1.5dCi - merge inapoi dar nu inainte..., bolt desfacut prin cutia de viteze
zvic |
17 Jul 2007, 22:21
Membru incepator Group: Members Posts: 42 Joined: 6 January 05 |
Ambition
DCI 2006
adip |
17 Jul 2007, 22:32
Banned Group: Members Posts: 2.177 Joined: 12 July 06 From: Melbourne, Victoria |
* What you live with you learn.
What you learn you practice. What you practice you become. What you become has consequences . |
zvic |
17 Jul 2007, 22:46
Ambition
DCI 2006
ady85btz |
17 Jul 2007, 23:01
Membru onorific Group: Members Posts: 3.803 Joined: 16 March 06 From: Bucuresti |
Ai incercat sa pleci si cu a-2-a treapta?
Kia
Cee'd ~the BEST~
zvic |
17 Jul 2007, 23:13
Am incercat si cu treapta a 2-a, acelasi lucru.
Masina e din 01.07.2006 si are cca 21000km, acum o luna i-am facut revizia de 20000km, nu am avut probleme pana acuma, nici macar agataturile alea la schimbat viteza, doar iarna pana se incalzea putin intra o idee mai greu. Singura problema e un zgomot in stalpul stanga fata si o ciobitura pe parbriz , mi-a sarit o piatra de la o alta masina. This post has been edited by zvic: 17 Jul 2007, 23:18 |
Ambition
DCI 2006
ady85btz |
17 Jul 2007, 23:23
ciudata problema.cheama dacia asistenta ca d-asta ai garantia 0248.500.500 asta parca era numaru
Kia
Cee'd ~the BEST~
zvic |
17 Jul 2007, 23:27
Acuma nu mai chem, o sa merg dimineata si vorbesc direct cu aia in service. Voiam doar niste indicatii ca io cum nu ma pricep sa nu-mi bage aia cine stie ce povesti.
This post has been edited by zvic: 17 Jul 2007, 23:41 |
Ambition
DCI 2006
ady85btz |
17 Jul 2007, 23:41
sa postezi ce-au depistat daciotii .bafta maine
Kia
Cee'd ~the BEST~
zvic |
17 Jul 2007, 23:43
Sa fie, o sa postez diagnosticul.
Ambition
DCI 2006
18 Jul 2007, 09:27
Sa nu fie rotile infranate la mersul inainte.
zvic |
18 Jul 2007, 10:26
Dimineata am mers la masina, cu toate actele si nr de telefon de la dacia asistenta, pregatit sa ii chem. Am incercat sa o pornesc sa vad daca mai face, am pornit fara probleme, am facut o tura de vreo 10 km si a mers ok. Am zis ca tot merg in service sa se uite la ea, au luat-o si astia la ture, chiar de 2 ori cu 2 mecanici diferiti, totul mergea ok. Au zis ca daca mai face sa sun la dacia asistenta si sa vedem apoi ca ei nu stiu ce sa-i faca (au verificat uleiuri, au ridicat-o si s-au uitat pe sub ea, chiar si pe computer au pus-o).
Am iesit din service, nici n-am apucat sa fac 500 de metri si iar a inceput sa faca exact la fel ca si aseara, in marsarier mergea in fata nu, i-am sunat pe astia din service, au venit si au incercat si ei, au ajuns la concluzia ca se blocheaza cutia de viteze si ca trebuie desfacuta. Nu am inteles exact dar unul din ei spunea ceva de genul ca este un magnet care colecteaza eventualele ramasite metalice de pe acolo si s-ar putea sa fi sarit ala de la loc si sa fi ajuns ceva mizerie intre pinioane si ramane cuplat marsarierul si cand dai inainte. I-am intrebat de ce numai in anumite momente si n-au zis nimica, azi o desfac si poate dupamasa o sa-mi dea un diagnostic mai exact. Va tin la curent. <span class='edit'>18 Jul 2007, 16:15:</span> Tocmai mi-am ridicat masina din service, se pare ca era ceva bolt destrans prin cutia de vciteze si ramanea marsarierul cuplat tot timpul. Au zis ca se poate sa fi fost slabit de mai mult timp si sa fi dat in ceva groapa si s-a miscat. Am facut cu masina cca 20 km, pe un deal mai mare, a mers fara probleme, parca motorul suna putin altfel. This post has been edited by zvic: 18 Jul 2007, 16:16 |
Ambition
DCI 2006
ady85btz |
18 Jul 2007, 17:04
Rare problemele la cutiile de pe Logan,si tu ai fost unu din norocosi .In ce sens se aude motor:mai bine sau mai prost?
Kia
Cee'd ~the BEST~
zvic |
19 Jul 2007, 10:49
Nu stiu daca e doar o impresie dar parca sunetul motorului e putin mai ascutit, parca se aude un clinchet metalic mai tare putin decat inainte. Oricum o sa vad dupa ce fac mai multi km si o sa ma mai uit prin topicurile cu zgomote de aici.
Ce am uitat sa va zic este ca atunci cand am fost prima data in service mi-au verificat-o si pe calculator si avea o eroare, ceva cu presiunea pe sina parca, am retinut un cod dar nu stiu daca e corect, ceva cu CC17 parca. Poate sa-mi spuna cineva mai multe detalii despre acest defect ? 19 Jul 2007, 11:00: Si inca o chestie, desi pana acuma am fost foarte multumit de masina, dupa faza asta parca mi-am pierdut increderea, chiar daca au strans ei ce au avut de strans pe acolo nu mai vreau sa raman pe undeva in mijlocul campului cand ti-e lumea mai draga. In consecinta m-am hotarat sa vand masinuta asta si sa iau altceva. Logan Ambition 1,5 DCI, 1 iunie 2006, 21000km, cam care ar fi un pret corect pentru ea ? This post has been edited by zvic: 19 Jul 2007, 11:00 |
Ambition
DCI 2006
TIulian |
19 Jul 2007, 13:21
Metode de seducție cu cărămida.. Group: Members Posts: 197 Joined: 27 March 07 |
QUOTE o eroare, ceva cu presiunea pe sina parca cel mai probabil este vorba de presiunea motorinei in rampa, si eroarea asta e generata de obicei de desincronizarea pompei de injectie => probleme la distributie; daca zici ca mai e si zgomot metalic, asta corelat cu suspiciunea de desincronizat distributie => e posibil sa degenereze grav de tot, de regula daca sare distributia suficient de mult se lasa cu supape indoite, tacheti facuti praf, in cazuri extreme chiar si axa cu came fisurata, etc. mai du-te odata in service, si cere-le extra sa verifice bine distributia.. LE - ca sa fii sigur ca verifica ca lumea, si nu doar se uita la misto spune-le ca "la un moment dat s-a aprins pe bord becu ala portocaliu in forma de motor, moment in care motorul a inceput sa vibreze puternic, a pierdut din putere, si s-a oprit" - asta ar trebui sa ii alarmeze... This post has been edited by TIulian: 19 Jul 2007, 13:32 |
1816 SLR Cum să îți recucerești prietena, după ce i-ai pronunțat din greșeală numele pe râgâitură..
zvic |
19 Jul 2007, 19:03
Azi am facut cca 20 km cu masina, am oprit radioul sa ascult motorul. Cred ca chestia aia cu zgomotul a fost doar o impresie de moment, azi a tors foarte frumos si a mers ok.
L-am intrebat pe un tip din service si a zis ca e posibil ca eroarea sa fi aparut din cauza problemei cu cutia de viteze. |
Ambition
DCI 2006
zvic |
26 Jul 2007, 00:48
Intre timp am mai facut ceva km, am facut si vreo 400 km in afara orasului. Zgomotul ala la motor exista dar se manifesta doar la turatii mai mari, cam de la 3000rpm, nu e continuu, de exemplu daca tin constant la 3500rpm nu se aude cu aceeasi intensitate, nu stiu cum sa explic, parca motorul nu merge rotund, e cumva ca si cum clantanitul ala de diesel nu mai e corelat cu turatia. Un cunoscut care are si el un logan diesel a zis ca si la el s-a auzit asa o perioada dar acuma a disparut.
Inca nu am avut timp sa merg in service dar sper ca saptamana viitoare o sa reusesc. This post has been edited by zvic: 26 Jul 2007, 00:48 |
Ambition
DCI 2006
cbogdy |
27 Jul 2007, 16:50
Membru autentic Group: Members Posts: 249 Joined: 23 January 06 |
zvic
stai linistit... dai gaz. asa face si a mea, uneori mai tare, uneori mai incet... si face asa cam de 15k km am fost cu ea la "doctor" si autorizat (vezi Dacia service) si la "baieti" specialisti in diesel. Asa face pompa de injectie, ceva pe la avans, nu ai ce sa-i faci. Teoretic la toti face, la unii mai tare, la unii mai incet, ideea e de ureche muzicala. A... bine ca nu se accentueaza sunetul chiar ieri am venit de la mare si l-am ascultat, este exact la fel ca prima data cand l-am constatat. mentionez ca am 47.800 km. |
2006-1.5DCi65Cp berlina, 2009-1.5DCi85Cp MCV
- HD***** tot HD*****
calin.c |
29 Jul 2007, 11:20
Membru autentic Group: Members Posts: 310 Joined: 27 July 04 From: sighisoara |
lipsa presiune sina nu are legatura cu distributia si nici cu cv
posibila cauza : ai ramas fara motorina odata ,pompa slaba, un ijector slab sau filtrul de motorina murdar |
cbogdy |
29 Jul 2007, 13:50
calin.c
esti simpatic foc. la cine ai dat raspunsul? |
zvic |
2 Aug 2007, 12:49
Vroiam sa zic ca poate din cauza ca imi tot murea motorul cand am avut problema cu cutia a aparut si eroarea aia. In orice caz face in continuare la fel la turatii mari si inca tot nu am apucat sa merg in service, cand o sa am ceva concret o sa mai postez.
Ambition
DCI 2006
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 31st May 2024 - 19:42 |
