Demontare bord CN, Schema de demontare
vaally |
30 Aug 2005, 13:03
Membru Group: Members Posts: 182 Joined: 4 August 05 From: Ploiesti |
Dacia berlina
1310 L
- PH 11 SYH
vaally |
30 Aug 2005, 13:04
Nu am precizat Dacia 1310 L din 1998 -nu stiu daca are importanta, Decembrie 1998.
Dacia berlina
1310 L
- PH 11 SYH
ionutctn |
2 Sep 2005, 08:01
Membru cu TDI Group: Members Posts: 1.373 Joined: 20 November 04 From: Bucuresti |
Nu trebuie mai bani ca doar suntem aici ca sa ne ajutam cel putin asa cred eu
1998 Skoda Superb Elegance
People who say it cannot be done, should not interrupt those who are doing it. |
vaally |
2 Sep 2005, 09:30
Dacia berlina
1310 L
- PH 11 SYH
Dyda |
2 Sep 2005, 10:23
Membru autentic Group: Members Posts: 677 Joined: 30 April 04 |
Nu , vei constata singur ca ai spatiu ff mic si nu ai cheie adecvata
-------------------- Kox
2 Jan 2006, 23:05
Academician doctor inginer, savant de renume mondial Group: Moderatori Posts: 7.449 Joined: 11 November 03 From: Bucuresti |
imi pare cu regret ca intervin aici, dar daca nu o fac atunci asta nu o sa mai fie un loc unde sa ne putem ajuta din simplul motiv ca nu va mai exista (copyright, drepturi de autor, etc ... va spune ceva ???)
P.S. exista PM |
octavianjitaru |
10 Jul 2009, 19:03
Membru incepator Group: Members Posts: 1 Joined: 10 July 09 |
va rog mult, as vrea si eu schema pentru demontare bord CN. va multumesc
1410
1997 / Berlina
cristymishu |
10 Jul 2009, 20:22
Membru incepator Group: Members Posts: 3 Joined: 4 July 09 |
http://forum.softpedia.com/lofiversion/index.php/t17587.html sper se ter ajute.
1310 CLi
Mr_Devil83 |
10 Jul 2009, 23:06
Membru autentic Group: Members Posts: 2.254 Joined: 14 June 08 |
Sunt 5 suruburi de 5 sau de 6 care se pot desface folosind o tubulara cu clicket mica, din trusele de scule chinezesti. Nu cred ca trebuie musai dat jos parbrizul.
1300 / SUPERNOVA EUROPA
1984 / 2002
neoxxx |
20 Jan 2010, 10:52
Membru incepator Group: Members Posts: 1 Joined: 20 January 10 |
As vrea si eu o schema de demontare a bordului. Am cautat peste tot si nu am gasit. Daca ma puteti ajuta va rog sa ma contactati pe messenger la ID: lucky_serpisor
1410
1999
- VL05YFB
Alexio |
20 Jan 2010, 11:17
Ciocolata mecanica! Group: Members Posts: 1.108 Joined: 7 December 08 |
Ai vointa mare daca vrei sa dai CN-ul jos... ca sfat... cine iti zice sa dai parbrizu jos ca sa il scoti, sa nu il asculti... cauta in comert surubelnite cu gatul indoit la diferite grade pentru suruburile de la parbriz.
1310 Berlina
adrianne |
20 Jan 2010, 12:11
Membru autentic Group: Members Posts: 518 Joined: 9 September 05 From: Bucuresti |
Sau surubelnite elastice, ce se pot arcui, si in capatul carora poti pune tubulara necesara.
1310 L
1996
- B44UCJ parerea unui amator...
ghitza |
20 Jan 2010, 12:23
Membru autentic Group: Members Posts: 4.806 Joined: 23 April 08 From: ARAD |
e chinuiala lu dracu fara sa dai parbrizu jos.mai bn il dai ca nu e greu si lucrezi frumos ca nu e greu de dat.doar sa lucrezi cu grija.spor
Dacia/BMW 316i an 99
1310 li
2003 Berlina
- Ar-07-GIB/BG
Alexio |
21 Jan 2010, 00:06
Eu nu as da CN-ul jos nici sa ma bati... mai bine platesc la service sa o faca ei... m-am uitat in schema de la mazda... e mai simplu sa imi demontez la aia bordul decat CN-ul de Dacie :|.
This post has been edited by Alexio: 21 Jan 2010, 00:06 |
1310 Berlina
vis-a-vis |
21 Jan 2010, 00:11
DaciaClubber Group: Members Posts: 7.888 Joined: 20 June 05 From: Bucuresti |
Iti dau parbrizul jos si-l pun la loc pana desfaci tu doua suruburi
Logan MCV
1.5 DCi Life is a journey, not a destination.
baranga |
21 Jan 2010, 12:35
...eu merg cu DACIA iar tu pe jos.... Group: Members Posts: 888 Joined: 8 February 08 From: Slobozia- IALOMITA |
corect hai sa zicem ca desfaci suruburile cu parbrizul pus da le nai pui la loc cu parbrizul pus???
Break
1999 - 1310CL
- IL 03 HLE mi-au sters reputatia;eu o aveam cea mai mare
razvan32 |
22 Jan 2010, 11:01
superdaciuta Group: Members Posts: 842 Joined: 12 January 08 From: Ploiesti |
ai 3 suruburi stanga si 3 suruburi dreapta
1990 TX BERLINA
- 6-PH-7008
ghitza |
22 Jan 2010, 12:16
tot treaba mai buna iese cu parbrizul dat jos.ai 3 in stanga 3 in dreapta +cele 2 de pe fiecare stalp(total 4).cochilie volan+volanu.consola cu ceasuri si toate cele.l-am dat asta vara cand am antifonat.e putin de munca
1310 li
2003 Berlina
- Ar-07-GIB/BG
tom79 |
5 Feb 2010, 20:29
Membru incepator Group: Members Posts: 26 Joined: 17 January 10 |
QUOTE(Alexio @ 21 Jan 2010, 00:06) Eu nu as da CN-ul jos nici sa ma bati... mai bine platesc la service sa o faca ei... m-am uitat in schema de la mazda... e mai simplu sa imi demontez la aia bordul decat CN-ul de Dacie :|. nu trebuir sa dai bordul jos.doar plansa de bord.exista niste surubele sub scrumiera sisub ceasurile de bord. se scot grile aerisire cleme de la ceasuri |
1994 berlina
1994 berlina
- ct 94 ela
ph88dmc |
15 Feb 2010, 15:36
Membru incepator Group: Members Posts: 53 Joined: 7 September 09 From: ploiesti |
salut baieti ..si eu as vrea sa dau bordul jos.....mi-ar prinde bine nintelus ajutor..scheme ceva ,...orice.... problema si la mine cu stergatoarele ..la mine a iesit din parghia aceea de stanga - dreapta angrenata de motor , surubul acela care tine stergatorul...
berlina
1998 / 1310 L / benzina
- ph88dmc
CGDBZ |
15 Feb 2010, 15:46
Membru autentic Group: Members Posts: 2.487 Joined: 8 July 09 From: BZ |
Eu cand am dat aeroterma jos nu am dat bordul dar nu am reusit sa o scot decat desmembrata , m-am chinit ceva , piele pe varful degetelor nu prea mai era dar am reusit , nu am vrut sa dau bordul jos ca tot asa am inteles ca trebuie dat parbrizul jos si al meu are cateva ciobituri de la pietricele sarite de pe drum si mi-a fost frica sa nu o "pun" de vre-un parbriz nou , dupa am aflat de la un amic ca el a dat bordul jos fara sa dea parbrizul , a folosit o cheie elastica cum spunea si un coleg mai susu .
baranga |
15 Feb 2010, 21:16
pentru a umbla la ansamblu stergatoare nu trebuie sa demontezi tot bordul;
da jos ceasurile si cutia la torpedo si aeratoarele centrale;nu e greu deloc |
Break
1999 - 1310CL
panter1 |
16 Feb 2010, 01:01
Membru autentic Group: Members Posts: 792 Joined: 26 February 09 From: Bucuresti |
pentru initiatorul topicului, la mine nu mai mergea dintr-o data stergatoarele si aeroterma, m-am gandit ca nu avea cum sa se strice deodata, apoi am desfacut plasticul acela dintre volan si ceasuri, am miscat putin de firele alea si au pornit amandoua, apoi mi-am dat seama ca era de la papucei, am scos mufele am strans papuceii, aveam si niste fire cam dezlipite si izolate, am desfacut legat bine firele sa faca contact, reizolat.. si merge si in ziua de azi.. mai bine vezi si tu daca problemele sunt de natura electrica.. apoi te apuci sa dai bordul jos ca te chinui mult si e pacat.. problema poate fi din alta parte..
emil aluas |
14 May 2010, 13:19
Membru incepator Group: Members Posts: 84 Joined: 17 June 09 From: Salaj |
imi poate spune si mie cineva cum sa dau bordu jos, numai ceasurile la dacia 1300
13.01.1974
- ALU
DannY_SmekeruL |
14 May 2010, 18:02
Membru autentic Group: Members Posts: 454 Joined: 30 August 07 From: Bucuresti-Slobozia |
pai desfaci suruburile din dreptul parbrizului apoi vezi ca pe fiecare parte ai cate 3 surburi cu cap de surubelnita stea .desfaci si cu asta basta(cel putin eu atat imi aduc aminte ca am facut cand am pus bordul de cn in locul celui de 1300
SOON Dacia 1310
with F7P Kompressor Edition
'84 VW Passat B6 2.0 TDI
emil aluas |
18 May 2010, 20:20
da dar eu vreau sa dau jos doar ceasurile fara sa ma complic sa dau tot bordu jos
am problema la mufa de la ceasu din dreapta nu face contact numai cand o misc |
13.01.1974
- ALU
ghitza |
18 May 2010, 20:51
pai tu nu ai bord CN nu?am vazut in semnatura le scoti prin stanga -jos si gata
1310 li
2003 Berlina
- Ar-07-GIB/BG
marianmarian_78@yahoo.com |
28 Dec 2014, 10:15
Membru incepator Group: Members Posts: 25 Joined: 27 December 14 |
Buna ziua! Va rog,la o Dacie din 1998 cu bord de CN cum pot da jos doar ceasurile, fara sa demontez bordul? Multumesc mult!
1410
1999
- BZ-01-SRL
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 21st May 2024 - 18:31 |
