Cold Start Problems, Starting the car in the morning.
Russini55 |
1 Oct 2012, 11:22
Membru incepator Group: Members Posts: 4 Joined: 1 October 12 |
Duster
1.6 4WD
STALEX2004 |
17 Jul 2013, 14:33
Membru autentic Group: Members Posts: 651 Joined: 5 June 08 From: Bucuresti |
try to replace the coil and the "wires" that conects the spark plugs to the coil...it seems like a an ignition problem...
acum am vazut data postarii This post has been edited by STALEX2004: 17 Jul 2013, 14:34 |
Clio 3 FL 1.5 DCI
2011 Renault Clio Symbol Fidji 1.5 DCI 2006
Renault Clio 3 FL 1.5 DCI 2011 |
Russini55 |
17 Jul 2013, 15:36
"try to replace the coil and the "wires" that conects the spark plugs to the coil...it seems like a an ignition problem..."
It really was a coil and sparkplug problem...but it was created by a damaged alternator. The alternator started creating more tension and it even melted the ceramic of one of the spark plugs. Changed alternator, coils and spark plugs and it's working perfectly. |
Duster
1.6 4WD
god |
17 Jul 2013, 16:18
wizard Group: Members Posts: 328 Joined: 15 November 04 From: Bucuresti |
The repair was made in warranty I assume...
Anyway, glad you managed to get this fixed. |
Duster 1.5 dci 4X4
Iunie 2010 / Prestige It's time to burn™
Squirrel |
31 May 2014, 22:09
Captain of Black Pearl™… Group: Members Posts: 4.466 Joined: 13 March 08 From: partea mea: Drum bun! |
Suddenly…
1PM 6PM Joyfull diesel! |
Duster
2010 1,6 16v 4Ś4 Laureaté Noir Nacré
- RO 44 AWD Fire, walk with me...in 4 strokes, water cooled.
P-A-C-O |
2 Jun 2014, 17:59
What you see is what you get! Group: Members Posts: 2.350 Joined: 3 October 10 |
si cine-i opreste sa faca "retur" la marfa ?!... in orice tara UE acest lucru este posibil, mai ales la un astfel de comportament al motorului
- Ziua de 16 nov 2014 a ramas in istoria Romaniei ca fiind ziua in care omul politic Victor Ponta a fost cel mai aproape sa devina Presedintele Romaniei
renaultlag2 |
6 Jun 2014, 20:32
Membru autentic Group: Members Posts: 493 Joined: 23 February 13 From: Bucuresti |
Fugi la ei se stie deja de problema,mai multe lume se plange.
2001 Dynamique
Squirrel |
6 Jun 2014, 21:10
Și se plânge în continuare, nu par a fi soluții încă…
Duster
P-A-C-O |
8 Jul 2014, 21:47
QUOTE Dacia lucreaza la un nou software pentru motoarele diesel care echipeaza Duster, pentru a le corecta functionarea Versiunile restilizate ale Dacia Duster, echipate cu motor diesel, vor beneficia de o resoftare in curand, pentru a corecta o functionare anormala a motorului la ralanti si in jurul turatiei de 2.000 rotatii pe minut (rpm), cand motorul manifesta lipsa de putere. La variantele diesel de dinainte de facelift nu existau aceste manifestari. Mai multi posesori de Dacia Duster facelift cu motoare diesel se plang de oscilatia turatiei la ralanti si de lipsa de putere la 2.000 rpm, insa nu toate masinile se manifesta astfel, desi, teoretic, toate au aceeasi versiune de software. Inginerii Dacia recunosc problema si spun ca lucreaza pentru a o rezolva, iar in curand posesorii de Duster 1.5 dCi vor fi chemati pentru o resoftare a sistemului electronic care gestioneaza functionarea motorului. “Noi am sesizat ca exista o problema care nu a fost cuprinsa in testele de anduranta pe care le-am facut. (…) Calibrarea care exista acum pe masina este, cum ii spunem noi, <<fara riscuri la client>>. Deci puteti sa folositi masina fara niciun fel de probleme si vom schimba aceasta calibrare dupa ce suntem convinsi ca acea noua calibrare nu va afecta masina”, a declarat unul dintre inginerii de la Renault Technologie Roumanie cu ocazia celei de-a saptea intalniri a dusteristilor. “La un motor diesel sunt circa 26.000 de parametri de functionare. Noi lucram intens sa ne asiguram ca modificarile nu vor influenta si alti parametri. Se poate intampla sa facem stabilizarea ralanti-ului pe 800 rpm, dar sa intervina zgomotul injectiei. Tacanitul acela pe care il auziti dumneavoastra. Si apoi sa spuneti… <<A! E motorul galagios>>”, a explicat un inginer RTR. pe langa faptul ca sunt total pe langa subiect pupincuristii de la Duster 4x4 Everyone RTR (care toata ziua stau si bibilesc la douadustere ijn garaj insa ei sunt angajati ca ingineri cu acte in regula), au auzit ei ceva insa nu prea stiu sa explice ce si cum, e chiar amuzant "interviul" bine, unu dintre ei are probleme serioase cu gramatica lb. romane in mailurile pe care le trimite in intern... si e roman 100% This post has been edited by P-A-C-O: 8 Jul 2014, 21:47 |
9 Jul 2014, 11:49
- Group: Members Posts: 21.839 Joined: 19 April 05 From: Romania |
http://0-100.hotnews.ro/2014/07/01/foto-de...icnic-gigantic/
QUOTE Clientii Dacia se aduna o data pe an pentru un picnic urias, iar la iarba verde se pot vedea diferentele dintre francezi si romani vis-a-vis de Dacia si modul in care marca este perceputa. I Fara mititei manele si betivi O intalnire de relaxare, fara scopuri comerciale Si uita asa mai dam o limba la Dacia. Para ca fenomenul prostitutional se extinde cat mai mult la jurnalisti. |
zanzie |
13 Jul 2014, 09:57
Aspirant de Trabant Group: Members Posts: 1.241 Joined: 30 April 08 From: Pădure |
QUOTE(Squirrel @ 31 May 2014, 23:09) Suddenly… squirrel, zi-ne si noua cum s-a rezolvat problema. |
gard viu din spini,
cu flori la poarta
si rinoceri in curte
Squirrel |
14 Jul 2014, 15:13
Cum a zis și P-A-C-O…nu încă.
Duster
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 26th April 2024 - 12:58 |
