Montaj boxe pe megane II?
Fratzica |
4 Sep 2006, 13:53
Zen Group: Moderatori Posts: 2.912 Joined: 6 April 04 |
Kia
Sportage
T-GDI 2021 "The happier we are, the less we see." - some japanese guy
semit |
4 Sep 2006, 14:24
Private Spice Group: Moderatori Posts: 5.972 Joined: 27 September 05 From: Bucuresti |
in 2 suruburi.. restu` de 2 prinderi le rupi. si ura si la gara.. cel putin eu asa am facut
Megane GT line 1.5dCi
'13 nu-ti face iluzii ca sa n-ai deziluzii.
Fratzica |
4 Sep 2006, 14:49
Kia
Sportage
semit |
4 Sep 2006, 15:16
cu patentu`
claus |
4 Sep 2006, 23:25
private spice Group: Members Posts: 1.695 Joined: 27 November 03 From: Bucuresti |
ce boxe ai luat, nenea ?
sunt curios daca e diferenta.. altfel.. cu problema ta.. semit are dreptate |
renault
megane II
2003 confort dynamique
Fratzica |
5 Sep 2006, 00:40
niste jvc-uri. o sa vad cum le montez si iti arat cum suna
Kia
Sportage
Fratzica |
5 Sep 2006, 20:56
deci am demontat azi boxele si nu mi-a venit sa cred... Ati vazut vreodata magneti de boxe de megane??????????
ia aruncati un ochi aici: Attached thumbnail(s) Image047.jpg ( Size: 239.84k ) Number of downloads: 2172 Image050.jpg ( Size: 307.72k ) Number of downloads: 2484 Image048.jpg ( Size: 268.47k ) Number of downloads: 2416 |
Kia
Sportage
Fratzica |
6 Sep 2006, 16:53
azi am montat boxele dupa ce le-am rupt cate doua urechi si am taiat plasticul ala din spatele lor. Se aude destul de bine. Oricum, mie inalte si medii imi trebuie ca bass iau din alta parte
Evenimente in timpul montajului: ametitu de fratemiu a vrut sa puna doua suruburi pe bord, da` n-a nimerit si le-a bagat fix in fanta de aerisire pt parbriz. Noroc cu Liviu ca m-a scos din belea. Mersi Liviu! |
Kia
Sportage
andreicri |
7 Sep 2006, 11:35
Membru autentic Group: Members Posts: 740 Joined: 5 September 04 From: Bucuresti |
Tu ce sistem aveai?Cel stock?Adik nu Cabasse,la asta ma refeream.Antifonare nu i-ai facut nu?
megane 2 sedan
1,9dCi/2004 Laguna 3 Dynamique 2.0 dCi full (fara piele si trapa)(pe vine)
morph |
7 Sep 2006, 13:03
Membru autentic Group: Members Posts: 330 Joined: 17 May 04 From: Bucuresti |
Saraciile alea de boxe de megane, cu magnetii aia micuti se aud mai bine ca 90% din boxele pe 13 dintr-un magazin de profil.
Btw, nu trebuie sa rupi urechile, este suficient sa le indoi spre exterior, astfel sa poti folosi boxele si in alte 'incinte'. Ai grija sa pui un mastic de jur imprejurul difuzoarelor, altfel or sa 'baraie'. This post has been edited by morph: 7 Sep 2006, 13:07 |
-------------------- fost posesor de Megane II Hatch 1.5dCi 80cp
A-klasse 1.5 CVT 2006 VW Polo Happy 1,2 HTP 2006 |
Fratzica |
7 Sep 2006, 13:06
sistemul era stock, si nu, nu am antifonat... inca. Dar urmeaza un alpine 9853, doua sisteme dls ms5 si antifonare.
Kia
Sportage
andreicri |
7 Sep 2006, 16:04
Ai idee cum se face antifonarea ,pentru ca am inetels ca usa de Megane e pacatoasa la aspectul asta datorita conceptiei sa zicem mai ciudate,cu multe goluri.Am mai intrebat pe aici(inclusiv pe Taz) dar vad ca nu mai intra.Apropo,cam care este adancimea de montare la boxe si ce dimensiuni au tweeterele?25 sau 20 mm ca sa nu ma mai chinui sa le masor..
This post has been edited by andreicri: 7 Sep 2006, 16:29 |
megane 2 sedan
andreicri |
7 Sep 2006, 16:30
[quote=morph,7 Sep 2006, 15:03]
Saraciile alea de boxe de megane, cu magnetii aia micuti se aud mai bine ca 90% din boxele pe 13 dintr-un magazin de profil. Erai sarcastic nu? |
megane 2 sedan
Fratzica |
7 Sep 2006, 17:16
pai.. antifonarea se face fie cu dynamat, fie cu un fel de pasta insonorizanta. Si la megane ar trebui sa tina pentru ca am vazut megane-uri in audio-shop-uri pt insonorizat.
Adancimea maxima de montaj e cat vrei, odata ce tai plasticul din spatele boxei Tweeterele nu stiu ce dimensiune au.. Si sper ca morph era sarcastic |
Kia
Sportage
andreicri |
7 Sep 2006, 22:05
QUOTE(CataNOS @ 7 Sep 2006, 19:16) pai.. antifonarea se face fie cu dynamat, fie cu un fel de pasta insonorizanta. Si la megane ar trebui sa tina pentru ca am vazut megane-uri in audio-shop-uri pt insonorizat. Adancimea maxima de montaj e cat vrei, odata ce tai plasticul din spatele boxei Tweeterele nu stiu ce dimensiune au.. Si sper ca morph era sarcastic Ideea era la adancimea de montaj sa nu loveasca geamaul,de aceea intrebam |
megane 2 sedan
Fratzica |
7 Sep 2006, 22:24
poti baga si mama boxelor si sunt sigur ca nu atingi geamul
Kia
Sportage
Lex Luthor |
8 Sep 2006, 08:19
Membru autentic Group: Members Posts: 1.112 Joined: 25 April 05 |
QUOTE(CataNOS @ 7 Sep 2006, 18:16) Sper, spre binele tau, ca nu ai taiat acel plastic din spatele boxelor. El avea rolul de a proteja difuzorul de apa care se poate scurge prin usa, pe langa geam sau aiurea (vezi ca exista un topic pe aici cu aceasta problema pacatoasa). sau daca l-ai taiat, sper ca ai facut dintr-o tabla de aluminiu o alta protectie. Altfel s-ar putea sa ai neplacuta surpriza sa ti se ude difuzoarele (sau, in functie de noroc, s-ar putea sa nu o ai). Sa stii ca exista boxe "custom fit" pentru Megane II fata. Le produce Pioneer, au membrana din Kevlar, au filtre si tot tacamul. Ia arunca un ochi aici: Boxe Pionner pt. Megane Si daca vrei si o poza: tsq131cdetailpageoy2.th.jpg Nu trebuie sa modifici nimic, nici in usi si nici la tweetere. pretul este in jur de 100 EUR. Poti sa le comanzi pe net. In Romania nu am gasit pana acum nicaieri. Din ce am citit pe forumuri straine, se aud destul de bine. |
Fratzica |
8 Sep 2006, 10:24
pai, 1 la mana, nu-mi plac boxele alea de la pioneer . 2 - acu am niste jvc-uri de care nu ma doare, le-am pus doar pentru ca se aud mai bine decat cele stock. Cand voi baga niste boxe adevarate, o sa am grija sa le acopar cu ceva. Si oricum, nu am taiat tot domul ala, ci doar partea plata din capat cu forma aia pt magnetul mic de la boxa stock.
Multumesc pt info! Daca ar fi venit cu 2-3 zile mai devreme era super |
Kia
Sportage
Meghitzanul |
8 Sep 2006, 11:03
***** 4 ISOFIX Group: Members Posts: 1.619 Joined: 10 January 05 From: Bucuresti |
Si eu am taiat plasticul ala acum 2 ani si nu au diff-urile nici pe dreaq.
Am bagat pe fata un set Infinity Ref 5002 (la sfatul unora de aici de pe forum...si tin sa le multumesc ) si merg de n-au aer, super bass (atat cat se poate scoate dintr-n diff de 13 cm)..... Trebuie sa schimb si boxele de pe spate pt ca e ca si cum nici nu le-as avea chiar daca stai pe locurile din spate |
VW Passat Variant
2.0TDI 170cp
DSG 2008 Audi A3 Sportback 2.0TDI 140cp DSG 2008
ex Renault Megane 1.6 16v 2004 Alan 42 + Sirio Turbo 2000 / Alan 42 + Sirio Turbo 1000 |
Sociopatul Tandru |
8 Sep 2006, 15:20
Membru autentic Group: Members Posts: 220 Joined: 23 June 05 From: Braila |
Dragii mei, nu va suparati pe mine, dar nu inteleg de unde ideea asta ca daca magnetii sunt mici difuzoarele se aud prost!
Nu are nici o legatura dimensiunea magnetului (si/sau a bobinei) cu calitatea sunetului. Va arat eu Celestion de-alea de 30cm pentru aplicatii profesionale cu suspenie din carton si membrana din carton care costa o avere si se aud mai bine ca foarte multe difuzoare asa zise "tari". Tin sa mentionez ca acele Celestion au magnetii foarte mici! Cum mai spunea cineva de pe aici, difuzoarele alea de pe Megane se aud mai bine ca 90% din cele din magazine, si aici sustin! Daca vrei parerea mea ai ales prost JVC-urile iar daca ai fi realist ai sa vezi ca sunetul nu mai este atat de liniar precum era inainte. Pentru nelamuriri asupra difuzoarelor recomand o carte pe care o puteti achizitiona de la Teora, online. Se numeste: Incinte acustice pentru difuzoare. Este scrisa numai de ingineri profestionisti si de acolo veti intelege cum sta treaba cu puterile, impedantele, parametrii T/S, magnetii si inductia lor si o sa intelegeti multe! Apropos, daca vinzi difurile de megane, da-mi pm! |
Nova GT
1998 Septembrie
- BR 69 CGF Nu sunt un nationalist dar ma mandresc cu Dacia!
Fratzica |
8 Sep 2006, 18:05
deci jvc-urile le aveam ramase de pe cealalta masina a mea. si nu cred nici batut ca boxele alea de pe megane se aud mai bine decat 90% din boxele de pe piata (apropo, jvc-urile se aud mai bine decat alea, eu avand nevoie doar de inalte si de medii. Pentru bass am altceva ). sa fim seriosi! Si inca o chestie, magnetul putea sa fie mic, si de neodymium, dar magnetul astora de-abia se chinuie sa tina lipita o agrafa de el, care pana la urma pica.
Deci eu unul prefer niste magneti mari decat d-aia mici (size does matter! ) ) Urmatoarele boxe (imediat ce fac rost de bani ) vor fi astea: http://www.be-loud.ro/produse/Difuzoare/DLS/Sisteme/DLS_MS5/ va rog remarcati dimensiunea magnetului P.S. De unde sunet liniar domne` ca pacaneau ca vai viata lor |
Kia
Sportage
Sociopatul Tandru |
11 Sep 2006, 12:35
CataNOS, eu ce am vazut pe Megane m-a lasat masca. Acum depinde ce ai avut tu, banuiesc ca sunt mai multe feluri de linii audio.
Cat despre difuzoarele de pe piata, pe mine m-au dezamagit si JBL ce sa mai vorbim! Vreau sa trec pe Hertz! Daca zici ca pacaneau , te cred pe cuvant! |
Nova GT
1998 Septembrie
Fratzica |
11 Sep 2006, 12:54
eu cred ca ai dat peste un cabasse, sau un sistem undercover , nu cred ca boxele astea stock aveau cum sa te impresioneze cumva
Kia
Sportage
andreicri |
11 Sep 2006, 14:52
Sa stii ca nici Cabasse nu suna stralucit,dimpotriva
megane 2 sedan
semit |
11 Sep 2006, 14:59
Cabasse inseamna aceleasi boxe dar player schimbat...
andreicri |
11 Sep 2006, 21:16
Nu ar fi exclus,desi nu vad care ar fi smenul fata de cel stock.La firmele care se reaspecta se schimba si boxele,basca sub(VEZI jbl,bose).Ma mir cum de Cabasse gireaza asa ceva.
This post has been edited by andreicri: 11 Sep 2006, 21:41 |
megane 2 sedan
Sociopatul Tandru |
14 Sep 2006, 04:29
Fratilor ce am auzit eu pe Megane stock suna de n-avea moarte!
Eu mi-as da JBL-urile mele pe acele difuzoare daca as stii care sunt si ce fel. |
Nova GT
1998 Septembrie
morph |
14 Sep 2006, 12:15
Nu eram sarcastic.
Sociopatul stie despre ce vorbesc. |
Lex Luthor |
22 Sep 2006, 12:20
Sunt in situatia de a alege niste boxe noi pentru Megane.
Initial vroiam Pioneer TSQ131 (construite special pt.Megane). Dar sunt prea scumpe (110 EUR) si se aduc greu. Cel mai probabil o sa mi aduca cineva din USA niste boxe asa ca m-am orientat spre ofertele de acolo. Ce am gasit eu la un pret "decent" sunt urmatoarele: Audiobahn ABC525T 75.52 $ - Honey Comb Cone - 35HZ - 25KHZ Frequency Response - 91dB Sensitivity - 120W RMS / Continuous Power Handling - 15 Oz. Magnet Structure - 2,75" Mounting Depth (69.8 mm) bigabc525taf6.th.jpg Hifonics ZXi 5.2C 83.99 $ - Frequency Response: 61Hz - 25KHz - Sensitivity: 91 dB - Power Handling: 90 watts RMS - Max fit Mounting Depth: 2.24" (56.8 mm) bigzxi52cxt6.th.jpg MA Audio Y30C5 5-1/4" $89.99 - Carbon Injected Woofer Cone - 1" PEI Titanium tweeter - Frequency Response: 35 Hz - 22k Hz - Sensitivity: 89.2 dB @ 1W/1M - 125 Watts RMS - Mounting Depth: 2.75" (69.8 mm) - 20 oz. Strontium Magnet bigy30c5kr7.th.jpg Kenwood KFC-P507 $110.49 - Oversized 130 mm Titanium Coated - 20 mm U.F.L.C. Soft Dome Tweeter - Sensitivity : 91 dB - Frequency response: 35 ~ 35.000 Hz - Rated Input Power: 45 W - Mounting depth (woofer): 60 mm - Magnet weight: 250 / 8.8 gr /oz kfcp507xmg8.th.jpg Kenwood KFC-X1300P $110.49 - Carbon-PP Hybrid Cone Woofer - Cast Aluminum Basket - 1" Tetlon Soft Dome Tweeter - Sensitivity: 91 dB - Frequency response: 40 ~ 30.000 Hz - Rated Input Power: 45 W - Mounting depth (woofer): 52.5 mm - Magnet weight: 230 / 8.1 gr /oz kfcx1300pxhy0.th.jpg Acum, despre Kenwood am auzit, stiu ce experienta au. Si despre Audiobahn am auzit. Despre MA Audio si Hifonics nu am auzit. Ce am citit pe net este ca Hifonics, Autotek, Crunch, MBQuart si Maxxsonics sunt o parte a companiei USA. MA Audio se pare ca este o companie bine vazuta in USA. A avut vreunul dintre voi posibilitatea sa asculte vreunul dintre aceste difuzoare. Sau, mai realistic spus, care ar fi recomandarea "audiofililor" de pe acest forum. Va rog sa va limitati la aceste propuneri, fara Magnat, DLS sau altceva. (oricum aceste marci, la varianta pe componente ar fi cu mult mai scumpe). Multumesc. By the way, stie cineva cat este adancimea maxima de montare pentru usile din fata (la cati mm de fata usii este geamul)? |
Fratzica |
22 Sep 2006, 19:34
hifonics sau kenwood. audiobahn tinde sa exagereze puterile afisate.
si cred ca poti baga boxe fara grija adancimii atata timp cat tai plasticul ala din usa. |
Kia
Sportage
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 27th April 2024 - 01:02 |
