Vibratie motor, problema?
snak3 |
8 Jul 2007, 18:49
Membru incepator Group: Members Posts: 58 Joined: 2 November 03 From: Bucharest |
2007 Ambition 1.5 Dci
- B ---- A GOOD friend will come and bail you out of jail but a TRUE friwnd will be next to you in the cell saying: " GOD it was good "
C@talin |
8 Jul 2007, 18:54
DCI stiam ca are acceleratie cu potentiometru cum,ai simtit tu vibratii in pedala aia,nu pot intelege,in rest poate te lumineaza altcineva sorry.Daca era benzina iti spuneam deacuma ca e subturata la 2000 si de asta vibra motoru.
Range Rover
V8 5.0
Vogue SE
snak3 |
8 Jul 2007, 19:13
Presupun ca se transmitea vibratia din motor in pedala, nu cred ca vibra pedala mecanic.
adip |
8 Jul 2007, 21:40
Banned Group: Members Posts: 2.177 Joined: 12 July 06 From: Melbourne, Victoria |
snak3, daca problema se reproduce constant, de fiecare data cand incerci, mergi cu ea inapoi in service-ul unde ai facut revizia si ia un mecanic de acolo la o proba de drum.
This post has been edited by adip: 8 Jul 2007, 21:44 |
* What you live with you learn.
What you learn you practice. What you practice you become. What you become has consequences . |
PaulT |
8 Jul 2007, 22:17
Membru autentic Group: Members Posts: 3.294 Joined: 23 June 06 From: Bucuresti |
Du-te inapoi la service.
C@talin---nu e subturat motorul la 2000rpm(pe benzina). |
Dacia/Mitsubishi
2006 Laureate/1973/2008
- B-00-xxx
C@talin |
8 Jul 2007, 22:27
Mai chiar daca ar fi fost,eu de cand ma stiu merg cu a 4 la 60 la ora adica fix 2000 ture
Range Rover
V8 5.0
Vogue SE
snak3 |
8 Jul 2007, 22:35
Mersi pt sfat adip. Problema e ca acum masina a plecat catre mare, deci ace destul de multi km de facut inainte sa pot ajunge cu ea inapoi in service in Brasov. Oare se poate intampla ceva foarte grav in km astia ?
Sunt foarte curios de la ce ar putea sa fie. |
adip |
8 Jul 2007, 23:19
snak3: inainte de a merge la revizie a mai facut asa?
snak3 |
9 Jul 2007, 07:38
nop, niciodata.
zodrac |
9 Jul 2007, 10:19
Membru autentic Group: Members Posts: 426 Joined: 13 January 05 From: Bucuresti |
Cel mai probabil ca vibratia sa se fi transmis prin pedala de ambreaj. Cel mai probabil cred ca ar mai trebui putin strins cablu de la pedala de ambreaj, dar cel mai bine mergi in service.
* Dacia Logan Ambition 1.5 dCi - iunie 2006
C O S T I |
7 Feb 2008, 13:21
Membru incepator Group: Members Posts: 76 Joined: 7 February 08 |
AJUTOR. Am o problema cu masina mea LOGAN 1.5 DCI.Am o vibratie la relanti dar numai dupa ce se incalzeste motorul. Dupa un timp ea dispare.Am fost la service au pus calc. pe ea si nu gasesc nimic si ei zic ca poate fii o problema mecanica ce nu se verifica cu calc. Stie cineva ceva sau a patit asa ceva ca sa ma ajute.
2006-laureat dci [B]dacia[/B][U]
AR-18-MOS |
7 Feb 2008, 13:26
Pai daca au zis ca poate are o problema mecanica, de ce nu le-ai zis sa o identifice si sa o repare?
BMW
730Ld
'07 High Executive
C O S T I |
7 Feb 2008, 14:59
nu au stiut ce sa-mi spuna
AMW |
8 Feb 2008, 02:11
Membru autentic Group: Members Posts: 779 Joined: 7 March 06 From: Bucuresti |
aceeasi problema o am si eu
am fost in service si am verificat: suproti motor, injectoare si au iesit ok la verificare, am facut o proba de drum si concluzia lor scrisa si pe procesul verbal de reparatie a fost sa schimb motorina cu euro 5 si sa schimb vitezele peste 3000 de ture...avand in vedere ca atunci cand m-au intrebat la cat schimb si am zis 2500 si poate un pic peste...au exclamat de parca le-am zis 1200 de ture. Seful de la garantii zicea ca ar putea fi infundat EGR-ul si sa bag euro 5 si sa merg mult mai turat pentru ca isi v-a reveni. Acum recunosc...dupa o cura de 2-3 plinuri de alpine diesel nu a mai tremurat la ralanti o perioada...s-a scumpit motorina...s-a incalzit afara si i-am bagat din nou sprint diesel...bineinteles...iar tremura... Daca stie cineva cu exactitate din ce cauza e sau cum se poate remedia va rog sa postati...deoarece eu o consider o problema grava. Tremura uneori de zici ca e vreun mertzan din `77 diesel cu milioane de km la bord... Se pare ca si motorina este una din cauze...dar nu cred ca doar de aici se trage... |
Volkswagen Passat
Highline 2.0 TDI 4MOTION
B6 Renault Megane III 1.5 dCI - 90 cp - 2012
Renault Scenic II Dynamique 1.6 16v |
denwer |
8 Feb 2008, 07:44
Membru Group: Members Posts: 151 Joined: 14 October 07 |
Inainte de pornire,in cateva randuri,reamorsati circuitul de alimentare de joasa presiune
prin pompare de la pompa manuala(para de cauciuc)pana cand aceasta se intareste si vedeti daca se mentine anomalia. |
1,5 DCi
C O S T I |
8 Feb 2008, 13:16
Revin si spun ca la rece porneste sifunctioneaza normal si doar dupa ce trece de primele doua dungi de la ind. de temperatura incepe sa faca si mai tine cam pina la 1/2ora de mers continu prin bucuresti.Daca se incalzeste bine nu mai face deloc SI CA O CONSTATARE cand vibreaza si dau drumul la AC se tureaza putin si vibratia dispare.Am sa incerc si faza cu amorsarea dar nu cred ca tine.Eu am cu ea 55000km si pe la 48000 am schimbat si injectoarele care erau duse [cica motorina e de vina] si tot asa face,am curatat EGR-ul si tot face. Cei de acolo au zis ca motorina e5 nu este buna pt. ca este mai uscata si nu face ungerea bine in pompa si injectoare si le strica dar am sa incerc si varianta asta.Masina este super testata,i-am luat chiar si compresia si nimic. Dupa ei masina nu are nimic insa s-a intimplat sa faca si cand am revenit odata la ei au vazut si degeaba iar ca sa imi desfaca motorul si sa caute e belea mare.Ca o mentiune toate verificarile le-am facut la Service Meridian .
AR-18-MOS |
8 Feb 2008, 18:00
Constatarea ta facuta in urma porniri aerului conditionat este una normala, deoarece turatia creste intotdeauna cand se cupleaza aerul conditionat.
This post has been edited by AR-18-MOS: 8 Feb 2008, 18:01 |
BMW
730Ld
'07 High Executive
AMW |
8 Feb 2008, 21:09
exact se manifesta si la mine cand dau drumul la AC, dealtfel este normal. Acum eu am observat aceasta vibratie exagerata dupa ce am mers vara trecuta prin bucuresti la 45 de grade bara la bara...imediat cum a venit un pic toamna si nu am mai dat drumul la AC se simtea vibratia...si evident..de atunci persista doar cand este motorul cald.
O sa incerc si cu pompa aia sa vad daca mai face... |
Volkswagen Passat
$$ilvviu |
8 Feb 2008, 21:19
Membru autentic Group: Members Posts: 5.882 Joined: 6 January 07 From: Roman/NT |
Vibreaza la relanti, dar daca turatia creste la 1000 rpm vibratia dispare...
Mie mi se pare a fi o problema cu tampoanele motorului. Nu stiu exact la Dacie, dar acelasi lucru l-am patit si eu si de vina era bieleta anticuplu. |
Initiale 2002
AMW |
8 Feb 2008, 21:58
am verificat tampoanele motorului in service ca eram convins ca de acolo e...dar nu era .... cica...
Eu am aj sa stau la semafor cu masina turata la 1000 de ture ca sa nu mai faca asa... Eu am 44k km si verif le-am facut la cobalcescu... |
Volkswagen Passat
denwer |
8 Feb 2008, 23:43
Ar mai putea fi turatia la relanti prea mica;poate va ajuta asta:Diagnosticare - Diagramă arbore de localizare pene
ALP6 Ralanti prea mare sau prea mic INSTRUCȚIUNI Nu consultați acest efect client decât după un control complet cu ajutorul testerului de diagnosticare. -Controlați parametrii motorului aplicând TESTUL 4. -Controlați circuitul electric aplicând TESTUL 2. -Garda ambreiajului este corect reglată ?Daca nu,efectuati reparatiile necesare; Daca da -Efectuați un control al calculatorului aplicând TESTUL 6. Contactați techline dacă efectul client persistă. Cereti la service sa va aplice procedura ALP6. |
1,5 DCi
AMW |
9 Feb 2008, 19:41
Turometrul, atunci cand este cald motroul, sta la fel cum statea si inainte...nici o modificare...
Volkswagen Passat
C O S T I |
11 Feb 2008, 19:55
am efectuat amorsare inainte de pornire si degeaba,am facut plinul cu motorina E5[40litri] si tot degeaba. o sa ma uit si la bieleta aia dar curios este ca apare vibratia[si la mine turatia pe relanti nu scade,cel putin vizibil pe turometru]si dispare.
denwer |
12 Feb 2008, 11:34
Turatia motorului la relanti trebuie sa fie de:-la rece 900 rot/min,iar la cald 805 rot/min;lipsa a 25-50 rot/min din turatia normala nu cred ca e sesizabila pe turometru,dar se detecteaza cu testerul.Voi ati afirmat ca la cresterea usoara a turatiei(prin pornirea AC sau din pedala de acceleratie),vibratia dispare sau asa am inteles eu.Ar putea fi o cauza care intr-adevar reduce putin turatia sau sezorul de turatie nu "citeste" corespunzator.Un control cu testerul de diagnosticare ar fi indicat si poate edificator daca diagnosticatorul e"uns" in vederea motivarii.
12 Feb 2008, 11:44: PS Eu cred ca e o situatie similara cu cea in care, fiind intr-o anumita treapta de viteza si turatia e usor sub cea necesara,se aud toti "greierasii" din bord pana cand se atinge turatia optima. This post has been edited by denwer: 12 Feb 2008, 11:44 |
1,5 DCi
C O S T I |
17 Feb 2008, 14:08
Am vorbit cu mecanicul si a zis ca sunt 12 teste pt. calculator dar nu are rost sa le fac pt. ca nu e de acolo si crede ca este un dezechilibru mecanic in motor.Mentionez ca el mi-a schimbat si injectoarele si e bine uns
calin.c |
17 Feb 2008, 15:15
Membru autentic Group: Members Posts: 310 Joined: 27 July 04 From: sighisoara |
totusi din ce spuneti nu este defect mecanic.
unul dintre injectoare nu lucreaza bine.nu se vede ca defect dar se poate diagnostica dupa parametri motorului |
denwer |
17 Feb 2008, 18:25
Dezechilibru mecanic in motor?Nu e incurajator,dar e original.Zici ca e bine uns,nu cumva o luase pe ulei?
1,5 DCi
calin.c |
17 Feb 2008, 18:31
nu are ce dezechilibru sa fie.
si daca arfii el cum il va decoperi? acel mecanic al tau bine uns cred ca ti-a uns injectoarele |
C O S T I |
25 Feb 2008, 21:21
se pare ca este o problema mai des intilnita caci vad ca a mai deschis si [tudorica] un topic in care se plinge de accesi vibratie
74r12 |
26 Feb 2008, 08:05
Membru autentic Group: Members Posts: 514 Joined: 2 July 04 From: Planeta Pământ (Terra) |
aruncati un ochi si aici: http://www.reno.ro/ciudatenie-relanti-page-1-t94198-s0.html
Megane
2.2
Expression+ 1,5 dci 85 cp Megane 3 Sport Tourer Privilege 1,5 dci 110 cp EDC
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 26th May 2024 - 12:50 |
