UCH duster model nou, Este acelasi UCH ???
george.enescu |
11 Mar 2014, 11:15
Membru incepator Group: Members Posts: 33 Joined: 7 December 05 |
logan laureate
- b 42 EIC
torquemada |
12 Mar 2014, 22:43
torquemada Group: Members Posts: 1.878 Joined: 17 January 05 From: Bucuresti |
1: Nu.
2: Da si nu, majoritatea informatiilor sunt pe CAN |
Logan II
2012 / 0.9 TCe Laureate
george.enescu |
21 Mar 2014, 15:03
Mersi pentru raspuns
Totusi ma intereseaza daca informatia de viteza vehicol si turatie sunt pe fir sau CAN Mersi anticipat |
logan laureate
- b 42 EIC
torquemada |
21 Mar 2014, 19:31
Pe CAN, mai jos ai semnalele spre TdB pentru X52, X72 si X79 phII.
+pemanent fuse Ground (Black) +cheie fuse Push button on-board computer [C4 BC] [C4 button board computer] Oil pressure switch Brake fluid control Hand brake control CAN L CAN H [C4 remote control light] info debit info debit [C4 engine oil level] [C4 engine oil level] outdoor temperature sensor outdoor temperature sensor seatbelt warning light harging indicator light |
Logan II
vsebas |
24 Oct 2014, 13:30
spawn Group: Members Posts: 297 Joined: 29 July 05 From: Timisoara |
Stie cineva care este numele in ddt pentru duster ph1 ? Share, pls ?
Duster 1.5 dci, / ex Logan 1.6 MPI 2005 Ambition
/ 2012, Laureate
- TM People are simply not predictable
torquemada |
29 Oct 2014, 18:00
E destul de clar, sper.
Attached thumbnail(s) Untitled.jpg ( Size: 201.39k ) Number of downloads: 668 |
Logan II
vsebas |
29 Oct 2014, 21:39
Pt. mine, din pacate nu e.
Rogu-te din pozele mele, sunt pe drumul bun ? ddt2600_4x4.jpg ( Size: 47.01k ) Number of downloads: 693 ddt2600_4x4_tr.jpg ( Size: 45.63k ) Number of downloads: 682 ddt2600_4x4_ECM.jpg ( Size: 38.08k ) Number of downloads: 663 ddt2600_4x4_uch.jpg ( Size: 31.49k ) Number of downloads: 667 |
/ 2012, Laureate
torquemada |
30 Oct 2014, 13:26
x79 Duster ph1(uch și TdB de x90) e trecut ca logan 4x4. Acum daca ai dCi în afară de UCH nu vei vedea nimic cu interfată clasica vag kkl, totul fiind pe CAN(injectie, ABS,4x4 etc)
x79 Duster ph2(uch și TdB de x52) se citeste doar cu interfata derelek usb diag2 sau 3 This post has been edited by torquemada: 30 Oct 2014, 13:28 |
Logan II
ambvision |
19 Nov 2014, 14:25
Membru Group: Members Posts: 104 Joined: 5 January 06 |
Nu aveti careva schema electrica de la duster PH2? Vreau sa-mi fac o automatizare si m-ar interesa in special schema de la pozitii/faruri, in caz ca difera de cea de la PH1.
Duster
dci 4x4 110hp
marian_ariciuc |
20 Nov 2014, 10:56
User Group: Members Posts: 322 Joined: 6 May 10 From: de obicei, acasa |
difera sigur!
ce automatizare? contribui si eu macar cu idei |
1.6 16V E5 Vand modul inteligent de geam pentru logan 1 si 2 si alte...
ambvision |
20 Nov 2014, 14:04
Pentru inceput lumini tip follow me home, actionabile si din telecomanda, si m-ar interesa modalitati usoare de a aprinde pozitia si faza scurta (separat) cu interventii minime asupra instalatiei electrice (masina e in garantie). De exemplu, la casetofon (in zona aceea as vrea sa pun) este un fir pe care vine 12v cand sunt aprinse pozitiile - daca eu dau pe acel fir 12v printr-un releu, se vor aprinde pozitiile ?
De asemenea ma gandeam ca acest modul sa faca si pe termostatul pt AC. Ar mai fi idei, insa depinde de ce as putea face in instalatia electrica a masinii. Tare as prefera sa fie totul cu mufe (de aceea ma gandeam la casetofon, probabil acea mufa e mai standard si as putea gasi-o usor), nu cu fire lipite |
Duster
dci 4x4 110hp
torquemada |
20 Nov 2014, 23:23
Scheme există dar nu sunt publice.
La radio CD ai alte mufe, nu cele care le ai pe mașina din semnătură. |
Logan II
creatorulcom |
23 Apr 2015, 13:40
Membru incepator Group: Members Posts: 1 Joined: 1 March 15 |
Ai tester ?
audi
a4
2010
kti |
30 Dec 2015, 19:40
,,hobyst,, Group: Members Posts: 123 Joined: 20 May 08 From: CRAIOVA |
eu da...
trebuie can dedicat DDT nu babauri... |
1.4/gpl/stag200-4 ,1,5 diesel
- xx-70-xxx
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 11th May 2024 - 00:06 |
