cum se pune la punct cureaua de distributie la sol
daniyl1978 |
4 Sep 2005, 12:45
Membru incepator Group: Members Posts: 3 Joined: 4 September 05 |
- is-53-ema
Asi |
5 Sep 2005, 01:50
Camaro SS Group: Members Posts: 930 Joined: 24 July 05 From: Bucuresti |
scoti cureaua veche si slabesti intinzatorul si pui cureaua noua si strangi intinzatorul.
Mitsubishi/Mercedes
Carisma/B-class
2003 1.9 DI-D/2007 200CDI
- B 79 ASI/Bxxx "Cei care au puterea de a constrange n-au nevoie sa recurga la judeacata" (Thucydides, 1, 77, 2)
daniyl1978 |
5 Sep 2005, 18:11
QUOTE(Asi @ 5 Sep 2005, 01:50) nu asta ma interesa man chestia cu punctela de pe arborele cotit pompa de injectie si axul cu came asta ca scot cureaua da o stiu de ar fi doar atat ar fi usor da e ceva mai complicat |
- is-53-ema
costi |
5 Sep 2005, 18:27
Membru autentic Group: Members Posts: 3.230 Joined: 15 October 03 From: Bucuresti |
nu poti; ca sa o intinzi corect iti trebuie scule
DSN/SLZ
5 Sep 2005, 19:49
Asa-i mai bine?...
Attached thumbnail(s) distributie_diesel_1.jpg ( Size: 121.12k ) Number of downloads: 711 distributie_diesel_2.jpg ( Size: 104.47k ) Number of downloads: 696 distributie_diesel_3.jpg ( Size: 115.41k ) Number of downloads: 657 distributie_diesel_4.jpg ( Size: 66.12k ) Number of downloads: 621 |
costi |
5 Sep 2005, 19:57
de ce nu-i spui si ce-i aparatul MOT 1505 si unde se gaseste el
DSN/SLZ
5 Sep 2005, 20:11
costi |
5 Sep 2005, 20:13
DSN/SLZ
gastorro |
24 Feb 2017, 13:35
Membru Group: Members Posts: 184 Joined: 27 September 15 |
Ba nu-ti trebuie "scula" ! Uite:
QUOTE(gastorro @ 21 Feb 2017, 16:03) Citeam despre curele si am descoperit cat de critic este reglajul tensiunii (intinderii) din ele ca sa nu strici rulmentii angrenati.. reply luat de aiciAm aflat care este cea mai ieftina si precisa scula/metoda de masurare a intinderii curelei: Un programel gratuit de frecventzmetru pentru telefoanele Android, descarcabil de pe Google Play, numit Carbon Drive by Gates Acum, cu ajutorul telefonului, poti sa-ti reglezi tensiunea din curea cu mare PRECIZIE ! Trebuie doar sa aflati care este frecventa (in Hz) din manual, cu care cureaua trebuie sa zbarnaie (oscileze) liber (exact ca o coarda de chitara). De exemplu la motorul F9Q, in manualul tehnic ( de aici ), la pagina 11A-39, scrie ca "la valeur de tension soit de 90Hz +/- 3Hz, sinon réajuster" ! Nimic mai simplu! - Intinzi rola pana la semn, apoi apropii microfonul telefonului la 1cm de curea (pe portiunea dintre fulia vibrochenului si rola intinzatoare) si dai un bobarnac in curea, iar frecventa masurata trebuie sa fie cu +/- 3Hz fata de ce vrea Renault (si reglezi fin din intinzator pana o aduci la 90Hz) |
Megane2 facelift 1.4 16v K4J740
2006.12
- CYO-274
5 Mar 2017, 03:26
ati innebunit cu diapazul ala sau cum dracu' ii zice...se masoara la simtul mainii,o rascesti la 90 de grade sau in geneal la 3kgf tre' sa faca burta de 6mm,toate astea se fac pe cea mai lunga latura dreapta a curelei la orice masina dupa ce s-a calat la semne si s-a rotit motorul o tura...eu am pus N distributii la logan-uri si mpi si dci si n-a venit nici unul inapoi sa-mi crape capu' ...terminati cu prostiile....
This post has been edited by sobolan: 5 Mar 2017, 03:27 |
BLUE R 19 |
6 Mar 2017, 00:36
Membru autentic Group: Members Posts: 5.244 Joined: 12 August 10 From: Pitesti |
/1900
17 Jul 2018, 12:43
fan Dacia Group: Members Posts: 19.943 Joined: 12 November 05 From: Bucuresti |
nu toate distributiile se tensioneaz ala fel. Poate nu au venit inapoi ca au ramas in drum mai departe. La dci oricum e tensor automat.
31 Jul 2018, 20:01
normal ca tu esti meseriasul cel mai smecher,tu le stii pe toate,amin.....si btw : rola de intindere de la distributia de logan DCi nu e chiar automata cum e pe la alte masini,altfel nu te uitai dupa "limba" cu imbusul prin ea.....desteptule !
1 Aug 2018, 08:25
Exista aplicatii android gen gates easy tension care rezolva problema cu un banal telefon, fara sa fie nevoie de diapaz. pentru astia care nu au laba calibrata ca sobolanii.
This post has been edited by einstein1984: 1 Aug 2018, 08:26 |
2 Aug 2018, 22:16
as fi dobitoc daca ti-as da "report" dar tine cont ca esti mai prost decat noaptea.....si chiar esti,esti un teoretician de doi lei care umbla cu carti si androide,eu chiar am pus mana pe ele efectiv.mie nu-mi trebuie diapaz,eu am explicat mai sus cum te poti verifica daca nu esti sigur,un cantar de mana era suficient....pe femeie o rezolvi tot cu androidul ?
This post has been edited by sobolan: 2 Aug 2018, 22:17 |
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 9th May 2024 - 17:57 |
