reglare volum, reglare volum in functie de viteza
niculescu |
17 Nov 2007, 22:46
Membru NATO Group: Members Posts: 56 Joined: 16 November 07 |
2007/abs plus
- B 01 HHH
l@u |
18 Nov 2007, 09:56
Membru autentic Group: Members Posts: 6.057 Joined: 31 July 06 |
Da' cu cartea tehnica ai incercat ?
Land Rover
Freelander
Td4, HSE
migabryel |
18 Nov 2007, 11:14
Membru autentic Group: Members Posts: 232 Joined: 31 March 06 From: Suceava |
s-ar putea sa zic tampenii, dar cred ca nu ai optiunea asta la modelul respectiv de blaupunkt
Logan Ambition
1.6mpi 2005
tester |
18 Nov 2007, 11:26
dacia tester ;) Group: Members Posts: 747 Joined: 22 August 07 From: iasi |
cu un simplu search te ai fi lamurit mai usor: http://www.daciaclub.ro/index.php?showtopi...70&hl=blaupunkt
- is xx xxx
niculescu |
18 Nov 2007, 13:22
in carte nu scrie...am citit din scoarta in scoarta.....iar ce se vb la adresa indicata este despre un cd player de renault cu sagetzi,fara rola...
2007/abs plus
- B 01 HHH
l@u |
18 Nov 2007, 14:27
Daca nu scrie in carte atunci iti spun eu ca 100% nu are aceasta functie Blaupunkt-ul tau.
Land Rover
Freelander
Td4, HSE
bobo77 |
18 Nov 2007, 15:41
........................... Group: Members Posts: 7.213 Joined: 27 January 06 From: Mangalia |
Asa stiam si eu ca nu are aceasta functie.
Laureate 1,6 mpi
2008 ph 2
niculescu |
18 Nov 2007, 18:07
ok merci
2007/abs plus
- B 01 HHH
18 Nov 2007, 23:15
Blaupunktul de pe Loganuri nu are functia de speed.
Aici se inchide. |
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 4th May 2024 - 11:44 |
