKA X
1.4 T 2019 "Cu stinga nici cruce nu poti sa-ti faci, daramite sa conduci o tara!" Petre Tutea
maxx |
3 Jan 2005, 15:18
Megane Renault Sport 2.0 Turbo 225hp, 6 speed, 0 - 100 6,5s Group: Members Posts: 401 Joined: 26 September 04 From: Bucuresti - Tei |
pai nu au zis nimic de niste "stelutze" ???
Logan Ambition Perla
- B 62 DRB ---- RENAULT -- NISSAN -- DACIA ----
luck |
3 Jan 2005, 15:44
Am facut asa. da' nu mergea pana am reusit cu media playeru' mai vechi ., 10 x.
2005 Laureate 1.4
gindanezu |
3 Jan 2005, 20:14
Membru incepator Group: Members Posts: 7 Joined: 20 November 04 From: Bucuresti |
n-am reusit sa inteleg...la ce viteza e facut cras-ul ?
logan 1.6 laureate
- B 40 FPM
tazzz |
4 Jan 2005, 05:34
Membru autentic Group: Members Posts: 521 Joined: 26 August 04 From: Iasi - Romania |
am incercat in fel si chip si nu am reusit sa copii fisierul...amincercat in Opera si in Internet Explorer si am incercat si in Flashget si totusi n-am reusit sa copii nimic...direct in browsere cu save target si cu Download with Flashget...si tot n-a vrut
aveti vreo explicatie? |
Laureat 1.6
- IS XX TAZ si aici ar fii semnatura nu? :)
smar2 |
4 Jan 2005, 13:00
Membru incepator Group: Members Posts: 77 Joined: 13 December 04 From: Germania |
Banuiesc ca viteza de impact a fost cea standard folosita la testele EuroNCAP (65km/h).
Dar nu stiu de ce estimeaza doar 3 stele, ca habitaclul nu pare sa sufere deformari. Se sparge doar parbrizul. O fi de la centuri varza + airbag slab? Sau intra piese prin bord? Sau ca n-are aproape deloc protectie laterala? Practic are cat Matizul SE (ala cu ranforsari in usi si airbag). Nu e cam putin? This post has been edited by smar2: 4 Jan 2005, 13:01 |
Logan MCV
Laureate 1.6MPI
- HSK-.....
brunner |
4 Jan 2005, 15:07
Membru autentic Group: Members Posts: 220 Joined: 25 January 04 From: ... |
QUOTE(smar2 @ 4 Jan 2005, 15:00) Dar nu stiu de ce estimeaza doar 3 stele, ca habitaclul nu pare sa sufere deformari. Se sparge doar parbrizul. O fi de la centuri varza + airbag slab? Sau intra piese prin bord? Sau ca n-are aproape deloc protectie laterala? Ziceau ei ca nu pot lua 4 stele, ca n-au airbaguri laterale. |
M
M
1
maxx |
4 Jan 2005, 15:59
la patru stele tre' sa ai centuri cu senzor de tensiune, nu airbag-uri laterale...
mai mult ca sigur la versiunea cu face-lift (peste cativa ani) va avea asa ceva... |
smar2 |
4 Jan 2005, 16:46
e... cine mai sta cativa ani... ne luam de-asta acum, si ne pocnim doar frontal, ca sa beneficiem cat mai mult de airbaguri, si cand ne-om lua dacia logan2, cu airbag lateral, toracic, cortina si de alte tipuri, o sa putem sa ne lovim din toate directiile...
sper totusi sa nu trebuiasca sa verific eficienta centurilor+airbag, ceea ce va doresc si voua... |
Logan MCV
Laureate 1.6MPI
- HSK-.....
m-power |
4 Jan 2005, 23:08
Membru Group: Members Posts: 108 Joined: 9 December 04 From: Iasiington |
Eu ma declar multumit de crash-test. Am vazut si mai rau.....
Ambiance
- IS xx DAM Daca nu aici...cand??
Daca nu acum....unde ???!? |
vad |
6 Jan 2005, 20:49
Membru Group: Members Posts: 184 Joined: 18 July 04 From: Bucuresti |
ma scuzati ca intervin, dar imginile sunt din prezentarea LOGAN din FRANTA, sunt aceleasi iamgini ce rulau (din cate imi amintesc eu) pe un panou langa masina deja botita in uzina RENAULT unde a fost lansat modelul! posibil ca aceste imagini sa fie preluate de la renault si nu sa fie filmate de cei ce au realizat emisiunea!
laureate 1.6
- bz xx vad iaca si eu pe aici ma bag in seama ... poate invat si eu cate ceva de la cineva ... sau mai invata si altii de la mine!
7 Jan 2005, 12:26
Da' cine a zis ca au facut aia de la emisiune crash-testul?
vad |
7 Jan 2005, 15:46
ok, poate a fost o neintelegere, insa eu vroiam sa reliefez ca este facut de cei de la reanault si deci, rezultatele pot fi putin trase de par, NU?
bine nu din ceea ce se vede doar ci din rezultatul final al parametrilor! |
laureate 1.6
St |
8 Jan 2005, 21:41
Membru Group: Members Posts: 4.436 Joined: 18 July 04 From: Bucuresti |
Mai, dar Crash-test-ele se fac pe versiunea de baza(ambiance in cazul logan), sau pe versiune full options, la logan Ambition?
Mazda/ BMW
MX-5/ 650GS
2012/ 2004 Fericirea este ceva ce nu se atinge niciodata,dar in cautarea ei merita sa alergi toata viata.
maxx |
8 Jan 2005, 22:26
yo cred ca se fac pe verisunea full...
n.vasiliu |
13 Feb 2005, 02:06
Membru Group: Banned Posts: 119 Joined: 12 February 05 From: Bucuresti |
Daca o sa va uitati la jenti la masina care sufera impactul o sa vedeti ca sunt de ambition (full). Pe cand masina pe care ei o "imping" pana la crash test are alte jenti.
DACIA/Renault
LOGAN Ambition 1.6
cristush |
13 Feb 2005, 04:11
Membru incepator Group: Members Posts: 38 Joined: 24 January 05 From: Bucuresti |
Preference 1,4MPI
- B-xx-xxx
Andy LGN |
13 Feb 2005, 14:17
Membru Group: Members Posts: 107 Joined: 28 August 04 From: Bucuresti |
Vai domne' are DOAR 3 stele. Vai Vai Vai ce ne facem ?
Aloooo. Unele Mercedesuri au 4 stele. STIATI ? Exista si 4x4 cu 4 stele (vezi Hyundai Santa fe:wub: Logan se pare ca nu are cum sa ia 4 stele din cauza lipsei airbag-urilor laterale. |
Skoda
Octavia 2 TDI
- B-xx---- Noi, romanii, am stat pe malurile istoriei si ne-am uitat la altii.
Phileas |
13 Feb 2005, 14:44
Membru Group: Members Posts: 108 Joined: 28 October 04 From: Bucuresti |
daca va uitati mai atent la filmulet se observa ca se deformeaza si plafonul nu numai parbrizul. mie asa mi se pare.
SupeRNova
2002 Rapsodie
SorinTSI |
13 Feb 2005, 14:48
Membru Group: Members Posts: 125 Joined: 17 November 04 From: Bucuresti |
Voi stiti cum se fac testele astea?Conteaza cat de deformat e habitaclul,daca soferul intra in contact cu plansa de bord,cu pedalele,cat de mari sunt fortele inregistare la manechin.Nu conteaza cate airbaguri ai.:3 stele are si Matizul. Adica la ala daca i-i pui airbaguri laterale o sa aiba 4 stele?
Da,sunt si BMW cu 4 stele (mai precis noua seria 5).Si cu ce te ajuta asta?Te simti cumva mai bine in masina ta cand i-l vezi pe unul cu un 545 ca trece pe langa tine? |
BMW
530D
2006 E60
chiriac.costin |
13 Feb 2005, 15:17
Membru incepator Group: Members Posts: 81 Joined: 26 January 05 From: Constanta |
Chiar nimeni nu observa un astfel de detaliu?...Testul NU este facut de Renault ci de UTAC (se poate observa inscriptionat pe masina de test).UTAC este controlul calitatii in Franta,asa cum este Euro NCAP in Europa.Nici o masina incadrata in aceasta categorie de pret nu poate scoate mai mult de 3 stele la nivelul de astazi
Logan Ambition
- CT 01 POL
GeorgeB |
13 Feb 2005, 15:23
the 7 stars of Pleiades constellation Group: Members Posts: 1.870 Joined: 7 January 03 From: Bucuresti |
asa si ?
SUBARU
Legacy 2.5
chiriac.costin |
13 Feb 2005, 15:43
Era un raspuns pentru vad care sustinea ca testul este subiectiv si este facut de Renault si klaus care intrebase cine a facut testul. |
Logan Ambition
- CT 01 POL
m-power |
13 Feb 2005, 16:46
QUOTE(n.vasiliu @ 13 Feb 2005, 00:06) Daca o sa va uitati la jenti la masina care sufera impactul o sa vedeti ca sunt de ambition (full). Pe cand masina pe care ei o "imping" pana la crash test are alte jenti. Cu si guranta s-au testat mai multe masini. Cred ca macar variantele de la extreme: Ambiance si Ambition. (Off topic: Oare berlineza cate stele ar lua?) |
Ambiance
Bogdan_F |
13 Feb 2005, 17:13
Membru autentic Group: Members Posts: 335 Joined: 30 June 03 |
Salut tuturor.La EuroNCAP sunt mai multe teste la care loganul a facut fatza destul de bine.
1. IMPACTUL FRONTAL: aici sincer sa fiu, din ce am vazut in inregistrare cred ca merita din plin 4 stele. Nu cinci pentru ca nu are centuri de siguranta cu limitator de tensiune si airbaguri dual-stage. Prin urmare e posibil ca fortele inregistrate de manechin sa fie destul de mari. Deformarea habitaclului a fost minima si cred ca usa s-a putut deschide normal, fara mare efort. 2. IMPACTUL LATERAL CU UN CORP DEFORMBIL + IMPACTUL LATERAL CU UN STALP - aici cred ca ar merita cam 2 stele, pentru ca nu are airbaguri laterale ci doar bari de impact in usi. E posbili ca manechinul sa fi avut un contact destul de dur cu montantul B. de aceea nu cred ca loganul o sa ia mai mult de 3 stele. oricum, sincer sa fiu, Kia Picanto, care este o masina aparuta in 2004, tot 3 stele a inregistrat, asa ca nu vad nici o problema.... Poate totusi, vor introduce cei de la Dacia niste airbaguri laterale (cap+torace) macar optional (mai mult de 4-500 euro nu au cum sa coste) |
Ford Fiesta
1.4 TDCi
m-power |
13 Feb 2005, 18:05
Ambiance
osirus |
13 Feb 2005, 22:27
Milionar de week-end Group: Banned Posts: 501 Joined: 17 November 04 From: Salajan |
Dacia/Skoda
Logan ambition
- Octavia L&K vreau o rabla de masina ca sa-i rup kilometraju s-o petarda buna rau sa-i dau jos ambalaju
................"Fac sport extrem cu dacia/Cu ochii inchisi o calc/I-mi place senzatia!"............... |
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 11th May 2024 - 04:47 |
