Rateuri, scurt si la obiect
CandyMan13 |
23 Jan 2009, 15:09
Membru autentic Group: Members Posts: 473 Joined: 1 July 07 From: Roman-Iasi |
1410
1996E
- NT-01-BSZ cea mai buna masina e masina pe care o ai
hordeagabriel |
23 Jan 2009, 15:12
membru Group: Members Posts: 154 Joined: 16 April 08 From: Deva |
E bine reglat avansul?
1995 berlina
CandyMan13 |
23 Jan 2009, 15:14
pai eu zic ca da ca e reglat cu pistonu 1 in pms si cand a dat scanteie strans.Plus ca am schimbat cu alt delco si tot la fel face...
1410
1996E
sumi_nos |
23 Jan 2009, 16:20
Membru autentic Group: Members Posts: 237 Joined: 18 December 06 |
VEZI SA NU AI CEVA PE LA SUPAPE SAU SA NU AI VREO TIJA NASOALA SAU AXUL DE LA CULBUTORI,POATE NU E STRANS,EU AM PATIT ASA,NU TRECEA DE 3000RPM NICI SA O OMOR DAR STIAM K SE DUSASE FILETUL IN CHIULOASA,FILETUL DE LA UNUL DINTRE SURUBURILE CARE STRANGE RAMPA CULBUTORILOR,DUPA CE AM RECTIFICATSI AM STRANS BN RAMPA GATA,TURATIE MAX LA O DACIE 1300 STANDARD DIN 1980 1,3 ESTE DE 7500-7800RPM
AM O INTREBARE AM AVUT PRESIUNE 0 LA ULEI AM SCHIMBAT POMPA DE ULEI FILTRU SI ULEIUL. DAR IN BAIA DE ULEI AM GASIT 2 CUZINETI AXIALI UNUL NE FOLOSIT NU SE CUNOASTE NIMIC PE EL E NOU SI UNUL TOCIT RAU. POT SCAPA DE ACOLO SAU NU SUNT AI MEI SI IA UITAT CINEVA PE ACOLO?? CE SE INTAMPLA DACA SUNT AI MEI SI MERG ASA FARA EI?CE POT STRICA ? SCUZE CA O REPET DAR SUNT DISPERAT This post has been edited by sumi_nos: 23 Jan 2009, 16:23 |
1410 SPORT
1989
- AG-01-MVU
baranga |
23 Jan 2009, 19:11
...eu merg cu DACIA iar tu pe jos.... Group: Members Posts: 888 Joined: 8 February 08 From: Slobozia- IALOMITA |
pt. @candyman13 :regleaza distanta la platina la 0,4 mm FIX si eventual curat-o si apoi masori distanta sa fie la fel pe toate cele 4 came ale axului delcoului;
verifici daca capsula vacuumatica(vacuumul) lucreaza; verifici distantele la bujii:le faci FIX 0,7mm refaci avansul;chiar daca zici ca ai tras-o la punct cu pistonul 1 la pms cateodata te mai fura semnul de pe volanta;parerea mea e ca ai avansul cam mare This post has been edited by baranga: 23 Jan 2009, 19:12 |
Break
1999 - 1310CL
- IL 03 HLE mi-au sters reputatia;eu o aveam cea mai mare
edymutu |
23 Jan 2009, 19:17
Membru incepator Group: Members Posts: 35 Joined: 5 December 08 From: campina |
rateurile st sigur de la aprindere. si eu am avut probleme asemanatoare si la mine a fost simplu, schimbarea condensatorului si problema a fost rezolvata. multa bafta
1980 berlina
- PH05UKC
CandyMan13 |
25 Jan 2009, 16:18
mutumesc pt sfaturi...dar cel mai apropiat sunt de parere ca e cel al lui sumi_nos pt asa cum am zis prima data cu alte piese perfect functionale si reglate face la fel...suspectez ceva din supape ca rampa e stransa ,nu am nici un filet slabit iar tijele le'am schimbat chiar daca si celelalte erau drepte....inca ma mai gandesc si la urma urmei dau chiuloasa jos .
1410
1996E
restromania |
28 Jan 2009, 01:01
Membru incepator Group: Members Posts: 84 Joined: 17 December 08 From: Galati |
Am si eu o intrebare..cum se regleaza bujiile la 0,7? cu ce masurati distanta asta?
va multumesc |
Super Nova
Clima 2001
- GL-88-SRG
Mario 86 |
28 Jan 2009, 02:13
Membru Group: Members Posts: 113 Joined: 26 January 09 |
tabla la capota aia subtire e reglaju cel mai bun si la platina cartonu de la un pachet de tigari da nu ala gros ala subtire ,iti garantez eu ca merge
Dacia 1310
Berlina
1996
- bt
SGM.MYKE |
28 Jan 2009, 07:44
Membru cu gargauni la cap Group: Members Posts: 584 Joined: 10 August 05 From: Stuttgart |
Un set de lere e si mai bun. Nu e scump si daca ai grija de el il ai toata viata.
Honda
Integra TypeR
1999_1.8 190CP Stiu putin, dar vreau mai mult.
Mr_Devil83 |
28 Jan 2009, 17:08
Membru autentic Group: Members Posts: 2.254 Joined: 14 June 08 |
Regleaza ca la carte aprinderea aia. lasa tu alea ca e o tija stramba si mai nu stiu ce ca daca era iti dadea el rateuri fara sa-i fie rusine la relanti. Daca ai zis ca ai s jocurile la tacheti n parametrii atunci nu ai ce cauta la motor. Te uiti la acesorii.
Ia vezi tu, motoru tau tine un relanti pe la 600 de ture? Eu zic ca nu. Cand il tine e reglata bine masina. Si tocmai aseara am patit si eu faza asta de tot rahatul, peste vreo 2000 de ture nu vroia sa o ia deloc. Am si ramas in mijlocul drumului din cauza ca aprinderea mea s-a decis sa faca nazuri. Si am zis sa curat si carburatorul si sa vad si eu nu or fi infundate alea 3 gauri de progresiune, pentru ca citisem aici, ca atunci cand accelerezi si ciocul de papagal scuipa benzina trebuie sa tasneasca si prin alea 3 gaurele. Ei, dupa 3 ore de curatat carburatorul, dupa ce am desfacut o gaura tehnologica ca sa vad nu o fi infundat cumva traseul, am realizat ca ala care o scris chestia aia e tampit si ca de fapt alea 3 gauri sunt pe traseul de relanti. Bun, cu carburatorul curatat si montat la loc, tot asa facea nenorocita. Si ma arde pe mine sa schimb luleaua. Si dintr-o data motorul meu sare de alea 7800 de ture care le are motoru standard din 1980. |
1300 / SUPERNOVA EUROPA
1984 / 2002
28 Jan 2009, 20:24
pai sunt pe traseul de relantii Mr... ce naiba credeam ca sti si tu barim atata lucru , eu un am explicat in fel si chip dar degeaba ... Progresiunea face trecerea de la regimul de relantii la regimul normal de functionare .
Lunaticul |
29 Jan 2009, 01:50
Membru autentic Group: Members Posts: 203 Joined: 27 December 07 From: Iasi |
Eu tocmai de la o tija indoita aveam rateuri in carburator. Sa fi vazut ce injuram cand mergeam la vale cu pedala la podea in treapta a patra si nu prindea mai mult de 50 km/h.
1310 L
1996 In orice situatie, ceea ce este cel mai dificil de facut, este, deobicei, ceea ce trebuie facut.
CandyMan13 |
29 Jan 2009, 12:54
eu am inteles ce ai zis tu mai sus.curiozitatea este ca cu alt delco(alta lulea implicit),alt carb(alt reglaj),alte bujii,nici o schimbare in mersul motorului;nici in rau da nici in bine.masina sta la relanti in 500 de ture.dimineata la rece pleaca la prima cheie fara soc si pana se incalzeste o las neturata...si tine motoru la 500 fara nici o problema.
problema intervine cand plec de pe loc...merge normal,iar daca ma dau la ea,de la 3800-4000 in sus "rateaza",se aude un zgomot aproapeinsesizabil corelat cu fluctuatia turometrului si aparitia lipsei de putere.rateurile sunt ffff scurte(normal la 4000)...si seama cu un zgomot de mitraliera..dar nu sunt BUBUITURI. |
1410
1996E
Minel |
29 Jan 2009, 13:14
Fisele ,bujiile fiind aceleasi .... ??
1310-L /VW Passat
1995/1397cmc
Mr_Devil83 |
29 Jan 2009, 13:15
QUOTE(djasu82 @ 28 Jan 2009, 20:24) pai sunt pe traseul de relantii Mr... ce naiba credeam ca sti si tu barim atata lucru , eu un am explicat in fel si chip dar degeaba ... Progresiunea face trecerea de la regimul de relantii la regimul normal de functionare . da, tu ai explicat in fel si chip, DAR TI-AI CITIT POSTURILE VREODATA? Deci pe bune, trebuie sa citesti de vreo 5 ori ce scrii tu si sa te gandesti cam unde vine o virgula. Poate daca ai incerca sa iti aranjezi si tu frazele am intelege si noi ce vrei sa spui si foarte probabil ca multi vor gasi informatii valoroase in posturile tale. DAR LA CUM LE SCRII IN PREZENT NICI O SANSA!!! |
1984 / 2002
CandyMan13 |
29 Jan 2009, 15:50
inclusic schimbate si bujiile si fisele...abolut tot ce se poate lua pt o verificare.pana si bobina...le'am pus pe rand,apoi observam comportamentul motorului,apoi schimbate intre ele...in fel si chip
1410
1996E
PH-06-BOA |
29 Jan 2009, 20:47
REGULA:
Cand da rateuri in carburator e din benzina putina, iar cand e in toba, curent putin. Parca ai zis in carburator, si ca l-ai pus pe cel de pe cealalta masina. Pune-l inapoi p-al tau, sau adapteaza-l ( jiglere, nivele ) |
- ph-99-aob
CandyMan13 |
29 Jan 2009, 23:07
corect,in carburator "paraie"...nu mai stiu ce sa adaptez..am schimbat cu altele de pe masinile unor prieteni/vecini etc,si tot la fel merge...cu fel de fel de reglaje...si nimic.
1410
1996E
dany_daci1300 |
29 Jan 2009, 23:33
Membru Group: Members Posts: 109 Joined: 28 June 07 |
am avut si eu problema asta si era de la carburator .... aveam garnitura aia groasa din textolit sparta ....
vezi sa fie garniturile bune This post has been edited by dany_daci1300: 29 Jan 2009, 23:35 |
1300,1307D
1975,2006 DACIA e cea mai buna masina findca e a noastra
da’ preferam BMW-uri in faruri cu lumina albastra |
CandyMan13 |
30 Jan 2009, 01:19
leam scos la un mom dat dar nu am observat sa fi avut vreun defect...o sa ma uit maine mai atent...mersi pt sfat
1410
1996E
v_razvan_c |
30 Jan 2009, 02:28
Membru autentic Group: Members Posts: 665 Joined: 11 March 07 |
QUOTE(PH-06-BOA @ 29 Jan 2009, 21:47) REGULA: Cand da rateuri in carburator e din benzina putina, iar cand e in toba, curent putin. Parca ai zis in carburator, si ca l-ai pus pe cel de pe cealalta masina. Pune-l inapoi p-al tau, sau adapteaza-l ( jiglere, nivele ) OK, dar si atunci cand pe langa rateu, iese si ditamai flacara pe carburator, de la ce mai este? |
Minel |
30 Jan 2009, 08:27
Supape admisie , incercati si o reglare a culbutorilor
1310-L /VW Passat
1995/1397cmc
CandyMan13 |
30 Jan 2009, 15:33
stai calm sefule ca nu imi iese flacari din carburator...paraie cand o tin in acceleratie dupa 4000de ture...da nu scoate flacari.
ce zice Minel s'ar putea adeveri.De supape sau arcurile de la supape sa nu se mai destina bine la turatii inalte, mi'a mai zis un om mai in varsta care a fost sef de service la o intreprindere.Ca am reglat culbutorii tocmai din cauza ca dupa ce am schimbat si rerererere-reglat tot ce se putea am zis ca e de acolo cu toate ca motorul mergea rotund(relanti)...dupa reglatul culbutorilor...nimic nou sub soare.De aici si concluzia lui Minel(care aveam si eu o suspiciune) si a mecanicului.:(Pacat de ciuloasa ca trebuie sa umblu la ea ca am inlocuit'o dupa ce mi s'astricat un filet la o bujie iar cu reductie nu a functionat si am "achizitionat'o" pe aceasta de pe masina botita care fusese cumparata cu doar 1500de km in urma(un prieten s'a dat peste cap cu ea).Nu am intrat in ea nici macar s'o subtiez iar acum sigur or sa mi se urce gargaunii la cap sa ma apuc de "tuning"(ba sa iau din chiuloasa,ba sa pun alt fel de supape)...and the saga continues.) This post has been edited by CandyMan13: 30 Jan 2009, 15:34 |
1410
1996E
PH-06-BOA |
30 Jan 2009, 18:11
Referitor la flacari- cand benzina e putina, nu mai are loc arderea in canera ci cauta mediul prielnic, care e pe galeria de admisie. Normal ca atunci cand expandeaza, iese pe carburator.
Acum inteleg ca , alta-i cauza. Nu te pripi, sa strici tot. Numai dupa ce sti sigur ce are , actioneaza. |
- ph-99-aob
CandyMan13 |
5 Mar 2009, 16:05
un topic de mult ingropat:)nu vreau sa il redeschid,doar sa va anunt ca bucuria e prea mare cand auzi simfonia celor 5500-6000 de ture cu pedala "la planseu" si nu se aude decat motorul exact cum trebuie,cantand inmul Frantei in Romania printre blocuri:))
PROBLEMA a disparut(acele rateruri de la 4000 de ture in sus)...cum????FOARTE SIMPLU:alta membrana pt pompa de benzina:P:P ..gata m'am linistit BAFTA! This post has been edited by CandyMan13: 5 Mar 2009, 16:05 |
1410
1996E
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 31st May 2024 - 15:25 |
