Disc ambreiaj dus?, Tremura la sfarsitul cursei
rattlesnake |
12 Oct 2007, 19:34
Membru autentic Group: Members Posts: 218 Joined: 2 April 06 From: Bucharest |
Astra H 1.7Cdti 100cp
2008 (ex Dacia Logan 1.4 2006)
C@talin |
12 Oct 2007, 19:49
Nu cred ca se manifesta asa :| .Spunene de ex. ce turatie ai in a 4 la 60 la ora? Sau incearca testu cu frana de mana .
Range Rover
V8 5.0
Vogue SE
andrei_2006 |
12 Oct 2007, 20:12
Loganist Group: Members Posts: 737 Joined: 21 September 06 From: Bucuresti |
Nu e de la discul de ambreiaj, probabil e in cutia de viteze ceva stricat, posibil un pinion.
2006 Laureate Plus
rattlesnake |
12 Oct 2007, 20:14
Dar cum se manifesta? In a 4-a la 60 am cam 2400-2500rpm...daca nu ma insel. O sa-ti zic maine exact.
Mentionez ca se manifesta accentuat cand o calc mai mult, sau am greutate in masina, precum si atunci cand urc vreo panta, bordura etc... Multi mi-au zis ca ar putea fi discul, cat si placa... Deci sa ma pregatesc pentru 10-12milioane lei vechi. This post has been edited by rattlesnake: 12 Oct 2007, 20:16 |
C@talin |
12 Oct 2007, 20:25
Moamma daca ai asa mult la 60 in a 4, e dus,patineaza
This post has been edited by C@talin: 12 Oct 2007, 20:25 |
Range Rover
V8 5.0
Vogue SE
12 Oct 2007, 22:20
Si eu as banui zona ambreiajuli dupa manifestari.
12 Oct 2007, 22:24
- Group: Members Posts: 21.840 Joined: 19 April 05 From: Romania |
Este o problema destul de frecventa asta cu tremuratul. Eu as incepe cu un reglaj al ambreiajului. Nu cumva tine sus ambreiajul ?
This post has been edited by IRONICK: 12 Oct 2007, 22:41 |
memyselfandI |
15 Oct 2007, 09:49
m Group: Members Posts: 191 Joined: 8 March 05 From: Bucuresti |
salutare,
vis-a-vis de ambreiaj am si eu o mica problema. Scartaie pedala de ambreiaj spre finalul cursei, dar numai cand se incalzeste. Adicatelea cand plec de pe loc dimineata, merge ca nou..dupa care incepe sa decupleze sacadat. Am tot uns una alta pe acolo si la fel.. daca n-am explicat bine, cer scuze. Bafta. |
1.6
- 7727 "la curse e simplu, totu' e sa faci ca drumul"
Steel Tormentor |
15 Oct 2007, 10:58
Membru autentic Group: Members Posts: 954 Joined: 30 March 07 From: Constanta |
Daca tot se vorbeste aici de ambreiaj o sa postez si eu cateva constatari. La revizia de 15 000 cei din service au avut ceva cu ambreiajul...l-au reglat si acum cupleaza mai sus ca inainte si pedala este si mai tare la apasare. Ca problema aparuta dupa acest reglaj, am observat ca intra mai greu in marsarier cateodata. O alta chestie sesizata mai dinainte ar fi un scartait al pedalei (ca de metal pe plastic). Ca intrebare, ce le-a trebuit sa modifice cursa pedalei, nu era bine din fabrica?
2007 Preference 1.4MPI
Kojak |
15 Oct 2007, 18:58
Membru autentic Group: Members Posts: 1.786 Joined: 18 January 07 From: Bucuresti |
C@talin |
15 Oct 2007, 19:11
Bine bre domn profesor
Range Rover
V8 5.0
Vogue SE
Kojak |
15 Oct 2007, 19:19
...pan' la urma, la tine e o.k. ambreiaju'?
AdrianMC |
19 Oct 2007, 10:01
Membru Group: Members Posts: 187 Joined: 29 March 06 From: Bucuresti |
Te rog sa postezi aici in ce consta acel test cu frana de mana. Eu am incercat ceva si vreau sa stiu daca se potriveste.
Multumesc frumos. |
nova_invicta |
25 Oct 2007, 09:08
Membru autentic Group: Members Posts: 258 Joined: 24 July 07 |
salut am vazut ca se discuta despre ambreaj am si eu o problema . Dupa 10-15 kilometri de mers prin oras bara la bara se aude un rontait ca si cum ar fi ceva slabit la ambreiaj daca apas pedala pana la fund dispare zornaitul acela sa fie oare rulmentul dus
logan 1.4 mpi
2006 preferance S.P.Q.R
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 28th April 2024 - 12:14 |
