photomediaen19224hddaci.jpgphotomediaen19211bddaci.jpgphotomediaen19228hddaci.jpgDUSTER: THE CONCEPT CROSSOVER FROM
DACIA UNVEILED AT GENEVA MOTORSHOW
• Dacia is breaking fresh ground and springs yet another surprise with the unveiling in Geneva
of Duster, a futuristic, image-building crossover that promotes the same values for which the
brand has stood from the beginning.
• Duster is Dacia's first concept car and the fruit of close collaboration between Renault Design
Central Europe in Bucharest, Romania, and Renault Design Technocentre in Guyancourt,
France.
• Duster's athletic stance adds an undeniable sporty feel to the brand's hallmark robustness.
• Inside, the use of colour, generous cabin space and an original modular layout ensure a
particularly convivial ambience for occupants.
2
ROBUST AND SPORTY
Duster – Dacia's first concept crossover – is proud to be different. Seen from the driver's side, it is visibly a
sporting coupé, yet passengers entering from the other side will see it as an MPV (Multi Purpose Vehicle) with
a traditionally opening front door and rear-hinged rear door which suggest plush travelling refinement.
Duster's height of 1.49 metres, short front and rear overhangs (65cm and 80cm respectively), generous
wheelbase (2.80m) and compact volumes (4.25m long, 1.64m wide) exude an overriding sense of robustness
and sports appeal.
The front end features a broad bumper with two horizontal air-intake slits that suggest power. The grille
features evident Dacia styling cues and is flanked by headlamps which wrap over the front wings to form a
tapering line of light that stretches rearward towards the doors.
Viewed from the side, the clear-cut lines of the wheel arches and tall doors reinforce the impression that
Duster sits squarely on the road. The Anthracite Grey bodywork and extensive one-piece glazed sweep –
made possible by the absence of a central pillar – highlights the styling of the sides which are unmistakably
reminiscent of Duster's graphic identity.
At the rear, the engraved Dacia logo further emphasizes the concept car's robust, dependable credentials.
Like Logan, Duster is just 4.25 metres long, and its inherent agility ensures that it is perfectly at home in the
urban jungle. Meanwhile, its 21-inch, five-spoke aluminium alloy wheels, exterior mirrors positioned on the
window surround and trapezoidal aluminium exhaust tailpipes are telltale signs of its sporting pedigree.
Special care has gone into Duster's aerodynamic efficiency (Cd: 0.30) and the fluid lines of the body sides
enable air to flow freely along the vehicle's flanks before being jettisoned through the rear lights. The
aerodynamic, wing-like forms of the roof-mounted direction indicators also channel airflow towards the rear.
The sum of all this work has naturally been beneficial to fuel consumption, and Duster stands out as a
particularly environmentally-respectful crossover. Despite its performance potential, the particulate filterequipped
1.5 dCi 105hp engine (77kW) emits just 139g of CO2/km, equivalent to fuel consumption of 5.3
litres/100km.
A CROSSOVER WITH DACIA HALLMARKS
This futuristic crossover showcases the brand's core values – namely simplicity, robustness and authenticity –
in a surprising form, yet Dacia's hallmark ingenuity and generosity are immediately apparent in the way
designers have approached Duster's cabin.
3
The concept car's two-tone chocolate and blue interior exudes a sense of well-being and conviviality. The fully
glazed roof floods the cabin with light, while the enveloping forms of the staggered slim-line front seats
provide first class comfort and support. The driver's seat is incorporated in a structure which extends all the
way from the sill to the centre console, forming a sculptural, one-piece ensemble that echoes the exterior's
sporty appeal.
The user-friendly dashboard features fluid, expressive lines while employing simple materials. The driver's
side front airbag is housed in the lower part of the steeringwheel which has made it possible to position the
screen centrally and free up appreciable stowage space on the dashboard. The latter's receding lines also
provide record kneeroom of 280mm for the front passenger who benefits from an exceptionally comfortable
seating position. The bellows-like form of the original two-tone dashboard incorporates a 20-litre glovebox,
while the door inserts each include eight-litre stowage bins. Another bin has been cleverly concealed in the
back of the rear right-hand seat. A simple push causes a box to slide forward from the boot which itself is in
total keeping with the Dacia spirit, with the upright tailgate providing a carrying capacity of 470dm3 (VDA), a
remarkable achievement for a vehicle of Duster's compact overall dimensions .
Duster is an adaptable, modular concept car. The four-seat 'daily driver' layout can be swiftly converted into a
leisure configuration in a matter of seconds. The passenger seat slides underneath the driver's seat on rails
concealed in the floor to leave just one front seat and consequently free up a total carrying volume of two
cubic metres. Thanks to a recess in the floor and a strap located under the dashboard, this space can be
used to carry a trials mountain bike.
4
Dimensions
Length (mm) 4,250
Width (mm) 1,640
Height (mm) 1,495
Overall width, doors open (mm) 4,285
Wheelbase (mm) 2,804
Front track (mm) 1,637
Rear track (mm) 1,640
Unladen weight (kg) 1,300
Boot volume (dm3 VDA) 470
Technical data
Engine type dCi 105
Maximum power hp (kW) 105 (77)
Maximum torque (Nm) 240 at 2,000rpm
Acceleration from standstill to 100kph (s) 9.6
CO2 emissions
Combined cycle fuel consumption
139g/km,
equivalent to 5.3 litres/100km
Transmission Manual six-speed gearbox
Tyres 245/35 ZR21
Wheels 21-inch diameter wheels
Partners
ProtoStyle Body styling
Michelin Tyres
Media contacts:
Product: Freddy Cholière, +33 (0)1 76 84 63 36
Corporate: Axelle de Ladonchamps, + 33 (0)1 76 84 64 69
