Afisare defectuoasa nivel combustibil
iulian00 |
13 May 2007, 13:33
Membru incepator Group: Members Posts: 12 Joined: 13 May 07 |
Logan - 1,4
dec 2006 / Laureate
- VLxxxxx
andrei_2006 |
13 May 2007, 15:23
Loganist Group: Members Posts: 737 Joined: 21 September 06 From: Bucuresti |
N-a mai auzit problema asta, in meniul de diagnoza (unde apare si cati litrii mai ai in rezervor) nu dadea nici o eroare?
This post has been edited by andrei_2006: 13 May 2007, 15:23 |
2006 Laureate Plus
C@talin |
13 May 2007, 15:51
Am patit si eu,da sa rezolvat de la sine.
Range Rover
V8 5.0
Vogue SE
Cossty |
14 May 2007, 08:03
Cossty Group: Members Posts: 112 Joined: 19 April 06 From: Ploiesti |
Nu se stinge becul decat daca bagi benzina cat sa sara de 2 liniute.
Cel putin asa face a mea. |
- PH-xx-FRG Dacia Logan Laureate 1.4 MPI (deocamdata multumit)
Opel Corsa D 1.2 enjoy + optionale (f. multumit) |
Giurisici Fabian |
14 May 2007, 08:25
Membru autentic Group: Members Posts: 1.123 Joined: 17 January 06 From: B de la Bucale |
la un amic era becul aprins si avea 15 litrii de benzina
solutia;am desfacut borna- de la baterie cam 10 min dupa care si-a revenit |
Logan II 1.5DCI
Laureat 2014
Amedeus |
14 May 2007, 12:16
Membru cu Logan Group: Members Posts: 1.907 Joined: 13 December 04 From: TM |
Da, si la mine e la fel. (am mai scris pe aici in urma cu cateva luni) Nu trebuie insa 10 min e suficient 10-20 sec.
Am incercat sa scot siguranta de la tabloul de bord. In afara de ceas si celalalte chestii memorate, care s-au sters, nu s-a rezolvat nimic cu indicatorul de nivel carburant. Solutia e borna sau o siguranta mare de 30 A din dreapta bateriei (cutia neagra de plastic) Atentie insa, veti avea nevoie de codul de la cass, CD. This post has been edited by Amedeus: 14 May 2007, 12:22 |
Megane Sedan IV Tce 116
2019 Business
Mythica |
14 May 2007, 12:32
Membru Group: Members Posts: 151 Joined: 23 September 06 From: Buzau |
Se reseteaza eroarea din meniul de diagnoza si daca nu se rezolva problema se desface borna de la baterie.
2006 Laureat Plus 1.4
iulian00 |
15 May 2007, 11:01
Cred ca am specificat ca in meniul diagnoza afisa corect...
Asta a facut totul mai interesant Deci asa face toate Seamana a problema soft sau interfatare incorecta.. This post has been edited by iulian00: 15 May 2007, 11:03 |
Logan - 1,4
dec 2006 / Laureate
- VLxxxxx
Mythica |
16 May 2007, 00:12
In meniul de diagnoza afiseaza nr de litrii din rezervor corect, dar eroarea de afisare e semnalata prin "--to" (sau ceva de genu asta). Daca apare asa, iesirea din meniul de diagnoza o faci prin apasarea si mentinerea apasata a butonului de la bord si nu prin luarea contactului.
DFA |
18 May 2007, 08:11
moderator://DC/Logan Group: Moderatori Posts: 3.514 Joined: 30 September 05 From: Buzău, RO |
Eroarea "TO" din meniul de diagnosticare nu are nici o legătură cu problema discutată aici, care se rezolvă foarte simplu printr-o resetare a CB făcută din meniul de diagnosticare:
QUOTE Cum se intra in meniul de diagnosticare al Calculatorului de Bord si ce semnifica valorile afisate: 1. Se tine apasat butonul de RESET in timp ce se pune contactul si se mentine apasat RESET timp de 5 secunde. Daca se porneste motorul va fi disponibila si informatia de la pct. 7. 2. Turometrul și Vitezometrul incep sa baleieze. 3. Se elibereaza butonul de RESET, apoi se apasa scurt pe el, trecand astfel cu fiecare apasare prin cele 5 ecrane de informatii, dupa cum urmeaza: 4. Prima apăsare: Toți martorii luminoși se aprind (doar la primele versiuni), pe ecran apare ceasul și versiunea de software a CB, turometrul si vitezometrul incep sa baleieze aproape toata scala de turatii, respectiv viteze. 5. A 2-a apăsare: Se aprind toate segmentele afișorului 6. A 3-a apăsare: Se afișează nr. de litri din rezervor (dacă e vreun defect la senzor apare "---") 7. A 4-a apăsare: Se afișează debit carburant în litri/oră dacă e motorul pornit (dacă e vreun defect apare "--"). La primele versiuni de software al TdB valoarea era afisata si daca ea era mai mica de 1 litru pe ora. La versiunile actuale nu se afiseaza decat valori mai mari de 1 litru pe ora, necesitand fie turarea motorului, fie cresterea sarcinii (de ex. prin pornirea AC). 8. A 5-a apăsare: Se afișează eventuale defecte memorate la senzori (toate defectele afișate în meniul de defecte de senzori memorate sunt defecte care au fost detectate dar nu mai sunt confirmate prezente, adică au avut loc) - 8.1 "- - -TO" - circuit deschis senzor temperatură apă - dacă motorul e rece nu se ține seamă de el - 8.2 "- - -TC" - scurtcircuit senzor temperatură apă - 8.3 "-JO- -" - circuit deschis senzor jojă carburant - 8.4 "-JC- -" - scurtcircuit senzor jojă carburant - 8.5 "D- - - -" - absență semnal la senzorul de debit carburant - se ține seamă de el numai dacă există CB instalat În caz de mai multe defecte memorate sau prezente, acestea sunt afișate pe o singură și aceeași linie a afișorului. Pentru a șterge defectele memorate plus resetarea datelor parțiale din CB și să ieși din secvența de autodiagnosticare, apasă lung pe tasta RESET. Aceasta procedura de resetare serveste si la rezolvarea afisarii incorecte a volumului de combustibil din rezervor. Dacă vrei să ieși din meniul de diagnosticare și nu vrei să ștergi defectele memorate și să aduci la zero datele parțiale din CB scoți contactul. |
Logan III Comfort
ECO-G 100cp
2021 sedan
ex Logan I 1.5 |
Mythica |
18 May 2007, 08:27
QUOTE(iulian00 @ 15 May 2007, 11:01) Nu ai specificat daca afiseaza vreo eroare. DFA are dreptate, eroarea pt carburant este "--jo". Mi s-a intamplat de multe ori sa ramana becul de benzina aprins (mai ales daca alimentam cu putina benzina, 5-10 l ) si de fiecare data stergeam eroarea prin resetarea CB. |
iulian00 |
21 May 2007, 21:31
Azi am patit-o din nou, dar am rezolvat folosind resetul specificat mai sus...
Imi pare cam des.... This post has been edited by DFA: 22 May 2007, 08:50 |
Logan - 1,4
dec 2006 / Laureate
- VLxxxxx
holograma |
22 May 2007, 12:26
Membru autentic Group: Members Posts: 437 Joined: 20 December 06 |
cea mai buna solutie e sa faci plinul dupa ce se aprinde becul...
2005 Laureate
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 15th May 2024 - 00:49 |
