[VAND] PIESE din dezmembrari Dacia Logan
GarageZone |
11 Jan 2015, 19:06
Membru incepator Group: Members Posts: 24 Joined: 13 April 12 |
Attached thumbnail(s) 20141129_191612.jpg ( Size: 1.6mb ) Number of downloads: 161 20141129_221834.jpg ( Size: 1.42mb ) Number of downloads: 167 20141129_222607.jpg ( Size: 1.62mb ) Number of downloads: 166 20141129_223658.jpg ( Size: 1.8mb ) Number of downloads: 166 20141120_144739.jpg ( Size: 1.45mb ) Number of downloads: 161 20141120_150255.jpg ( Size: 1.26mb ) Number of downloads: 56 |
Vel Satis
- TX 00908 TX
GarageZone |
15 Jan 2015, 22:14
PIESE din dezmembrari Dacia Logan :
- Motor 1.4 benzina - 55kw K7J-A7 Renault - Dacia Logan - 1000 lei (se vinde cu acte) - KIT aer conditionat A/C Dacia Logan 1.4 benzina - 55kw - 1500 lei - Catalizator Dacia Logan 1.4 benzina - 55kw - 150 lei - Galerie admisie Dacia Logan 1.4 benzina - 55kw + injectoare - 180 lei - Alternator Dacia Logan 1.4 benzina - 55kw - echipare A/C - 250 lei - Conducta vacuum frana Dacia Logan 1.4 benzina - 55kw - 50 lei - Vas lichid parbriz Dacia Logan + pompa - 80 lei - Ansamblu stergatoare Dacia Logan + motoras - 150 lei - Coloana directie Dacia Logan 1.4 - 125 lei - Corp clapeta acceleratie Dacia Logan - 125 lei - Bobina inductie Dacia Logan + fise - 80 lei - Electromotor Dacia Logan 1.4 benzina 55kw - 150 lei - Tamburi ABS Dacia Logan - 100 lei/buc - Fuzeta dreapta-stanga ABS Dacia Logan 1.4 benzina 55kw - 150 lei/buc - Etrier stanga-dreapta Dacia Logan 1.4 benzina 55kw - 100 lei/buc - Planetara dreapta Dacia Logan 1.4 benzina 55 kw - 120 lei - Pompa servo-frana Dacia Logan - 150 lei - Pompa ABS Dacia Logan - 250 lei - Calculator ECU Dacia Logan 1.4 benzina 55 kw - 250 lei - Calculator UCH Dacia Logan - 200 lei - Spirala airbag Dacia Logan - 100 lei - Bloc stergatoare Dacia Logan - functie calculator bord - 80 lei - Timonerie Dacia Logan 1.4 benzina 55 kw - 80 lei - Kit calculatoare - pornire Dacia Logan 1.4 benzina 55kw ECU + UCH + 2chei - 400 lei - Usa completa dreapta fata Dacia Logan - 250 lei - Oglinzi electrice stanga - dreapta Dacia Logan - 100 lei/buc - Macara geam electric spate stranga-dreapta Dacia Logan - 100 lei/buc - Macara geam electric fata stranga-dreapta Dacia Logan - 100 lei/buc - Geamuri spate stanga-dreapta Dacia Logan - 50 lei/buc - Set pistonase + arcuri saboti spate - 50 lei - Vas lichid servo-directie - 30 lei - Senzor servo-directie - 50lei - Contact cu 2 lamele chei - 100 lei - Butoane geamuri electrice spate - 50 lei - Buton oglinzi electrice - 30 lei - Frana de mana - 50 lei - Suport motor - 50 lei - Suport cutie viteze - 50 lei - Set furtune apa - 80 lei (toate furtunele) - Vas expansiune - 30 lei - Brate stergatoare - 30 lei - Plastic bord - 50 lei - Senzori ABS spate - 30 lei/buc - Plafon interior textil - 50 lei - Tampon antibalans - 30 lei - Suporti radiatoare - 30 lei/2buc - Suport vas servo-directie - 20 lei - Broasca capota - 30 lei - Cabluri capota + reglaj faruri - 30 lei - Pedale ambreiaj + frana - 30 lei - Kit lumina torpedou - 30 lei (lampa - buton - cablaj) - Plafoniera - 15 lei - Balamale capota - 30 lei/2buc - Acumulator Bosch S3 - 100 lei (an 2013) - 4 difuzoare - 25 lei/buc - conducte frana - plastice interioare - diverse Piesele provin din dezmembrari si sunt in perfecta stare de fuctionare. Preturile sunt usor discutabile. Telefon : 0769642062 UP! |
Vel Satis
- TX 00908 TX
GarageZone |
18 Jan 2015, 21:36
PRETURI NEGOCIABILE
LICHIDARI STOC 0769642062 |
Vel Satis
- TX 00908 TX
Catalinmodena |
19 Jan 2015, 23:06
Membru autentic Group: Members Posts: 2.547 Joined: 7 April 08 From: Aproape de Craiova |
supot ochelari?
megane sedan
manager 1.4 16v 2007
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 26th April 2024 - 06:08 |
