Please help..., Sort of tehnical question
icatenej |
15 Jul 2005, 10:07
Membru incepator Group: Members Posts: 51 Joined: 15 July 05 From: Belgrade, Serbia |
LGN 1.4 Amb. Pack
- BG 694 668
RIon |
15 Jul 2005, 10:12
pasionat Group: Members Posts: 2.835 Joined: 22 May 04 From: CJ |
Ask Klaus, he's good at this tweaking stuff. And he's doing it for free
Skoda
Octavia 2
- de CJ www.raresion.ro
icatenej |
15 Jul 2005, 10:14
LGN 1.4 Amb. Pack
- BG 694 668
RIon |
15 Jul 2005, 10:17
Klaus is one of our forum's member and moderator, also known as an good tweak master.
http://www.daciaclub.ro/index.php?showuser=73 send him an e-mail or Private Mesage Have a good day! |
Skoda
Octavia 2
AL |
15 Jul 2005, 12:48
I attached for you a picture presenting the necessary operations... Usually you should use a special tool ...but also you could use a screwdriver in order to remove the plastic ... you must use a little force to pull out de plastic part on the direction of the blue arrows...
Attached thumbnail(s) usa_spate.jpg ( Size: 24.15k ) Number of downloads: 375 |
Skoda
KAROQ
2019
- B-21-NEW
icatenej |
15 Jul 2005, 13:12
QUOTE(AL @ 15 Jul 2005, 12:48) I attached for you a picture presenting the necessary operations... Usually you should use a special tool ...but also you could use a screwdriver in order to remove the plastic ... you must use a little force to pull out de plastic part on the direction of the blue arrows... Thanks AL, This would help a lot. Could you please explain as well how to remove window lever. (red arrow on attached picture). Is there any kind of secure mechanism holding lever in place which has to be removed or I should just pull the lever by brute force? Igor. Attached thumbnail(s) usa_spate_1.jpg ( Size: 27.09k ) Number of downloads: 195 |
LGN 1.4 Amb. Pack
- BG 694 668
15 Jul 2005, 13:20
You simply pull it out with some force...
Is fitted with a kind of elastic claws. No problem, just pull it out. PS: the page for rear door... It is in spanish, but i think you can understand it...Pages_from_MR389LOGAN7.jpg ( Size: 244.31k ) Number of downloads: 383 And how it should be done in service... (if they have the tool...)outilages.jpg ( Size: 161.3k ) Number of downloads: 720 |
icatenej |
15 Jul 2005, 13:26
QUOTE(klaus @ 15 Jul 2005, 13:20) You simply pull it out with some force... Is fitted with a kind o elastic claws. No problem, just pull it out. Thanks guys, I think this would be all information I need at this moment. I will try it today. Igor. |
LGN 1.4 Amb. Pack
- BG 694 668
novauto |
15 Jul 2005, 23:32
Membru incepator Group: Members Posts: 38 Joined: 13 July 05 From: Serbia |
Autobest - Dealerworst
Well, this is true story from Serbia. Customer bought Dacia Solenza and now wants to change cassette player with CD player. He asked dealer for advice, does he can do it yourself and answer is NO. Car radio must be replaced at official service. Or there is no warranty anymore :-(. So I think klaus will go to the jail, since he made so many changes to his car. Of course if he lives at Serbia. A next question is: "Can I replace light bulbs?” Bulbs draw much more current (ARC less then 1A, but bulbs almost 10A) than car radio so this sophisticated operation must be done by high specialized persons only!! |
icatenej |
18 Jul 2005, 09:54
QUOTE(icatenej @ 15 Jul 2005, 13:26) I wish to thank all of you again. Someone rubed my rear door on parking loot and bended outer sheet-metal slightely inward. I decided not to go to service but to try to strighten door by myself. I removed plastic coverings in three minute process using service instructions you posted, and then just pushed outer plate by hand from inside... Everything vent in place, and now look like never been bended. Paint is almost untached, so I will just left it as is. I just can't see myself doing this on some German or Japanese car. Logan is clearly made for people and I'm happy with that. Igor. |
LGN 1.4 Amb. Pack
- BG 694 668
florin_el |
18 Jul 2005, 10:43
The Expert Group: Members Posts: 114 Joined: 28 December 04 From: Iasi, Casablanca |
It might be easier for German or Japanese cars if you have the service manual... oh, maybe not on the S-Klasse but on normal cars it's quite easy to do maintenance. I am doing that for my Galloper which is a carbon-copy of '99 Mitshubishi Pajero and I see no problem. It's easier because everything fits together when you are assembling back, no need for drilling machine to fit back the door cover or whatever else you removed.
2005 Laureate
- IS-05-FTY Don't drink and drive - you might hit a bump and spill it.
icatenej |
18 Jul 2005, 15:36
QUOTE(florin_el @ 18 Jul 2005, 10:43) It might be easier for German or Japanese cars if you have the service manual... oh, maybe not on the S-Klasse but on normal cars it's quite easy to do maintenance. I am doing that for my Galloper which is a carbon-copy of '99 Mitshubishi Pajero and I see no problem. It's easier because everything fits together when you are assembling back, no need for drilling machine to fit back the door cover or whatever else you removed. When thinking about what I previously posted, I came to conclusion that it is actually a price I paid for car which determine if I should try to repair something by myself or not. When I said "German or Japenese" I didn't mean that German or Japanese (or French or American) cars are really can't be serviced by user to some point... Instead, I tryed to picture myself removing interior parts from Golf V or Mazda 3 or Peugeot 307 or Megane and realised that I would never think about doing something like that in first place. But, with Logan, this is something that came to my mind prior anything else. And, question is why? Probably because I thought that even if I screw something, it wouldn't cost me kidney to restore it back to original state in registered service. Of course, we talk here about new cars, not used. I would try anything on 6 year old Passat or Pajero (pricewise, similar to new Logan), but not on new, no way... Igor. |
LGN 1.4 Amb. Pack
- BG 694 668
kodalo |
19 Jul 2005, 07:06
Membru incepator Group: Members Posts: 20 Joined: 11 April 05 |
QUOTE(icatenej @ 18 Jul 2005, 15:36) When thinking about what I previously posted, I came to conclusion that it is actually a price I paid for car which determine if I should try to repair something by myself or not. Igor. Yes, I also have same opinion, but it looks very hard to find any technical documentation about Logan, even one for end users not for specialist. |
Dacia logan
Ambiance 1.4 MPI
- NN XXX BBBB
novauto |
22 Jul 2005, 09:33
Well, I have Logan Ambiance without remote locking door. Since I have alarm, I would like to use it for remote lock/unlock door.
I suppose I must use wires from left front door or this from switch at console. I don't wanna use any other options for alarm (siren, cut off ignition,...) only lock unlock. Does anybody has idea how to do it with minimal wire modification? I have wiring diagram for alarm. |
dras |
22 Jul 2005, 15:58
Driver Group: Members Posts: 163 Joined: 21 November 04 From: Bucuresti |
QUOTE(novauto @ 22 Jul 2005, 09:33) Well, I have Logan Ambiance without remote locking door. Since I have alarm, I would like to use it for remote lock/unlock door. I suppose I must use wires from left front door or this from switch at console. I don't wanna use any other options for alarm (siren, cut off ignition,...) only lock unlock. Does anybody has idea how to do it with minimal wire modification? I have wiring diagram for alarm. Do you have centralized locking system? I understand that you don't have remote option, but if you lock the driver's door this action locks also the rest of the doors? If yes, then you just have to connect the alarm module to the existing wiring. If not you'd better visit a dealer. Anyhow I sugest you to do the operation at an authorized dealer, because if you do it someware else you will lose warranty for electric system. This post has been edited by dras: 22 Jul 2005, 16:08 |
Honda
Accord Executive
2007 / 2.0 A/T 155CP
- B-74-***
mccoy |
22 Jul 2005, 21:45
Membru autentic Group: Members Posts: 273 Joined: 2 January 05 From: small town in Vojvodina |
QUOTE(novauto @ 15 Jul 2005, 22:32) Autobest - Dealerworst Well, this is true story from Serbia. Customer bought Dacia Solenza and now wants to change cassette player with CD player. He asked dealer for advice, does he can do it yourself and answer is NO. Car radio must be replaced at official service. Or there is no warranty anymore.../" Yes,it is true,has been in auto-moto newspaper "SAT" The guy wanted some strong CD player with mp3... |
Laureate 1.6
- ...98-7. -----------------------------
Divide et impera ... and unite in EU ! ----------------------------- |
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 26th April 2024 - 02:46 |
