Automatic wipers start after “watering” windscreen
2 Jan 2005, 14:02
Attached thumbnail(s) 0_Schema_UCH.gif ( Size: 18.6k ) Number of downloads: 47720 1_mufa_de_scos.jpg ( Size: 84.04k ) Number of downloads: 71688 2_alcatuire_mufa.jpg ( Size: 55.68k ) Number of downloads: 44015 3_pozitionare_pin_7.jpg ( Size: 62.62k ) Number of downloads: 57896 4_mufa_maneta.jpg ( Size: 58.12k ) Number of downloads: 58506 |
Boris |
4 Jan 2005, 08:37
Croatian member Group: Members Posts: 497 Joined: 20 October 04 From: Zagreb, Croatia |
Thanks,
Usefull information. After the car arrives I will se if I will do anything myself in the warranty period because I'm not sure about the reaction to the interventions in wiring. Thet can always be done after the waranty period. Boris |
Logan Laureate 1.6
2005 + LPG Landi Renzo sequent Reliability of machines is inversely proportional to the number and importance of people watching it
Czar |
10 Jan 2005, 09:41
Membru incepator Group: Members Posts: 11 Joined: 9 December 04 From: Skopje |
Thank you Klaus ... I think I will be able to make the modification!
1.6 Laureate
- -862-OK
mccoy |
7 Mar 2005, 19:21
Membru autentic Group: Members Posts: 273 Joined: 2 January 05 From: small town in Vojvodina |
Salutare!
A few words `bout wipers . Because the high-ascending position of the right wiper (looking from driver’s seat) is not completely within area of the left one there is always a certain amount of liquid which remains on the windscreen after it has been washed & wiped… and goes down… and goes down for minutes…As for myself this is rather annoying,unpleasant,uncomfortable provoking…By the way,the same is on neighbour`s Ford Focus. I mention such problem does not exist on my old car. I dare say that the wipers should have been made or harmonized better. just an illustration,not piece of art… Attached thumbnail(s) wippers_2.JPG ( Size: 17.96k ) Number of downloads: 14427 |
Laureate 1.6
- ...98-7. -----------------------------
Divide et impera ... and unite in EU ! ----------------------------- |
sp67 |
7 Mar 2005, 20:44
Membru Group: Members Posts: 103 Joined: 4 December 03 From: Bucale |
It was the same on my Matiz. But I bought longer wiper blades and now they work ok, so I suspect the same could be true for the Logan; or you could try to adjust the left wiper to a higher resting position, so its trace will completely overlap with the right trace.
It seems some car manufacturers are now in the habbit of designing the wipers for a certain length, then they fit in shorter wiper blades to eek out a few f***ing cents |
mccoy |
8 Mar 2005, 14:59
[quote=sp67,7 Mar 2005, 19:44]
adjust the left wiper to a higher resting position I think that doesn`t make sense. There is possibility to elevate right one but I wonder if anybody would drive gorgeous,brand-new car with wipers like this: Attached thumbnail(s) Wipers_3.JPG ( Size: 8.75k ) Number of downloads: 5044 |
Laureate 1.6
Konstantin |
7 May 2005, 18:08
Membru incepator Group: Members Posts: 14 Joined: 24 April 05 From: Skopje |
Thanks Klaus for the insight about windscreen wipers. I just wired the connection on my Logan and it works just as you said it wold an as same as in my frends Clio.
However the collors of the wires on the wiper control stalk connector are not the same collor as the one on you'r picture's, (maybe the collors differ from model to model I have Logan 1,6 Laureate pack), but after a little counting i managed to do the installation. Thank's again it's really helpful function, and it was very nice of you that you decidet to share this kind of information with others. |
Logan laureate pack
- SK 225 OL Together We Stand
Divided We Fall |
kodalo |
10 Jun 2005, 08:59
Membru incepator Group: Members Posts: 20 Joined: 11 April 05 |
Hi,
Can I activate "open door" signal on my dashboard? I have Ambience 1.4 so there is no in standard package. |
Dacia logan
Ambiance 1.4 MPI
- NN XXX BBBB
10 Jun 2005, 09:51
There is no led on the bord...
There are two type of dashboards, for entry level models, and for the others. On entry-level leds are missing... |
kodalo |
10 Jun 2005, 10:45
QUOTE(klaus @ 10 Jun 2005, 09:51) There is no led on the bord... There are two type of dashboards, for entry level models, and for the others. On entry-level leds are missing... If LED is missing only it is not a problem. But does other wiring is missing also? This post has been edited by kodalo: 10 Jun 2005, 10:46 |
Dacia logan
Ambiance 1.4 MPI
- NN XXX BBBB
jocker |
5 Aug 2005, 17:43
Membru incepator Group: Members Posts: 20 Joined: 23 July 05 |
logan laureate 1.4 MPI
- Makedonija
siru |
14 Oct 2005, 01:09
Membru incepator Group: Members Posts: 30 Joined: 13 October 05 |
I have "implemented" myself the procedure described by Klaus and it works.
Some improvements, tips and tricks: - I have used a wire from an old mouse, because it has an adapter for fitting the pin 7 of the UCH - I have found a solution to connect this new wire on the pin 4 of the wiper stalk connector WITHOUT BREAKING THE ISOLATION of the existing wire for controlling the wipers: - pull out the existing wire of pin 4 (first pull out as much as possible the black side of the wiper connector stalk) - it has an adapter at the end for fitting the pin 4; this adapter has a hole which I have used to connect the new wire - I have reinserted the existing wire in the connector with the new wire attached and it worked. I remind here that the first things to be done before acting on the wires are: - remove the key from the contact - remove the safety fuses from the left panel, as described in the first image of Klaus Thank you Klaus for your guidelines! Good luck |
Laureate 1,4 MPI
- AG-01-SYR
Boris |
16 Oct 2005, 17:27
QUOTE(klaus @ 2 Jan 2005, 14:02) 2. The other end of the wire connected to UCH in this way is pulled up to the wiper control stalk and is connected to pin number 4 of wiper control stalk connector (the fourth from right to left, upper row, as you look from driver’s seat to the dashboard - this one pin actually gives 12+ Volts to windscreen washer pump - . In the image “4 Mufa maneta.jpg” can be seen the way I did that. A stuipid question, where is the "wiper control stalk"? |
Logan Laureate 1.6
DFA |
27 Oct 2005, 12:23
Logan III Comfort
ECO-G 100cp
2021 sedan
ex Logan I 1.5 |
Boris |
28 Oct 2005, 11:19
Logan Laureate 1.6
magomat |
24 Nov 2008, 21:33
Membru incepator Group: Members Posts: 20 Joined: 2 August 08 From: Belgium |
What is the situation with the new Mcv Phaze II.
Is this now standaard |
mcv logan
laureate 1.5 dci 85 7 pl Belgium,Brussel
2008/10/20
al bundy |
24 Dec 2008, 21:54
Membru incepator Group: Members Posts: 32 Joined: 11 May 06 From: Bucuresti |
It's the same like Phaze 1. It means don't have this options. Need to be installed.
skoda
octavia
- b-5784
eadin79 |
23 May 2010, 09:58
Membru incepator Group: Members Posts: 27 Joined: 15 February 08 From: Craiova |
Hi guys,
I did it!. It's just a wire which should be added... I'm romanian citizen, but I'm shame that our friends from Dacia couldn't add it from the factory.... Best regards. |
Renault Fluence
Dynamiques 1.5dCi 110HP
2011
- XXX-XXX-XXX [COLOR=purple]Traim in Romania si asta ne face sa cheltuim mai putin ...
HenkM |
17 Jul 2010, 12:19
Membru incepator Group: Members Posts: 3 Joined: 19 July 07 |
The UCH modification works for MCV phase I and II and the Duster (all tested and confirmed on Laureate versions).
Logan MCV 1.6 16V 7p
VladK2K |
18 Nov 2010, 11:05
Membru Group: Members Posts: 191 Joined: 30 August 05 From: Bucuresti |
Did it as well last night. It's not necessary to take out de UCH, only the plug (but it's a b!tch to take it out in the first place).
I used a connector from a floppy drive for the brown plug and some ethernet wire (not the whole cable) which I've just spun around a couple of times around the connector in the wipers command unit. Worked like a charm. Honestly now, if the function's there, why not activate it in the first place. Do they really think people are going to think "hmm, I'd buy a Clio but... Hey, look the Logan also has auto wipers when washing the windshield, let's buy that!" ? |
Hyundai
Tucson
2017 LP+
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 8th May 2024 - 01:30 |
