Eliminarea 'celebrului triunghi' de la stergatoare, Eliminare triunghi de la stergatoarele de parbriz
alexis |
8 Mar 2012, 15:33
daciot Group: Members Posts: 204 Joined: 30 June 05 From: Bucuresti |
Spring
2021
- B XX HXX
8 Mar 2012, 15:38
- Group: Members Posts: 21.839 Joined: 19 April 05 From: Romania |
Si iti stau stergatoarele la imbinarea dintre ele, unul peste altul.
alexis |
8 Mar 2012, 16:15
Spring
2021
- B XX HXX
8 Mar 2012, 16:36
Asta nu este rezolvare ...
8 Mar 2012, 16:42
Sa le spui si la aia de la BMW, ca tot asa le fac...
8 Mar 2012, 16:43
Aia au si alte brate pe care nu le vezi din habitaclu.
alexis |
8 Mar 2012, 19:44
Spring
2021
- B XX HXX
ALH |
8 Mar 2012, 20:08
Membru incepator Group: Members Posts: 67 Joined: 29 October 10 |
QUOTE(alexis @ 8 Mar 2012, 19:44) Nu inteleg ce vrei sa spui. La pozitia de repaus cele 2 lame se suprapun partial. Nu vad care e problema. Astfel dispar cele 2 triunghiuri: cel de jos - fara importanta si cel de sus - cel suparator. aceeasi solutie am adoptat si eu, chiar mai ,,ciobanesca": 650 cu 600 mm |
Duster 4x4, 1.6 16V
2010
9 Mar 2012, 15:01
stiind eu ca am vazut la un producator serios treaba cu suprapunerea stergatoarelor, am cautat prin arhiva personala si, ce sa vezi, am si gasit ce cautam:
Attached thumbnail(s) IMG_8364.jpg ( Size: 254.5k ) Number of downloads: 3333 IMG_9317.jpg ( Size: 176.37k ) Number of downloads: 3755 IMG_9387.jpg ( Size: 161.34k ) Number of downloads: 3701 |
b76bgaarh |
9 Mar 2012, 15:54
Membru autentic Group: Members Posts: 9.966 Joined: 5 October 06 From: Bucuresti |
hmm sl....
nu pune si initiatorul o poza? |
Megane sedan
9 Mar 2012, 15:57
SL, ML, clasa C, d-astea
george_scala_2004 |
9 Mar 2012, 17:53
Membru autentic Group: Members Posts: 6.576 Joined: 16 April 09 |
alexis |
9 Mar 2012, 18:30
Poze, ca s-au cerut:
Attached thumbnail(s) Stergatoare_de_Laguna_1.jpg ( Size: 108.02k ) Number of downloads: 3437 Stergatoare_de_Laguna_2.jpg ( Size: 111.17k ) Number of downloads: 1586 |
Spring
2021
- B XX HXX
LuluMOB |
9 Mar 2012, 19:35
Membru cu pedale. Group: Members Posts: 1.136 Joined: 28 October 05 From: Iași |
La Logan nu a disparut complet, chiar daca le-am suprapus si eu putin:
2011-07-30%2021-11-44_0455.JPG Suprapunerea nu ma deranjeaza, dar triunghiul si faptul ca se vad stergatoarele parcate de la volan, da. |
ABS+ AC 1.4MPI 06/2007
andreig1982 |
9 Mar 2012, 22:05
Membru autentic Group: Members Posts: 1.410 Joined: 15 January 06 |
fara modificari ale mecanismului, cea mai buna varianta este cu stergatoare de 600 cu 450
poate nu uit sa fac maine o poza, doua This post has been edited by andreig1982: 9 Mar 2012, 22:06 |
Logan Ambition
alexis |
9 Mar 2012, 22:31
QUOTE(andreig1982 @ 9 Mar 2012, 22:05) fara modificari ale mecanismului, cea mai buna varianta este cu stergatoare de 600 cu 450 poate nu uit sa fac maine o poza, doua Am incercat. In cazul Duster-ului nu merge deoarece sterge o suprafata prea mica in partea dreapta a parbrizului. Varianta 600/500 este combinatia cea mai buna din punctul meu de vedere. |
Spring
2021
- B XX HXX
andreig1982 |
9 Mar 2012, 22:50
pai si la logan sterge pe o raza cu 2,5 cm mai mica
nu e un capat de lume PS nu trebuie sa dai quote mesajului anterior This post has been edited by andreig1982: 9 Mar 2012, 22:50 |
Logan Ambition
12 Mar 2012, 14:04
bogdan_dsn |
12 Mar 2012, 16:31
Membru autentic Group: Members Posts: 730 Joined: 14 September 07 From: Cluj-Napoca |
Nu se poate face si la duster prelungirea parghiei pentru stergatorul din dreapta cu 15mm?
Kia
Ceed SW 1.4 TGDI
2020
alexis |
12 Mar 2012, 17:35
Care-i rostul cand varianta aplicata rezolva problema?
Spring
2021
- B XX HXX
12 Mar 2012, 17:44
Pai metoda asta a fost aplicata din 2004-2005.
ani[I]aL_2008 |
10 Apr 2012, 20:07
Membru incepator Group: Members Posts: 64 Joined: 17 July 09 From: Cluj-Napoca |
Servus tuturor!
Cursa stergatorului dreapta se va modifica doar prin solutia indicata de colegul TEDY (post no .75): taiere si sudare a piesei de angrenare. In urma diverselor postari de pe forum : - am scapat de scartaitul stergatorului dreapta prin inlocuirea bratului suport stergator cu unul identic cu cel de la sofer( masina mea este model PH1 2008-martie)- sistemul / ansamblul stergatoarelor de pe Duster este identic cu cel de pe Logan fabricat de la sf. anului 2007 si pana in prezent. - am scapat de triunghiul "de mizerie" de pe mijlocul parbrizului creat de miscarea stergatoarelor prin taierea si sudarea elementului din ansamblul stergatoarelor( am taiat in jur de 8-8.5 mm din piesa- nu am facut poze ; daca se studiaza topic-ul se "releva" usor despre ce piesa este vorba). Taierea si sudarea elementului din ansamblul stergatoarelor le-am realizat in Cluj cu ajutorul d-lui Fodor Todorut, nr. tel.:0741 363 926. Pentru cei din Cluj, si nu numai, va recomand . Sper ca am reusit sa fiu de ajutor tuturor de pe forum care au aceste probleme si nu le-au rezolvat inca. |
2008-Kiss Fm, 1.4mpi
- BC 05 ***
zanzie |
11 Apr 2012, 16:00
Aspirant de Trabant Group: Members Posts: 1.241 Joined: 30 April 08 From: Pădure |
gard viu din spini,
cu flori la poarta
si rinoceri in curte
ani[I]aL_2008 |
11 Apr 2012, 19:38
Servus
Imi cer scuze pt inducerea in eroare, am dat "copy&paste" de pe topicul cu Logan( Piese auto- Stergatoare parbriz), acolo este post-ul no.75. Si DA, modificarea se poate face si la Duster. Ca timp alocat : - 10 min. max sa scoti tot ansamblul - vreo 20-30 de minute sa demontezi piesa, sa o tai , sa o sudezi, sa o slefuiesti, eventual o si vopsesti daca ai timp si garaj la indemana - 10 min. sa montezi ansamblul la loc That's all! Spor la bricolat si Sarbatori fericite tuturor colegilor de pe Forum! |
- BC 05 ***
bobo77 |
11 Apr 2012, 21:49
........................... Group: Members Posts: 7.213 Joined: 27 January 06 From: Mangalia |
Despre topicul asta este vorba...
http://www.daciaclub.ro/Stergatoare-parbri...ml#entry3391776 |
Laureate 1,6 mpi
2008 ph 2
ani[I]aL_2008 |
11 Apr 2012, 22:13
Mersi bobo77
- BC 05 ***
virgiliu |
19 Apr 2012, 14:55
Membru incepator Group: Members Posts: 84 Joined: 13 April 09 From: Bucuresti |
Eu unul am pus stergator la mine de 60 cm dar cred ca trebuia de 65 ca tot nu am scapat definiv. Cel de la pasager e original.
Duster 4x4 cu 4x4 valve
2010
ionutctn |
19 Apr 2012, 15:52
Membru cu TDI Group: Members Posts: 1.373 Joined: 20 November 04 From: Bucuresti |
Cautati cumva sa adaptati alte brate cu alt sistem, sa aiba alta prindere si sa va permita si o pozitie mai joasa a lamelelor parcate. Atunci puteti incerca o dimensiune mai mare a lamei de la sofer. Nu e neaparat sa fie suprapuse. Pot fi pe linie lamele iar distanta dintre ele foarte mica. Incercati cu masuratori, altfel nu se poate. Am vazut destule masini la care nu se suprapun si acopera foarte bine.
This post has been edited by ionutctn: 19 Apr 2012, 15:55 |
1998 Skoda Superb Elegance
ani[I]aL_2008 |
19 Apr 2012, 16:02
Servus tuturor!
Da "ionutctn", si mie imi plac bratele stergatoarelor de la AUDI, dar nu cred ca ar merge pe Logan sau Duster. Chiar daca ar iesi la masuratoare, banuiesc ca achizitionarea lor si "adaptarea" acestora ar fi mult mai scumpa decat ne-am astepta, asa-i?! Solutia descrisa aici: http://www.daciaclub.ro/Stergatoare-parbri...ml#entry3391776 este eficienta si mi-a rezolvat problema. "Virgiliu", stergatorul, daca e de 60-65cm. , datorita fortei de apasare a bratului , gandita pentru stergatoarele de 50-55cm ( sa zicem),nu va sterge pe capete parbrizul. Am incercat pe Loganul din dotare urmatoarele dimensiuni : - la sofer:60cm, 65cm, 55cm; cel de 55 este perfect, sterge complet si fara sa faca zgomote, sa lase dare, etc. - la pasager:45cm, 48cm, 50cm; cel de 50 este perfect, sterge complet si fara sa faca zgomote, sa lase dare, etc. Adevarul este ca eu am mai facut si urmatoarea modificare: am montat un brat similar celui de la sofer si la pasager. Investitia a meritat, am scapat de scartaieli. Cele mai bune stergatoare pe care le-am utilizat pana in prezent pe masina sunt BOSCH ECO ( sistem clasic, nu flat). |
- BC 05 ***
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 25th April 2024 - 13:35 |
