Noisy Gear Engine, Noisy Gear Engine
homerolo |
30 May 2006, 19:38
Membru incepator Group: Members Posts: 22 Joined: 30 May 06 |
RENAULT LOGAN
LOGAN 1.6
LOGAN 1.6
- GJC123
isa |
30 May 2006, 21:05
Membru incepator Group: Members Posts: 2 Joined: 14 May 06 |
Don't worry about that sound because it's from the clutch bearing and it is a "techonological sound". Try this : press the clutch and see if that noise is the same. Normaly you can bearly hear it when the clutch is pressed.
PS: I heard the same noise on a Megane 2 1.4 16V. |
Daewoo
Matiz
- B-36-JTU
homerolo |
30 May 2006, 21:20
ON THE OTHER HAND, ARE THERE PEOPLE ON THESE FORUM WORKING WITH LINUX SO FAR....
RENAULT LOGAN
LOGAN 1.6
LOGAN 1.6
- GJC123
homerolo |
30 May 2006, 21:25
QUOTE(isa @ 30 May 2006, 14:05) Don't worry about that sound because it's from the clutch bearing and it is a "techonological sound". Try this : press the clutch and see if that noise is the same. Normaly you can bearly hear it when the clutch is pressed. PS: I heard the same noise on a Megane 2 1.4 16V. after i press the clutch the noise goes off, ok thanks for the help i will have to live with it from now on, hey but this car is great. Down here in ecuador it's selling a lot and it really cheap comparing to all the benefits comes with. |
RENAULT LOGAN
LOGAN 1.6
LOGAN 1.6
- GJC123
30 May 2006, 21:55
As isa said, is from the clutch' springs. The same as on Clio's clutches
homerolo |
30 May 2006, 22:41
RENAULT LOGAN
LOGAN 1.6
LOGAN 1.6
- GJC123
icatenej |
31 May 2006, 15:17
Membru incepator Group: Members Posts: 51 Joined: 15 July 05 From: Belgrade, Serbia |
QUOTE(homerolo @ 30 May 2006, 21:20) This is off-topic, of course, but I'm using linux on regular basis. I started with linux more than 7 years ago. In matter of fact, my entire company runs on linux - both servers and desktops. Why you ask? |
LGN 1.4 Amb. Pack
- BG 694 668
homerolo |
31 May 2006, 17:54
QUOTE(icatenej @ 31 May 2006, 08:17) This is off-topic, of course, but I'm using linux on regular basis. I started with linux more than 7 years ago. In matter of fact, my entire company runs on linux - both servers and desktops. Why you ask? Because I saw on the forum some pinguin's picture and i inmediatelly thought that those persons were linux users. If you know a good linux forum i woul like to participate i am a IT administrator for linux platform. thank you. |
RENAULT LOGAN
LOGAN 1.6
LOGAN 1.6
- GJC123
martin245 |
31 May 2006, 18:28
EX PAT Group: Members Posts: 913 Joined: 1 April 06 From: Karlsbad Germany (again) |
QUOTE(homerolo @ 30 May 2006, 22:41) on last thing about this, the noise comes from the gear stick underneath that is where that noise comes from. it's still ok right ? Check that the gearstick is not touching any part of the bodywork as this will give a noise The noise could come from a Dry thrust bearing on the Clutch . are you having problems changing gear ?? and can you feal Vibration on the gearstick?? |
logan 14 mpi Simply RED
- GB 1 Bessy Regs
martin245 |
31 May 2006, 18:29
- GB 1 Bessy Regs
martin245 |
31 May 2006, 18:30
QUOTE(homerolo @ 30 May 2006, 22:41) on last thing about this, the noise comes from the gear stick underneath that is where that noise comes from. it's still ok right ? Check that the gearstick is not touching any part of the bodywork as this will give a noise The noise could come from a Dry thrust bearing on the Clutch . are you having problems changing gear ?? and can you feal Vibration on the gearstick?? If you have any worries take the car back it is your right as a NEW car owner Stand up for your rights mate Stu Attached thumbnail(s) vivitar_012.jpg ( Size: 91.31k ) Number of downloads: 146 vivitar_012.jpg ( Size: 533.97k ) Number of downloads: 119 |
- GB 1 Bessy Regs
homerolo |
31 May 2006, 23:37
QUOTE(martin245 @ 31 May 2006, 11:30) Check that the gearstick is not touching any part of the bodywork as this will give a noise The noise could come from a Dry thrust bearing on the Clutch . are you having problems changing gear ?? and can you feal Vibration on the gearstick?? If you have any worries take the car back it is your right as a NEW car owner Stand up for your rights mate Stu No the gearstick is not touching any part of the bodywork and there is no problem changing gear, only when i have the gearstick in neutral (5 stick ) it's when you hear that noise under the gearstick. When i press the pedal it goes off. I think this is normal, because a have a friend, and she says that she has the same noise when it's on neutral. thank you |
RENAULT LOGAN
LOGAN 1.6
LOGAN 1.6
- GJC123
zorpetus |
1 Jun 2006, 11:13
Membru Group: Members Posts: 120 Joined: 17 April 06 |
QUOTE(homerolo @ 31 May 2006, 23:37) Does anybody has a problem (not always, but from time to time) to put the gear stick in REVERSE? Sometimes, no matter what you try it can not be put in reverse - UNLESS you release the clutch, press it again, and then try to put in reverse. My friend has that problem and would like to know is it known or that is something that is just on his Logan. |
None
None
- None
DFA |
1 Jun 2006, 11:38
Yes, the problem is known, in service they put a lot of grease on the mechanism below the gear stick (under the car).
Logan III Comfort
ECO-G 100cp
2021 sedan
ex Logan I 1.5 |
zorpetus |
1 Jun 2006, 11:45
QUOTE(DFA @ 1 Jun 2006, 11:38) Yes, the problem is known, in service they put a lot of grease on the mechanism below the gear stick (under the car). Thank you! But the problem is not a serious one (it would not damage the car, for example) - so, he doesn't have to go to service immediatelly, but can wait for the first warranty service (after one year or 10.000 km, whichever comes first). |
None
None
- None
martin245 |
1 Jun 2006, 20:19
QUOTE(zorpetus @ 1 Jun 2006, 11:13) Does anybody has a problem (not always, but from time to time) to put the gear stick in REVERSE? Sometimes, no matter what you try it can not be put in reverse - UNLESS you release the clutch, press it again, and then try to put in reverse. My friend has that problem and would like to know is it known or that is something that is just on his Logan. If it wont go into reverse just put it into first and heypresto you can get reverse Stu |
- GB 1 Bessy Regs
aproapeom |
2 Jun 2006, 14:33
Membru incepator Group: Members Posts: 76 Joined: 25 November 05 |
if u think about it , putting it into the 5th gear would be more easy
same problem here |
logan 1.4
- b xx wor
Boris |
2 Jun 2006, 17:21
Croatian member Group: Members Posts: 497 Joined: 20 October 04 From: Zagreb, Croatia |
What I would like to know is why that happens.
More or less I drove only my former Fiesta for a longer period, and with that car I could not put in reverse maybe one time out of twenty. With the Logan is one out of every three or four times. Not that it bothers me much ("but the light bulb in the glove compartment did "), but I would just like to know what's the reason for it. Any technical explanations? |
Logan Laureate 1.6
2005 + LPG Landi Renzo sequent Reliability of machines is inversely proportional to the number and importance of people watching it
martin245 |
2 Jun 2006, 19:15
1st gear and reverse gear are on the same shaft this is one reason it helps using 1st gear
Stu |
- GB 1 Bessy Regs
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 26th April 2024 - 04:30 |
