Renault logan 1.6mpi, Problem with ignition coil
PolitoNAM |
9 Feb 2014, 14:54
Membru incepator Group: Members Posts: 1 Joined: 9 February 14 |
Logan 1.6mpi
- N884WB
pollux83 |
21 Feb 2014, 23:03
Membru incepator Group: Members Posts: 5 Joined: 21 September 10 From: SE France |
You might like to check the top dead centre sensor, which is at the right-hand end of the engine block, on top of the clutch housing. The symptoms you describe can occur if the sensor is defective - or loose or not in the correct position.
It shouldn't fail within 2 years but maybe it has become loose. I haven't had the problem with my Logans but I did have it with a Megane that had the same type of engine. As you described it, the car tended to stall and refused to start when the engine was hot. In my case, changing the sensor fixed the problem. |
2010
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 14th May 2024 - 01:14 |
