NU SE APRINDE MARTORUL ROSU DIN BORD/NU PORNESTE, NU SE APRINDE LEDUL ROSU DIN BORD/ NU PORNESTE!HELP
Sirbu Cosmin |
![]() Membru incepator Group: Members Posts: 7 Joined: 11 July 14 ![]() |
Attached thumbnail(s) 20131116140557.jpg ( Size: 196.39k ) Number of downloads: 597 pzXLkYxrHq0.jpg ( Size: 103.7k ) Number of downloads: 497 10555161_648228125258245_1049864309_n.jpg ( Size: 72.52k ) Number of downloads: 504 10544871_648228078591583_92133752_n.jpg ( Size: 100.93k ) Number of downloads: 507 10544450_648228085258249_902694179_n.jpg ( Size: 96.07k ) Number of downloads: 511 10543754_648228111924913_1687354832_n.jpg ( Size: 85.27k ) Number of downloads: 139 10543119_648228131924911_1738674214_n.jpg ( Size: 72.54k ) Number of downloads: 130 10533459_648228008591590_752540098_n.jpg ( Size: 60.95k ) Number of downloads: 121 10522684_648228105258247_785934233_n.jpg ( Size: 57.26k ) Number of downloads: 114 10490174_648228065258251_1698655557_n.jpg ( Size: 99.42k ) Number of downloads: 127 1937833_648228118591579_18708774_n.jpg ( Size: 78.56k ) Number of downloads: 120 |
- CT 86 AUG
velceani |
![]() Membru autentic Group: Members Posts: 953 Joined: 29 May 09 From: C de Arges ![]() |
cel mai usor e sa verifici bateria, apoi masele pe caroserie, apoi
sigurantele. Daca nu e nici una e nasol, poate fi calculatorul.. |
Logan 2
Sl plus 1.2 16v 2016
zabar |
Membru Group: Members Posts: 155 Joined: 8 August 12 ![]() |
Colegu daca invarte electromotorul si nu porneste verifica butonul acela care taie alimentare in caz de accident,,si eu m-am chinuit o saptmana.Se oxideaa acel buton eu lam dat jos si pur si simplu am legat firele unul de altul izolatie si drum bun
laguna
2.2 / 150
mrkiry |
![]() Din tara unde nici apocalipsa nu ajunge... Group: Members Posts: 1.818 Joined: 2 December 10 From: Bucuresti ![]() |
Butonul acela doar taie alimentarea.90% e imobilizatorul defect
Megane2
2004 Lux Privilege
- GR85KYR Renault Megane 2,1.6 16v,113 cp,an 2004
DIRTYDOG |
![]() Membru incepator Group: Members Posts: 32 Joined: 5 July 11 From: IASI ![]() |
Fa urmatoarele verificari:
Verificați starea siguranței F03 din cutia siguranțe habitaclu. Siguranța este bună? Există defectul CONTACTOR BLOCARE UȘI? Verificați continuitatea și izolarea față de masă între pinul A5 al UCE decodor și tabloul de bord (pin 6 din conectorul negru). Cablajul este bun? Înlocuiți siguranța. Analizați acest defect și remediați. Remediați cablajul. Efectuați testele următoare pentru găsirea elementului defect: - dacă martorul antidemaraj este aprins permanent, debranșați conectorul UCE decodor și verificați dacă martorul se va stinge; - dacă martorul antidemaraj este stins, branșați pinul A5 al conectorului cablajului de la UCE decodor la o masă electrică și verificați dacă martorul se va aprinde. Răspunsurile sunt afirmative? Înlocuiți tabloul de bord. Înlocuiți UCE decodor. Aceasta procdura este luata dintr-un manual de secheme electrice. 11 Jul 2014, 20:22: Uite si un link unde gasesti manuale utile ptr. SOLENZA http://docauto.ro/manuale-dacia-solenza/ Mult succes. 11 Jul 2014, 20:27: Daca mai ai intrebari scrie la sectiunea SOLENTA nu incara tot forumu aiurea ca ne ametesti. Mai trebuia sa scrii si la sectiunea Duster si era complet. ![]() This post has been edited by DIRTYDOG: 11 Jul 2014, 20:27 |
LOGAN 1.0 SCE
2017
zabar |
Sustin butonul care taie alimentarea ma repet la fel si la mine invartea electromotorul dar nu pornea.Nu te lega de cablurile de masa caci daca erau intrerupte nu misca absolut nimic.Ia si tabloul de sigurante si verifical cu mare atentie plus si cutia neagra de la motor.
Revino cu remedieri sa ne spui ce a avut. Colegu tu cu ce cheie incerci sa pornesti masina???? Sa nu fie cheia cu buton defecta asta nu ai specificat. This post has been edited by zabar: 11 Jul 2014, 21:45 |
laguna
2.2 / 150
renaultlag2 |
![]() Membru autentic Group: Members Posts: 493 Joined: 23 February 13 From: Bucuresti ![]() |
Incearca butonul.
Imo daca era busit se aprindea becul si ramanea aprins. Daca este imo si ai nevoie de ecu cu imo off te pot indruma catre cineva. |
2001 Dynamique
zabar |
Up
laguna
2.2 / 150
Sirbu Cosmin |
zabar cheia cu care porneam masina este cea originala , tin sa precizez ca mergea numai cu o singura cheie putem sa pornesc masina! :|
<span class='edit'>12 Jul 2014, 10:31:</span> renaultlag2 , ce buton sa incerc????:| sa vad ca daca este ala sa ma indrumi tu:| <span class='edit'>12 Jul 2014, 10:41:</span> mrkiry , ce piese contine kitul de pornire pe care il ai tu??este de solenza? <span class='edit'>12 Jul 2014, 11:06:</span> zabar eu nu am buton care taie alimentarea, eu nu am acest buton pur si simplu nu este.. This post has been edited by Sirbu Cosmin: 12 Jul 2014, 10:07 Attached thumbnail(s) Primele_291.jpg ( Size: 123.78k ) Number of downloads: 218 |
- CT 86 AUG
ZLATE58 |
Membru autentic Group: Members Posts: 249 Joined: 7 December 08 ![]() |
nu mai incerca degeaba.
va trebuie o alta cutie decodoare si calibrata pe masina |
megane
1.6 16v electrica auto
mrkiry |
Kitul de pornire este format din uce decodor, ecu injectie,inel contact,cip cheie.Mai bine vorbim la telefon 0784164280
Megane2
2004 Lux Privilege
zabar |
Toate il au este imposibil sa nu il ai , poate a fost scos si legat pe direct si ascuns pe undeva sau au cazut mai jos firele si de asta nu le vezi.Dar din ce ne ai postat in poze nu prea arata bine deloc....Spor la teaba in continuare.
laguna
2.2 / 150
mrkiry |
QUOTE(renaultlag2 @ 11 Jul 2014, 21:45) Incearca butonul. Imo daca era busit se aprindea becul si ramanea aprins. Daca este imo si ai nevoie de ecu cu imo off te pot indruma catre cineva. Daca ar fi immo busit, nu ramane aprins neaparat martorul.Exista posibilitatea sa licare intruna, sa nu se aprinda deloc sau sa ramana aprins. |
Megane2
2004 Lux Privilege
velceani |
nici a mea nu are butonul acela, e din 2003
Logan 2
vladut88 |
![]() Membru autentic Group: Members Posts: 1.973 Joined: 22 May 09 From: Beius judetul bihor ![]() |
Foarte putine solenze au butonul acela
dacia ARO
SOLENZA scala 10,4 diesel 1,9 DRA
2004 1994
- bh 10 twa I hate BMW
spiridon |
![]() Membru autentic Group: Members Posts: 786 Joined: 5 May 05 From: Iasi ![]() |
Data fiind pozitia "din fabrica" cu mufa in sus si stiut fiind faptul ca atunci cind ploua apa se strecoara pe linga chederul parbrizului inauntru, cel mai ades ajungind direct in decodor !
Daca vreti sa intimpinati aceste probleme trebuie neaparat schimbata pozitia decodorului, adica pus cu mufa in jos si daca deja s-a stricat sunt mai multe variante: - immo off la calculatorul de injectie si merge fara cip in cheie - inlocuire decodor cu unul no sau de sh (complicat siscump trebuie cod din cheie, facut cipuri, adaptat - inlocuire chei, decodor, calculator (si acesta varianta e scumpica ) |
Dacia Supernova
- prima iubire, a inceput in...
- IS- inginer - frezez si programez chei, repar telecomenzi, immo off 0741024494
ionut.vl |
Membru incepator Group: Members Posts: 9 Joined: 30 April 12 ![]() |
Salutare, cei care aveti binecunoscuta problema a martorului antidemaraj care clipeste incontinuu dupa ce se pune contactul, problema este ca v-a intrat apa mai multa sau mai putina la UCE (sau la UCH - la Solenzele mai noi, din 2004).
Eu am patit-o si am rezolvat in felul urmator: este pe forum userul Spiridon Viorel din Iasi, am apelat la el pentru anularea decodorului UCE.I-am trimis calculatorul de injectie prin Fan Curier, din Cluj la Iasi, domnul mi-a facut IMMO OFF si acum merge ca vioara masinuta. Costuri: 100 lei manopera plus 40 lei transportul. Riscuri: destul de mici zic eu, desi acum e posibil sa fie pornita si cu alta cheie care se potriveste mecanic. Dar o sa-i pun o alarma si sa-i refac inchiderea centralizata. 16 Feb 2015, 20:26: Numar de telefon userul Spiridon Viorel din Iasi : 0741024494 |
2003, confort
Si eu cand am intrat in baie am facut o descoperire (sau inventie? mai studiez) revolutionara: apa calda. Cred ca ar trebui sa o inregistrez la OSIM.
edy99 |
![]() Membru autentic Group: Members Posts: 703 Joined: 7 June 11 From: Constanta (CT) - Petrila (HD) ![]() |
Oricine are interfata obd2 si ddt2000 poate face imo off, si costa mai putin achizitia decat sa dai decodorul la toti care cred ca au inventat mersul pe jos. Tinand cont ca solenza se deschide si cu o furculita, nu recomand asta
Dacia Solenza Scala;
Renault Laguna 2 Initiale Paris;
2003 / 2003;
- XX XX DOD_XX XX LOL 100% adrenaline
Crap |
![]() It's all about fishing ! Group: Members Posts: 289 Joined: 29 June 05 From: Bucuresti / Militari ![]() |
Al meu arata mai rau ca in pozele de sus...
Am luat smirghel fin si am dat pe toate contactele, l-am curatat bine, am pus capacul la loc plus silicon si am intors cutia cu mufa in jos sa fiu sigur ca nu mai patrunde apa. A pornit la sfert ! ![]() |
Dacia/VW/Audi
Solenza/MK5/A3/Megane III
2003/2008/2007/2013
JulianSLZ |
Membru incepator Group: Members Posts: 2 Joined: 7 February 12 ![]() |
Are cineva de vanzare un kit de pornire complet ptr Solenza 1.4 mpi din 2003? E cu UCE si nu gasesc niciunde cu inchidere pe el...
george_scala_2004 |
Membru autentic Group: Members Posts: 6.580 Joined: 16 April 09 ![]() |
http://www.daciaclub.ro/DONATII-obiecte-ac...-p4259482.html#
http://www.daciaclub.ro/-VAND-Dezmembrez-D...za-t283634.html http://www.daciaclub.ro/-VAND-Dezmembrez-D...ml#entry4260326 http://www.daciaclub.ro/-VAND-Dezmembrez-D...va-t276168.html http://www.daciaclub.ro/-VAND-Dezmembrez-S...ma-t254971.html http://www.daciaclub.ro/-VAND-DEZMEMBREZ-D...za-t276734.html http://www.daciaclub.ro/-VAND-DEZMEMBREZ-R...II-t273867.html |
... “The old world is dying and the new world struggles to be born: now is the time of monsters.”
- Antonio Gramsci. |
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 26th July 2025 - 23:44 |
