cod casetofon, cod casetofon sansero stepway
cretuovi1985 |
7 Sep 2015, 15:50
Membru incepator Group: Members Posts: 1 Joined: 7 September 15 |
dacia sandero
dacia sandero
2011 dacia sansero stepway 1.6
- tm 90 rxy
sandero2 |
12 Sep 2015, 10:58
Membru incepator Group: Members Posts: 21 Joined: 5 March 15 |
La mine codul este trecut în factura de cumpărare a mașinii.
Logan, Sandero Stepway
2007, 2015
- MH 03 TFE
kelu84 |
18 Jan 2016, 23:04
Membru incepator Group: Members Posts: 1 Joined: 18 January 16 |
Salut si scuze de deranj am si eu un Stepway si am dat jos bateria si imi cere un cod si nu il stiuVa rog frumos daca ma puteti ajuta UU1BSDBLK46737059
Attached thumbnail(s) 20160118_230254.jpg ( Size: 436.11k ) Number of downloads: 258 |
sandero stepway
2012 1.5dci
- 8333 HJS
valeriu_50 |
30 Aug 2020, 19:41
Membru incepator Group: Members Posts: 1 Joined: 30 August 20 |
buna seara !
am si eu aceasi problema ! am cumpararat sun sandero din germania second dar nu am primit codul de deblocare , am uitat din graba sa-l cer si acum .... nu-l am !! . poate sa ma ajute cineva si pe mine cu codul de deblocare ! am sa atasez poza de pe spatele radioului si VIN - ul masinii !! VIN - UU1BSDA3K44586411 , 1,6 MPI VA MULTUMESC !! This post has been edited by valeriu_50: 30 Aug 2020, 19:50 Attached thumbnail(s) BLAUPUNKT.png ( Size: 430.12k ) Number of downloads: 210 |
sandero stepway
2011 , 1,6 MPI
RazvanF |
1 Sep 2020, 06:19
Tech Group: Members Posts: 2.284 Joined: 25 March 14 |
Posibil 2937
Logan MCV Stepway X52
Bicicleta galbena |
19 Sep 2022, 17:27
Sunt nembru, domnule! Group: Members Posts: 2.056 Joined: 29 January 13 From: Bucuresti |
Rog ajutor cod radio pt VIN:
UU15SDE3355641423 Mercic. |
Peugeot
407 1.8 16v
2005 , ex-Dacia Solenza 1.4 Mpi 2003 ____________________________
Gil26 |
19 Sep 2022, 20:02
Membru autentic Group: Members Posts: 3.096 Joined: 10 May 20 |
Salut,
Dupa seria VIN codul de deblocare se poate afla doar in reprezentanta. Dar daca doresti poti scoate aparatul iar pe eticheta ai datele pre-code, ultimele patru caractere, de obicei o litera si trei cifre (sau poti incerca sa apesi tastele 1 si 6 cateva secunde si apare precode) apoi acestea le poti introduce pe acest site (vezi si ex de acolo cu precode): Link site code generator click pe "Get radio code" si se obtine codul din patru cifre... (sau poti sa atasezi aici o poza cu eticheta de pe aparat si iti oferim codul) This post has been edited by Gil26: 19 Sep 2022, 20:08 |
2017
Bicicleta galbena |
19 Sep 2022, 20:15
Mercic Gil, am vazut pe yt cum se scoate radioul, incerc maine operatiunea.
Stai asa: tastele 1 si 6 sunt cele din afisajul pt cod? Deci n-ar mai fi nevoie sa scot fizic radioul? This post has been edited by Bicicleta galbena: 19 Sep 2022, 20:17 |
Peugeot
407 1.8 16v
Gil26 |
20 Sep 2022, 05:17
Da, poti incerca sa apesi si tastele 1 si 6 consecutiv pentru cateva secunde si poate iti apare pre-code (asta insa depinde de aparat), daca nu apare atunci trebuie demontat aparatul, pentru demontare la acest SanderoII rosu 2016 cu radio RAD28C si fara navigatie eu am gasit doar vederea explodata a plansei de bord (vezi atasat), dar daca doresti poti pune si link-ul cu acel fimulet, poate sa fie de folos si altor colegi.
Cu acest pre-code se obtine codul de deblocare din patru cifre, pentru introducerea codului se poate vedea si manualul de utilizare, trebuie avut grija, daca se introduce codul gresit de obicei apare mesajul CODE (insotit si de un beep), trebuie asteptat cu aparatul alimentat un timp care creste functie de nr. de introduceri gresite (ex ½, 1, 2..24 ore), apoi se apasa butonul Power pe ecran apare CODE dupa care ”0000” si se poate introduce codul, de obicei prima cifra ”0” clipeste, se apasa tasta "1" pentru prima cifra a codului de cate ori este necesar apoi al doilea ”0” clipeste si se apasa tasta ”2” pana la cifra corecta, la fel pentru tastele ”3” si ”4”, apoi la sfarsit se apasa tasta ”6” lung (cam 5 secunde) se aude un beep si... gata, dar asta depinde si de aparat. (contorul de introduceri gresite se poate reseta scotand \scriind eeprom, la fel daca aparatul este blocat se poate debloca dar trebuie cineva care stie ce \cum face) Am precizat toate acestea pentru ca cine cauta \doreste informatii despre codul de deblocare poate sa le gaseasca intr-un singur loc (chiar daca despre unele s-a mai discutat si pe alte topice dedicate). Drumuri bune! (si cu radio OK) Attached thumbnail(s) PlansaBord.png ( Size: 616.39k ) Number of downloads: 151 RadioCode.png ( Size: 415.87k ) Number of downloads: 149 |
2017
Bicicleta galbena |
20 Sep 2022, 17:15
Mercic Gil, s-a rezolvat mult mai simplu - colegul a fost la o reprezentanta Dacia si doar pe baza VIN i-au comunicat codul radio. Eu venisem pregatit cu surubelnite sa desfac etc, n-a mai fost cazul
Peugeot
407 1.8 16v
Gil26 |
1 Oct 2022, 13:50
Desigur ca asa cum am scris si in postul #7 codul radio se poate obtine pe baza seriei VIN si in reprezentanta.
Dar se poate incerca la fel de simplu si usor sa se apese consecutiv tastele #1 si #6 pentru aprox 10 secunde apoi se elibereaza tasta #6 si dupa cam 3 secunde tasta #1 iar precode apare pe ecran (din graba am uitat sa scriu si asta), lucru testat pentru unele aparate si de cativa colegi de forumuri. |
2017
georgstelsib |
1 Oct 2022, 14:37
Membru Group: Members Posts: 136 Joined: 17 May 15 |
Consecutiv sau Simultan ? Fiindca inseamna cu totul si cu totul altceva . Nu sunt sinonime . Consecutiv inseamna succesiv , adica unul dupa altul , nu in acelasi timp . Tu cum ai operat pe "masinile " tale ? Consecutiv sau simultan ? fiindca vad ca-i inveti pe altii ...
Gil26 |
1 Oct 2022, 14:47
,si acest post al tau este in stilul "caracteristic", doar flame si polemica, nu ajuta pe nimeni cu absolut nimic
Iar daca iti face asa mare placere se apasa simultan timp de 10 secunde si se elibereaza consecutiv la interval de 3 secunde (tasta 6 apoi tasta 1), si repet ca astfel i-am ajutat pe cativa colegi de forumuri, pe masina mea nu am avut nevoie sa "operez" pana acum, plus ca am integrat un generator de coduri si deblocare, dar am si codul primit la achizitionarea masinii . This post has been edited by Gil26: 1 Oct 2022, 14:52 |
2017
georgstelsib |
1 Oct 2022, 14:55
Bravo , asa da . Deci SIMULTAN si nu consecutiv , fiindca daca-ti urma cineva metoda nu ajungea niciodata la vreun rezultat . Bravo , felicitari pentru "erata".
Gil26 |
1 Oct 2022, 14:56
Si pana acum au fost colegi care au urmat metoda pe care le-am spus-o si au ajuns la rezultat. Iar daca tot vrei sa te dai asa mare "profesor" : nu este vreo "erata", se pot apasa si CONSECUTIV tastele #1 si #6 la un interval foarte mic de timp iar efectul \rezultatul este acelasi. This post has been edited by Gil26: 1 Oct 2022, 15:32 |
2017
Bicicleta galbena |
1 Oct 2022, 16:56
The war ain't over!
Peugeot
407 1.8 16v
georgstelsib |
1 Oct 2022, 18:38
Mare , mic , dar profesor si... nu-i plac "profesorii" fara diploma . Acestia "put" de departe a incultura si proasta crestere .
This post has been edited by georgstelsib: 1 Oct 2022, 18:40 |
Gil26 |
1 Oct 2022, 18:47
Tot offtopic, fara rost\sens, si ca in toate posturile tale tot "pe invers"
(dar macar te-ai "caracterizat" bine\corect cu " ...de departe a incultura si proasta crestere" ) This post has been edited by Gil26: 1 Oct 2022, 18:50 |
2017
Dom Vasi |
7 Nov 2022, 07:55
Membru incepator Group: Members Posts: 28 Joined: 5 November 22 |
Ptr un radiocd Blaupunkt de logan se poate face vreo modificare sa nu imi mai ceara codul de 4 cifre cand decuplez bateria?
Urc o poza cu aparatul image__1_.jpeg ( Size: 298.58k ) Number of downloads: 69 eventual vreo modificare pe placa,un strap. Nu sunt electronist,dar am la cine sa apelez daca mi se spune mura in gura pe schema aparatului ce trebuie facut. This post has been edited by Dom Vasi: 7 Nov 2022, 08:02 |
Ambiance 1,5dci 65cp
7 Nov 2022, 11:06
fan Dacia Group: Members Posts: 19.774 Joined: 12 November 05 From: Bucuresti |
ori iti iei o jucarie dina sta https://www.feuvert.fr/outillage-specialise...9hoC1eUQAvD_BwE ori scrii codul undeva in masina. Pe ala oricum nu-l fura nimeni.
Dom Vasi |
7 Nov 2022, 12:41
Am codul de pe factura de cand am cumparat masina.Credeam ca se poate face ceva sa se bypaseze introducerea codului de fiecare data cand scoti bateria ...
7 Nov 2022, 12:56
nu mai bine iei un radio aftermarket (zgomootec sh chiar) care oricum suna mai bine? Dect sa dai bani pe modificat ala? Protectia cred ca e din soft totusi, nu HW.
Dom Vasi |
7 Nov 2022, 13:52
Am un pioneer deh2800mp de cand aveam oltcitul. Doar ca pe radio cel mai multumit sunt de cel de pe logan.
Cu cel de pe oltcit nu prindeam asa multe posturi |
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 28th March 2024 - 22:35 |
