AIR CONDITIONER, BAD SMELL WHEN STARTING AIR CONDITIONER
homerolo |
7 Jul 2006, 21:15
Membru incepator Group: Members Posts: 22 Joined: 30 May 06 |
RENAULT LOGAN
LOGAN 1.6
LOGAN 1.6
- GJC123
martin245 |
8 Jul 2006, 12:04
EX PAT Group: Members Posts: 913 Joined: 1 April 06 From: Karlsbad Germany (again) |
How old is your car ??.You need to have the Airconditioner serviced as it can harvest all sorts of nasty bugs and this could be what is smelling
Go here and have a read http://www.popularmechanics.com/automotive...+spraying+it+in. Stu This post has been edited by martin245: 8 Jul 2006, 12:08 |
logan 14 mpi Simply RED
- GB 1 Bessy Regs
GoGu |
9 Jul 2006, 11:56
Prea de la tara Group: Moderatori Posts: 1.970 Joined: 14 August 03 From: Iasi |
http://www.daciaclub.ro/index.php?showtopic=48545#
There is a bactericide foam which solves this problem. This foam is injected from underneath the car, through the condensate drainage hole. |
Scenic 1.5dCi
recolta 2012
homerolo |
10 Jul 2006, 16:18
QUOTE(GoGu @ 9 Jul 2006, 04:56) http://www.daciaclub.ro/index.php?showtopic=48545# The car is new it only has 2 months. There is a bactericide foam which solves this problem. This foam is injected from underneath the car, through the condensate drainage hole. |
RENAULT LOGAN
LOGAN 1.6
LOGAN 1.6
- GJC123
homerolo |
10 Jul 2006, 16:48
RENAULT LOGAN
LOGAN 1.6
LOGAN 1.6
- GJC123
13nov |
12 Jul 2006, 14:21
Membru autentic Group: Members Posts: 260 Joined: 7 June 04 From: Bucuresti |
It doesn't really matter how old is the car if the A/C smells bad it means that it has acummulated some bacterias and this is why it smells bad. You cand buy a spray for cleaning the A/C and clean the evaporator by inserting the dispenser of the spray in a hole underneath the car.
OPEL
ASTRA GTC 1.9 CDTI
2008 Clio III 1.5 dci Privilege
AL |
14 Jul 2006, 15:14
use one of this...
http://www.motip.com/?page=23&id=787 (see also the attached file: WEBL322.pdf ( 58.81k ) Number of downloads: 76 ) or, the next one, recommended/used by Dacia: http://www.loctite.be/Teroson/TeroseptCleaner.htm ( terosept product specifications: http://65.213.72.112/tds5/docs/Terosept-EN.pdf ) |
KAROQ
2019
- B-21-NEW
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 13th June 2024 - 07:10 |
