current 5V, 500mA
current 5V, 500mA
jocker |
14 Jun 2010, 19:31
Membru incepator Group: Members Posts: 20 Joined: 23 July 05 |
logan laureate 1.4 MPI
- Makedonija
psychoo |
14 Jun 2010, 20:44
Membru Group: Members Posts: 3.415 Joined: 23 August 07 From: Timisoara |
LM2596 is a 3A switching voltage regulator, so you have less power dissipation on higher current consumption. it comes n 12V output, 5V output or adjustable output.
it only needs a few external components: 3 capacitors, 2 resitors and one coil, the values of theese components can be found in product datasheet. it`s cheap and reliable. |
Focus
jocker |
14 Jun 2010, 21:21
QUOTE(psychoo @ 14 Jun 2010, 19:44) LM2596 is a 3A switching voltage regulator, so you have less power dissipation on higher current consumption. it comes n 12V output, 5V output or adjustable output. it only needs a few external components: 3 capacitors, 2 resitors and one coil, the values of theese components can be found in product datasheet. it`s cheap and reliable. I did a little googling about this LM2596... and I see that this is simple switcher power converter. So where should I connect this semi conductor, and how should this electric circuit look like? |
- Makedonija
psychoo |
14 Jun 2010, 21:28
i posted a picture with the schematic for LM2596-5V output and the complete datasheet.
you just need to connect it like in the schematic, on the input line you feed it 12V from car socket and on the output you have the +5V regulated. cheers Attached thumbnail(s) Untitled.jpg ( Size: 56.41k ) Number of downloads: 471 Attached File(s) lm2596.pdf ( 734.75k ) Number of downloads: 48 |
Focus
jocker |
15 Jun 2010, 15:49
Thanks for your help, I really appreciate.
Will try to find this LM2596 these days, and see to connect it right. |
- Makedonija
15 Jun 2010, 15:56
fan Dacia Group: Members Posts: 19.912 Joined: 12 November 05 From: Bucuresti |
5V sound exactly like the tension used for various sensors by the ECU, but I wouldn't tamper with that. The solution above is much better.
marksman |
15 Jun 2010, 16:43
Post mortem nihil est Group: Members Posts: 7.464 Joined: 1 November 04 From: sat |
Opel / Mazda
Crossland X / CX-30
2019 / 2020 Charlie Foxtrot
g100sic |
16 Jun 2010, 09:46
Membru autentic Group: Members Posts: 313 Joined: 4 January 07 From: Serbia |
On the schematic above it is stated that input voltage is UNREGULATED 12V, but since the car battery as a voltage source can be considered (highly) regulated, you can eliminate that first condenser on the input from the design, and save a bit (veeeeeery little, though O:))
Fiesta 1.4 (96 HP)
2010 / Trend (Flex Pack 11) Never argue with a fool -- people might not notice the difference! (Murphy's First Law of Debate)
psychoo |
16 Jun 2010, 10:25
wrong! the car battery voltage isn`t well filtered. it has lots of spikes from the electric windows, fan or even alternator. It is recomended that you use the minimum filtration wich is provided in that schematic.
In this case "unregulated" means the input voltage, wich is different than the regulated 5V output |
Focus
DannyY |
16 Jun 2010, 10:29
Marele plictisit Group: Members Posts: 1.695 Joined: 5 May 09 |
Don't!
That capacitor filters the noise produced by various inductive elements. I would suggest even its replacement with a larger capacity one... |
Opel/Honda/Opel
Astra G/Civic 4D/Corsa E
2004/2015/2019
g100sic |
17 Jun 2010, 15:51
The greatest spike the car battery must sustain comes from the electric starter (order of magnitude 100+ Amps), and compared to that any other electric motor in an average car is insignificant.
As for the EMI noise, the biggest source is high voltage ignition/spark plugs. Has anyone actually measured those ripples, spikes and noise on a battery in a working car? I mean, besides specialized laboratories, unavailable to the ordinary public... After all, the man does not need high specs, and even if the voltage on the output isn't 99.999999....% pure, it is used for charging battery in another device, which has it's own regulation, + at least 2 more levels of filtration, etc, etc... Let's not go academic about simple things! This post has been edited by g100sic: 17 Jun 2010, 15:59 |
Fiesta 1.4 (96 HP)
17 Jun 2010, 16:11
The riple is big enough to be seen with an osciloscope. How much could you be saving by dispensing with an ordinary capacitor?
psychoo |
18 Jun 2010, 15:09
The spikes from the electric motor that opens the window fried some transistors and microcontrollers that were filtered according to the technical documentation of the stabilizer. I had to put 7 diodes to protect my device and make it reliable.
I can`t understand why people don`t respect the technical datasheet that comes with a product. Then if the prodct malfunctions or fries another device you`ll say that the step down converter is faulty? If the manufacturer says "put at least that value there" that`s what you should do. If you don`t you cand have trouble. I`d understand if that condenser was expensive but the most expensive costs 0.1 Euro |
Focus
mario1980 |
18 Jun 2010, 18:06
Membru autentic Group: Members Posts: 437 Joined: 8 April 05 From: Iasi |
I would try something simpler: a 7805F (isolated package) linear regulator, mounted somewhere on a large piece of metal, under the dashboard, eventually with a 5.6 ohms, 5W resistor in series with its supply. You don't even need a pcb, and is cheaper.
http://www.datasheetcatalog.org/datasheet/...hild/LM7805.pdf If you can't find isolated version, make sure to electrically isolate it's mounting terminal from the chasis. |
dci Preference 2006
- SV ?? ??? Adesea, aproape fiecare om tolereaza prostia celui de linga el, atit timp cit nu ii uzurpa propria prostie.
psychoo |
18 Jun 2010, 18:26
For non switching step down voltage converters the power dissipation is greater. 14.4V - 5V = 9.4V voltage drop on the regulator. And even this regulator needs capacitors between input-gnd and output-gnd.
If you supply a heatsink you can use the LM7805 with satisfying results. Cheers |
Focus
copros |
21 Nov 2010, 18:21
Membru incepator Group: Members Posts: 7 Joined: 7 June 10 |
psychoo's suggestion seems to be right.
BMW
volvo
- 18765 www.hid-copros.com Profeestional on auto lighting such as hid kits,canbus ballast,led bulbs,canbus led bulbs,bixenon lens,daytime running light.
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 26th April 2024 - 15:02 |
